2475/20AGY-500
2475/20AGY-500
    DABURNELECTRONICS
    FEPHIVOLT#2025KV500FTGY
2475/20AGY-500 数据手册
Daburn Electronics & Cable 44 Richboynton Road Dover, NJ 07801 #2475 FEP High Voltage Wire Fluorinated Ethylene Propylene (FEP) high voltage wire. This wire achieves high voltage protection due to the excellent dielectric properties of FEP and therefore has smaller diameters than other high voltage wires. FEP also has a high stress crack resistance and retains its toughness and flexibility even at higher temperatures up to 200°C. This wire is very resistant to chemicals including transformer oils. It has a low coefficient of friction, low flammability, negligible moisture absorption, and excellent resistance to ozone sunlight and weather. • High voltages - depending on AWG size up to 30 KV DC • High flexibility • Excellent resistance to chemicals • Small diameters • FEP Resins meet flammability requirements of UL94V-O This series is RoHS compliant. Description: Stranded silver plated soft copper conductors insulated with FEP. Operating Temperature: -65°C to +200°C Daburn Cat. No. AWG Nom. Wall Nom. O.D. IN MM IN MM KV DC Rating Stranding 2475/28 28 19/40 .0145” .368 .044” 1.118 18 2475/26 26 19/38 .0155" .394 .050" 1.270 20 2475/24 24 19/36 .013" .330 .050" 1.270 18 2475/22 22 19/34 .015" .381 .060" 1.524 20 2475/20A 20 19/32 .021" .533 .080" 2.032 25 2475/20B 20 19/32 .031" .787 .100" 2.540 30 2475/18 18 19/30 .041" 1.041 .130" 3.302 30 Standard Put-Ups: 1,000 feet, 500 feet, 250 feet. 100 feet if in stock only. Standard Colors: Clear or Natural, White, Black, Red, Green, Yellow, Blue, Brown, Orange, Gray, Violet. Tel: 973-328-3200 Fax: 973-328-3130 www.daburn.com Revision B
2475/20AGY-500
1. 物料型号:#2475 FEP高压电线。 2. 器件简介:FEP(氟化乙烯丙烯)高压电线,具有优异的介电性能,可实现高压保护,且直径比其他高压电线小。FEP具有高耐应力开裂性,即使在高达200°C的温度下也能保持其韧性和柔韧性。此外,它对化学品有很高的抵抗力,包括变压器油,具有低摩擦系数、低可燃性、几乎不吸水、以及对臭氧、阳光和天气的极好抵抗力。 3. 引脚分配:文档中没有提供引脚分配信息,因为它是关于电线的,而不是电子元件。 4. 参数特性: - 电压等级:根据AWG尺寸,可达到30KV直流。 - 高灵活性。 - 极好的化学抗性。 - 小直径。 - FEP树脂满足UL94V-0的可燃性要求。 - 符合RoHS标准。 5. 功能详解:文档描述了电线的构造,包括镀银软铜导体和FEP绝缘。 6. 应用信息:文档未明确列出应用信息,但根据其特性,这种电线适用于需要高电压保护和化学抗性的场合。 7. 封装信息:提供了电线的尺寸和额定电压,以及标准包装长度和颜色选项。
2475/20AGY-500 价格&库存
很抱歉,暂时无法提供与“2475/20AGY-500”相匹配的价格&库存,您可以联系我们找货
