PFM1203WH001
PFM1203WH001
    ALPHAWIRE(阿尔法电线)
    CABLE3COND12AWGWHITE1000'
PFM1203WH001 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. PFM1203 Construction Diameters (In) 1) Component 1 3 X 1 COND a) Conductor 12 (65/30) AWG TC 0.093 b) Insulation 0.032" Wall, Nom. PVC 0.157 (1) Color(s) Cond Color Cond Color Cond Color 1 BLACK 2 GREEN 3 WHITE 2) Cable Assembly 3 Components run parallel under jacket. 3) Jacket 0.035" Wall, Nom.,PVC 0.227X0.541 (0.237X0.555 Max.) a) Color(s) WHITE b) Print ALPHA WIRE-* 3C 12 AWG EXXXXX (UL) BOAT CABLE 105C DRY 75C WET BC-5W2 OIL RESISTANT I 600V VW-1 CE ROHS * = Factory Code Applicable Specifications 1) UL Boat Cable (BC-5W2) 105°C / 600 VRMS OIL RES I VW-1 2) CE: EU Low Voltage Directive 2006/95/EC Environmental 1) CE: EU Directive 2011/65/EU(RoHS2): This product complies with European Directive 2011/65/EU (RoHS Directive) of the European Parliament and of the Council of 8 June 2011. No Exemptions are required for RoHS Compliance on this item. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. 3) California Proposition 65: Properties The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Physical & Mechanical Properties 1) Temperature Range -20 to 105°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 153 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 600 VRMS 2) Capacitance 34 pf/ft @1 kHz, Nominal Conductor to Conductor 3) Inductance 0.18 µH/ft, Nominal 4) Conductor DCR 1.75 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 18 x 12 x 8 Continuous length b) 500 FT 12 x 12 x 3.5 Continuous length c) 250 FT 12 x 6 x 3.5 Continuous length d) 100 FT 12 x 4.5 x 3.5 Continuous length e) 50 FT 6.5 x 4 x 2.5 Continuous length f) Bulk(Made-to-order) [Spool dimensions may vary slightly] www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time.  By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE.  In the case of conflicting contractual provisions, this notice shall govern the status of this document.  ©2013 ALPHA WIRE - all rights reserved. EU/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: PFM1203 PFM1203 , RoHS-Compliant Commencing With 7/1/2005 Production This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope.  Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering & QA 5/15/2013
PFM1203WH001
物料型号:PFM1203
器件简介:Alpha Wire公司生产的船用电缆,型号PFM1203,符合UL标准,具有105°C/600V的额定温度和电压。
引脚分配:该电缆由3根导体组成,颜色分别为黑色、绿色和白色。
参数特性: - 导体规格:12(65/30) AWG TC,外径0.093英寸。 - 绝缘材料:0.032英寸壁厚,标称PVC,外径0.157英寸。 - 护套:0.035英寸壁厚,标称PVC,尺寸0.227×0.541英寸(最大0.237×0.555英寸)。 - 护套颜色:白色。 - 打印信息:包括Alpha Wire公司名称、产品型号、UL认证信息等。
功能详解: - 环境适应性:符合欧洲RoHS指令和REACH法规,不含高度关注物质(SVHC)。 - 物理和机械特性:工作温度范围-20至105°C,最小弯曲半径为电缆直径的10倍,最大拉力153磅。 - 电气特性:额定电压600VRMS,电容34 pf/ft(1kHz时),电感0.18 H/ft,导体直流电阻1.75 Q/1000ft(20°C时)。
应用信息:该电缆适用于船用环境,具有油阻和阻燃特性。
封装信息:提供多种包装尺寸,包括1000英尺、500英尺、250英尺、100英尺、50英尺的连续长度卷装,以及定制的散装包装。
PFM1203WH001 价格&库存
很抱歉,暂时无法提供与“PFM1203WH001”相匹配的价格&库存,您可以联系我们找货
