Daburn Electronics & Cable
44 Richboynton Road
Dover, NJ 07801
#2475 FEP High Voltage Wire
Fluorinated Ethylene Propylene (FEP) high voltage wire. This wire achieves high voltage protection due
to the excellent dielectric properties of FEP and therefore has smaller diameters than other high voltage
wires. FEP also has a high stress crack resistance and retains its toughness and flexibility even at higher
temperatures up to 200°C. This wire is very resistant to chemicals including transformer oils. It has a low
coefficient of friction, low flammability, negligible moisture absorption, and excellent resistance to ozone
sunlight and weather.
High voltages - depending on AWG size up to 30 KV DC
High flexibility
Excellent resistance to chemicals
Small diameters
FEP Resins meet flammability requirements of UL94V-O
This series is RoHS compliant.
Description: Stranded silver plated soft copper conductors insulated with FEP.
Operating Temperature: -65°C to +200°C
Daburn
Cat. No.
AWG
Nom. Wall
Nom. O.D.
IN
MM
IN
MM
KV DC
Rating
Stranding
2475/28
28
19/40
.0145”
.368
.044”
1.118
18
2475/26
26
19/38
.0155"
.394
.050"
1.270
24
19/36
.013"
.330
.050"
1.270
18
2475/22
22
19/34
.015"
.381
.060"
1.524
2475/20A
.021"
.533
.080"
2.032
25
2475/20B
.031"
.787
.100"
2.540
30
2475/18
18
19/30
.041"
1.041
.130"
3.302
30
Standard Put-Ups: 1,000 feet, 500 feet, 250 feet. 100 feet if in stock only.
Standard Colors: Clear or Natural, White, Black, Red, Green, Yellow, Blue, Brown, Orange, Gray, Violet.
Tel: 973-328-3200 Fax: 973-328-3130
www.daburn.com
Revision B
很抱歉,暂时无法提供与“2475/20BWH-1000”相匹配的价格&库存,您可以联系我们找货
