201619RD013
201619RD013
    ALPHAWIRE(阿尔法电线)
    HOOK-UPSTRND16AWGRED5000'
201619RD013 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. 201619 Construction Diameters (In) 1) Component 1 1 X 1 HOOKUP a) Conductor 16 (19/29) AWG TC 0.056 b) Insulation 0.0185" Wall, Nom. PVC 0.093+/- 0.002 (1) Color(s) WHITE, BLACK, RED, GREEN, YELLOW, BLUE, BROWN ORANGE, SLATE, VIOLET Applicable Specifications 1) UL VW-1 2) Military MIL-W-16878E Type C 105°C / 1000 VRMS Environmental 1) EU Directive 2002/95/EC(RoHS): All materials used in the manufacture of this part are in compliance with EU Directive 2002/95/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Consult Alpha Wire's web site for compliance Date of Manufacture. 2) California Proposition 65: The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Properties Physical & Mechanical Properties 1) Temperature Range -55 to 105°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 19.1 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 1000 VRMS 2) Inductance 0.05 µH/ft, Nominal 3) Conductor DCR 4.6 /1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 5000 FT 12 x 10 x 5 Continuous length b) 1000 FT 6.5 x 6 x 1.9 Continuous length c) 500 FT 6.5 x 4 x 2.5 Continuous length d) 100 FT 3.5 x 3 x 1.125 Continuous length e) Bulk(Made-to-order) [Spool dimensions may vary slightly] www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com RoHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number:201619 201619 , RoHS-Compliant Commencing With7/1/2005Production This document certifies that the Alpha part numbers cited above are manufactured in accordancewith Directive 2002/95/EC of the European Parliament and of the Council of 27 January 2003,better known as the RoHS Directives, with regards to restrictions of the use of certain hazardoussubstances used in the manufacture of electrical and electronic equipment. The reader is referredto these Directives for the specific definitions and extents of these Directives. No Exemptions arerequired for RoHS Compliance on this item. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm) Polybrominated Biphenyls (PBB) Polybrominated Diphenyl Ethers (PBDE) 0.1% by weight (1000 ppm) Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire'sknowledge, information and belief at the date of its release. The information provided is designedonly as a general guide for the safe handling, storage, and any other operation of the productitself or the one that it will become part of. The intent of this document is not to be considered awarranty or quality specification. Regulatory information is for guidance purposes only. Productusers are responsible for determining the applicability of legislation and regulations based ontheir individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering & QA 10/31/2012
201619RD013
物料型号:201619
器件简介:文档描述了Alpha Wire公司的一种线缆产品,包括其构造、适用规格、环境标准、物理和机械属性、电气属性以及包装信息。
引脚分配:文档中没有提及引脚分配,因为它是关于线缆而非电子元件。
参数特性: - 温度范围:-55至105°C - 弯曲半径:10倍线缆直径 - 拉力:最大19.1磅 - 电压等级:1000V RMS - 电感:0.05微亨/英尺(名义值) - 导体直流电阻:4.6欧姆/1000英尺@20°C(名义值)
功能详解:文档提供了线缆的物理和电气属性,以及符合的环保和军事标准。
应用信息:文档没有明确提供应用信息,但根据其属性,这种线缆可能适用于需要特定温度范围和电气特性的应用。
封装信息:文档提供了不同长度线缆的包装尺寸,包括5000英尺、1000英尺、500英尺和100英尺的连续长度包装。
201619RD013 价格&库存
很抱歉,暂时无法提供与“201619RD013”相匹配的价格&库存,您可以联系我们找货
