781816TYL013
781816TYL013
    ALPHAWIRE(阿尔法电线)
    HOOK-UPSTRND18AWGYELLOW5000'
781816TYL013 数据手册
Hook-Up Wire Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 377 Hook-Up Wire T he broad range of hook-up wire from Alpha means you will find the product exactly suited to your application—whether it’s as straightforward as a control cabinet in a protected environment or as specialized as a machine tool on the factory floor, a hightemperature oven, or off-road construction equipment. Our hook-up wire is available in a variety of insulations to meet your needs for temperature, ability to withstand wear and abrasion, electrical performance, or resistance to oil, solvents, and chemicals. • S  tranded and solid copper conductors, bare or tinned, with other platings available for special application needs • Broad range of insulations • Color-coded insulation for easy circuit identification • UL, CSA, and Mil-spec compliance • Convenient put-ups as short as 100 feet • Excellent uniformity and low-fray design for easy handling, stripping, and termination Choice of Insulations to Meet Temperature Range and Mechanical and Environmental Requirements Insulation Material Temperature Range Features PVC Polyvinyl chloride -55°C to +105°C General-purpose insulation Good abrasion resistance Excellent flame resistance XL-PVC Cross-linked PVC -55°C to +105°C Better abrasion and cut-through resistance than standard PVC Improved temperature and solder iron resistance over standard PVC Used in high-density wiring mPPE Modified polyphenylene ether -40°C to +105°C Excellent recyclability Excellent abrasion and cut-through resistance Superior dielectric properties for thinner walls than PVC—allows wires 45% smaller in diameter and 40% light in weight PTFE Polytetrafluoroethylene -55°C to +200°C High temperature Chemically inert: excellent chemical and solvent resistance Excellent electrical properties XLPE Cross-linked polyethylene -55°C to +125°C Higher temperature rating than PVC Silicone -40°C to +150°C High-voltage material Excellent flexibility Excellent dielectric strength and resistance to radiation, corona, and ozone PDVF Polyvinylidene fluoride -40°C to +125°C ETFE Ethylene tetrafluoroethylene -70°C to +150°C TGGT Teflon glass glass Teflon +250°C High-temperature applications Chemically inert: excellent chemical and solvent resistance Moisture resistant Withstands mechanical abuse and repeated flexing Mica glass +450°C High-temperature applications, such as heat-treating furnaces, kilns, and food service equipment Excellent thermal stability Silicone MG 378 Widely used in wire wrap applications Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Voltage Insulation Wire Range (AWG) Stranded Solid XL-PVC 26 – 16 — XLPE 22 – 18 — Approvals UL CSA Temperature Range UL/CSA AWM I A/B FT1 AWM 1429 150 300 600 -55°C to +80°C AWM 3265 I A/B FT1 -55°C to +125°C AWM 1569 -40°C to +105°C -40°C to +80°C PVC 30 – 16 24 – 16 AWM 1007 SR-PVC 30 – 16 — AWM 1061 XL-PVC 26 – 16 — XLPE 22 – 18 — XLPE 22 – 16 — AWM 3199 PTFE 24 – 8 — AWM 1180 24 – 10 26 – 10 AWM 1015, 1230 MTW, THW, TW PVC -55°C to +105°C TR-64 -40°C to +90°C I A/B FT1 -10°C to +80°C AWM 1430 REW XL-PVC -55°C to +105°C AWM 3266 CL 1252 XLPE -55°C to +125°C CL1054 -55°C to +125°C -60°C to +200°C TEW-105 -20°C to +105°C 8 – 4/0 — AWM 1242, 1284 mPPE 28 – 10 18 – 14 AWM 11028 I A/B FT-1 -40°C to +105°C -20°C to +105°C XLPE 18 – 10 — AWM 3271 CL 1251 XLPE -55°C to +125°C XLPE 20 – 2/0 — AWM 3173, 3195, 3196, 3300 SIS Rated -55°C to +125°C ETFE 24 – 4 — SAE AS22759/16 -55°C to +150°C PTFE 26 – 8 — SAE AS22759/11 Silicone 22 – 4/0 — AWM 3212, 3213, 3214 Silicone 22 – 2 — AWM 3239 PTFE 32 – 22 30 – 26 MIL-DTL-16878/6 (Type ET) -60°C to +200°C XL-PVC 26 – 16 — MIL-DTL-16878/1 (Type B) -55°C to +105°C PVC 32 – 14 — MIL-DTL-16878/1 (Type B) -55°C to +105°C PVC 14 – 8 — MIL-W-76 Type HW -20°C to +80°C PTFE 30 – 10 26 – 18 MIL-DTL-16878/4 (Type E) -60°C to +200°C PVC 24 – 12 24 – 18 MIL-DTL-16878/2 (Type C) -40°C to +80°C XLPE 22 – 18 — MIL-DTL-16878/2 (Type C) -55°C to +105°C PTFE 24 – 8 — MIL-DTL-16878/5 (Type EE) -60°C to +200°C XLPE 18 – 10 — MIL-DTL-16878/1 (Type D) -55°C to +105°C 1000/2000 XLPE/PVC 14 – 2 — UL 4703 PV Wire RW-90 -40°C to +90°C 600/1000 LSZH/LSZH 14 – 2 — UL 4703 PV Wire TÜV 2 PFG 1169 — -40°C to +90°C PVDF — 30 – 24 AWM 1422, 1423 -40°C to +125°C ETFE — 30 – 24 AWM 1516, 1523 -70°C to +150°C 10,000+ -55°C to +200°C AWM I A/B -40°C to +150°C -40°C to +150°C Military 250 600 1000 3000 Solar Wire Wrap Ribbon Cable: 5 to 30 Conductors 150/300 PVC 26 – 22 — AWM 2713, 2555 -55°C to +80°C 600/1000 PVC 26 – 22 — MIL-DTL-16878/1 and /2 (Types B & C) -55°C to +105°C Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 379 Wire > Hook-Up Wire > 300 V Hook-Up Wire 300 V, PVC 3047 3048 3049 3050/1 AWG 30 28 26 24 mm2 0.06 0.09 0.14 0.20 AWG 7/38 7/36 7/34 Solid mm 7 x 0.10 7 x 0.13 7 x 0.16 1 x 0.51 Insulation Thickness Inch mm 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 3050 24 0.23 7/32 7 x 0.20 0.016 0.41 0.056 1.42 892407T† 892419† 3051/1 24 24 22 0.23 0.24 0.32 7/32 19/36 Solid 7 x 0.20 19 x 0.13 1 x 0.64 0.016 0.016 0.016 0.41 0.41 0.41 0.056 0.057 0.057 1.42 1.45 1.45 Part No. UL AWM 1007, 1581, 1569 VW-1 CSA AWM I A/B FT1 CSA TR-64 FT1 Operating Temperature • -40°C to +105°C (AWM 1569, CSA AWM) • -40°C to +90°C (CSA TR-64) • -40°C to +80°C (AWM 1007, 1581) Materials • Stranded or solid tinned copper conductor • PVC insulation Availability 100 ft (30.5 m) 1000 ft (305 m) Wire Size Stranding Nominal Diameter Inch mm 0.044 1.12 0.047 1.19 0.051 1.30 0.052 1.32 3051 22 0.35 7/30 7 x 0.25 0.016 0.41 0.062 1.57 892207T† 892219† 22 22 0.35 0.38 7/30 19/34 7 x 0.25 19 x 0.16 0.016 0.016 0.41 0.41 0.062 0.064 1.57 1.63 3053 20 0.51 10/30 10 x 0.25 0.016 0.41 0.069 1.75 892010T† 3053/1 892007† 892019† 20 20 20 20 0.51 0.52 0.56 0.62 10/30 Solid 7/28 19/32 10 x 0.25 1 x 0.81 7 x 0.32 19 x 0.20 0.016 0.016 0.016 0.016 0.41 0.41 0.41 0.41 0.069 0.064 0.070 0.072 1.75 1.63 1.78 1.83 3055 18 0.81 16/30 16 x 0.25 0.016 0.41 0.079 2.01 891816T† 3055/1 891819† 3057/1 18 18 18 16 0.81 0.82 0.96 1.31 16/30 Solid 19/30 Solid 16 x 0.25 1 x 1.02 19 x 0.25 1 x 1.29 0.016 0.016 0.016 0.016 0.41 0.41 0.41 0.41 0.079 0.072 0.082 0.083 2.01 1.83 2.08 2.11 3057 16 1.32 26/30 26 x 0.25 0.016 0.41 0.092 2.34 891441† 891265*† 891000*† 14 12 10 2.08 3.30 5.32 41/30 41 x 0.25 65/30 65 x 0.25 105/30 105 x 0.25 0.016 0.016 0.016 0.41 0.41 0.41 0.106 0.125 0.150 2.69 3.18 3.81 Colors Z1, 1 - 10 Z1, 1 - 10 Z1, 1 - 10 Z1, 1 - 10 Z1, 1 – 19, 28, 30 Z2, 0 - 9 Z2, 0 - 9 Z1, 1 - 10 Z1, 1 – 19, 28, 30 Z2, 0 - 9 Z2, 0 - 9 Z1, 1 – 19, 28, 30 Z2, 0 - 9 Z1, 1 - 10 Z2, 0 - 9 Z2, 0 - 9 Z1, 1 – 19, 28, 30 Z2, 0 - 9 Z1, 1 - 10 Z2, 0 - 9 Z1, 1 - 10 Z1, 1 – 19, 28, 30 Z2, 0 - 9 Z2, 0 - 9 Z2, 0 - 9 *UL AWM 1581 and 1569. All others UL AWM 1007 and 1569. †CSA AWM I A/B FT-1. “T” indicates topcoat conductors. Insulation Colors Z1 1 White 5 Yellow 9 Slate 13 White/Green 2 Black 6 Blue 10 Violet 14 White/Yellow 3 Red 7 Brown 11 White/Black 15 White/Blue 4 Green 8 Orange 12 White/Red 16 White/Brown 17 White/ Orange 18 White/ Slate 19 White/ Violet 28 Green/ Yellow 29 Yellow/Green 30 Pink Insulation Colors Z2 0 Black 1 Brown 2 Red 3 Orange 4 Yellow 5 Green 6 Blue 7 Violet 8 Slate 9 White These wires also available in 500 ft (152 m) put-ups. 380 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 300 V Hook-Up Wire 300 V, Semirigid PVC Part No. UL AWM 1061 VW-1 CSA AWM I A/B FT1 Operating Temperature • -10°C to +80°C Materials • Stranded or solid tinned copper conductor • Semirigid PVC insulation Availability 100 ft (30.5 m) 1000 ft (305 m) 422807 422801 422607 422601 3250 3251 422010 3252 422001 421816 3253 421626 3254 Wire Size AWG 28 28 26 26 24 22 20 20 20 18 18 16 16 mm2 0.09 0.08 0.14 0.13 0.23 0.35 0.51 0.56 0.52 0.81 0.90 1.32 1.43 Stranding AWG 7/36 Solid 7/34 Solid 7/32 7/30 10/30 7/28 Solid 16/30 7/26 26/30 7/24 mm 7 x 0.13 1 x 0.32 7 x 0.16 1 x 0.40 7 x 0.20 7 x 0.25 10 x 0.25 7 x 0.32 1 x 0.81 16 x 0.25 7 x 0.40 26 x 0.25 7 x 0.51 Insulation Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 Nominal Diameter Inch mm 0.035 0.89 0.033 0.84 0.039 0.99 0.036 0.91 0.044 1.12 0.050 1.27 0.057 1.45 0.058 1.47 0.052 1.32 0.067 1.70 0.068 1.73 0.080 2.03 0.080 2.03 Colors Z2 Z2 Z2 Z2 Z1 Z1 Z2 Z1 Z2 Z2 Z1 Z2 Z1 Insulation Colors Z1 1 White 2 Black 3 Red 4 Green 5 Yellow 6 Blue 7 Brown 8 Orange 9 Slate 10 Violet Insulation Colors Z2 0 Black 1 Brown 2 Red 3 Orange 4 Yellow 5 Green 6 Blue 7 Violet 8 Slate 9 White These wires also available in 500 ft (152 m) put-ups. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 381 Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, PVC Part No. UL AWM 1015, 1028, 1230, 1231, 1232, 1283, 1284 VW-1 UL MTW, TW (14 to 8 AWG), THW (6 to 1/0 AWG) CSA AWM I A/B FT1 and TEW-105 Operating Temperature • -40°C to +105°C (AWM, TEW) • -40°C to +90°C (MTW) • -40°C to +75°C (THW) • -40°C to +60°C (TW) Materials • Stranded bare copper conductor • PVC insulation Availability 100 ft (30.5 m) 1000 ft (305 m) 382 Wire Size Stranding Insulation Thickness Inch mm Nominal Diameter Inch mm AWG mm 2 AWG mm 461816 18 0.81 16/30 16 x 0.25 0.032 0.81 0.111 2.82 461626 16 1.32 26/30 26 x 0.25 0.032 0.81 0.124 3.15 461419 14 2.07 19/0.0147 19 x 0.37 0.032 0.81 0.138 3.51 461219 12 3.29 19/0.0185 19 x 0.47 0.032 0.81 0.157 3.99 461265 12 3.29 65/0.010 65 x 0.25 0.031 0.79 0.153 3.89 461019 10 5.26 19/0.0234 19 x 0.59 0.032 0.81 0.181 4.60 460819 8 8.38 19/0.0295 19 x 0.75 0.047 1.19 0.242 6.15 460619 6 13.32 19/0.0372 19 x 0.94 0.063 1.59 0.311 7.90 460419 4 21.09 19/0.0469 19 x 1.19 0.063 1.59 0.360 9.14 460219 2 33.63 19/0.0591 19 x 1.50 0.063 1.59 0.421 10.69 460001 1/0 53.39 19/0.0745 19 x 1.89 0.078 1.98 0.529 13.44 UL Style 1015, 1230 1015, 1230 1015, 1230 1015, 1230 1015, 1230 1015, 1230 1028, 1231 1283, 1232 1283, 1232 1283, 1232 1284, 1232 Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, PVC Part No. 782607* 782401* 3070* 782201 782207T 3071 782010T 3073 782001 781816T 3075 781801 781601 3077 781401 3079 3080 781201 781001 3081 788133 786133 784133 782665 782133 781259 781836 780001 780002 780003 780004 Wire Size AWG 26 24 24 22 22 22 20 20 20 18 18 18 16 16 14 14 12 12 10 10 8 6 4 2 2 1 1 1/0 2/0 3/0 4/0 mm2 0.14 0.20 0.23 0.32 0.35 0.35 0.51 0.51 0.52 0.81 0.81 0.82 1.31 1.32 2.08 2.08 3.29 3.31 5.26 5.32 8.61 13.57 21.55 33.72 34.45 41.96 42.39 52.98 67.43 84.47 106.93 T indicates top coat conductors. *Not MTW UL AWM 1015, 1028, 1230, 1231, 1232, 1283, 1284 VW-1 UL MTW (22 to 4/0 AWG) UL THW (6 to 1/0 AWG) CSA AWM I A/B FT1 and TEW 105 • -20°C to +75°C (THW) • -20°C to +60°C (TW) Operating Temperature • -20°C to +105°C (AWM, TEW) • -20°C to +90°C (MTW) Availability 100 ft (30.5 m) 1000 ft (305 m) Insulation Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.082 2.08 0.082 2.08 0.082 2.08 0.082 2.08 0.082 2.08 0.082 2.08 Stranding AWG 7/34 Solid 7/32 Solid 7/30 7/30 10/30 10/30 Solid 16/30 16/30 Solid Solid 26/30 Solid 41/30 65/30 Solid Solid 105/30 133/29 133/27 133/25 665/30 133/23 259/25 836/30 1045/30 1330/30 1666/30 2109/30 mm 7 x 0.16 1 x 0.51 7 x 0.20 1 x 0.64 7 x 0.25 7 x 0.25 10 x 0.25 10 x 0.25 1 x 0.81 16 x 0.25 16 x 0.25 1 x 1.02 1 x 1.29 26 x 0.25 1 x 1.63 41 x 0.25 65 x 0.25 1 x 2.06 1 x 2.59 105 x 0.25 133 x 0.29 133 x 0.36 133 x 0.45 665 x 0.25 133 x 0.57 259 x 0.45 836 x 0.25 1045 x 0.25 1330 x 0.25 1666 x 0.25 2109 x 0.25 Nominal Diameter Inch mm 0.083 2.11 0.084 2.13 0.088 2.24 0.089 2.26 0.094 2.39 0.094 2.39 0.101 2.57 0.101 2.57 0.096 2.44 0.111 2.82 0.111 2.82 0.104 2.64 0.115 2.92 0.124 3.15 0.128 3.25 0.138 3.51 0.157 3.99 0.145 3.68 0.166 4.22 0.184 4.67 0.263 6.68 0.336 8.53 0.395 10.03 0.461 11.71 0.465 11.81 0.540 13.72 0.547 13.89 0.592 15.04 0.647 16.43 0.768 19.51 0.754 19.15 5 Yellow 6 Blue 7 Brown 8 Orange UL Style Colors 1015, 1230 1015, 1230 1015 1015, 1230 1015, 1230 1015 1015, 1230 1015 1015, 1230 1015, 1230 1015 1015, 1230 1015, 1230 1015 1015, 1230 1015 1015 1015, 1230 1015, 1230 1015 1028, 1231 1283, 1232 1283, 1232 1283, 1232 1283, 1232 1284, 1232 1284, 1232 1284, 1232 1284, 1232 1284, 1232 1284, 1232 Z2, 0 - 9 Z2, 0 - 9 Z1, 1 - 10, 28 Z2, 0 - 9 Z2, 0 - 9 Z1, 1 - 10, 28, 29 Z2, 0 - 9 Z1, 1 - 10, 28 Z2, 0 - 9 Z2, 0 - 9 Z1, 1 - 10, 28, 29 Z2, 0 - 9 Z2, 0 - 9 Z1, 1 - 10, 28, 29 Z2, 0 - 9 Z1, 1 - 10, 28, 29 Z1, 1 - 4 Z2, 0 - 9 Z2, 0 - 9 Z1, 1 - 4 Z2, 0 - 9 Z2, 0 - 9 Z2, 0 - 9 Z2, 0 - 9 Z2, 0 - 9 Z2, 0 - 9 Z2, 0 - 9 Z2, 0 - 9 Z2, 0 - 9 Z2, 0 - 9 Z2, 0 - 9 Insulation Colors Z2 Insulation Colors Z1 1 White 2 Black 3 Red 4 Green Materials • Stranded or solid tinned copper conductor • PVC insulation 9 Slate 10 Violet 28 Green/Yellow 29 Yellow/Green 0 Black 1 Brown 2 Red 3 Orange 4 Yellow 5 Green 6 Blue 7 Violet 8 Slate 9 White These wires also available in 500 ft (152 m) put-ups. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 383 Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, PVC Part No. MIL-DTL-16878/1 (Type B) MIL-W-76 Type LW Operating Temperature • -55°C to +105°C Materials • Stranded or solid tinned copper conductor • PVC insulation Availability 100 ft (30.5 m) 1000 ft (305 m) 1850 1851* 1852* 1853* 172619 1854* 1854/19 1855 1855/19 1856* 1856/19 1857 1857/19 1858/19 1859/19 Wire Size AWG 32 30 28 26 26 24 24 22 22 20 20 18 18 16 14 Stranding AWG 7/40 7/38 7/36 7/34 19/38 7/32 19/36 7/30 19/34 7/28 19/32 7/26 19/30 19/29 19/27 mm2 0.03 0.06 0.09 0.14 0.15 0.23 0.24 0.35 0.38 0.56 0.62 0.90 0.96 1.23 1.94 mm 7 x 0.08 7 x 0.10 7 x 0.12 7 x 0.16 19 x 0.10 7 x 0.20 19 x 0.13 7 x 0.25 19 x 0.16 7 x 0.32 19 x 0.20 7 x 0.40 19 x 0.25 19 x 0.29 19 x 0.36 Insulation Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 Nominal Diameter Inch mm 0.029 0.74 0.032 0.81 0.035 0.89 0.039 0.99 0.040 1.02 0.044 1.12 0.045 1.14 0.050 1.27 0.052 1.32 0.058 1.47 0.060 1.52 0.068 1.73 0.070 1.78 0.076 1.93 0.091 2.31 Colors Z1, 1 - 6 Z1, 1 - 6 Z1, 1 - 10 Z1, 1 - 19 Z2, 0 - 9 Z1, 1 - 19 Z1, 1 - 19 Z1, 1 - 19 Z1, 1 - 19 Z1, 1 - 19 Z1, 1 - 19 Z1, 1 - 19 Z1, 1 - 19 Z1, 1 - 19 Z1, 1 - 10 *Also meets MIL-W-76 Type LW. Insulation Colors Z1 1 White 2 Black 3 Red 4 Green 5 Yellow 6 Blue 7 Brown 8 Orange 9 Slate 10 Violet 11 White/Black 12 White/Red 13 White/Green 14 White/Yellow 15 White/Blue 16 White/Brown 17 White/Orange 18 White/Slate 19 White/Violet Insulation Colors Z2 0 Black 1 Brown 2 Red 3 Orange 384 4 Yellow 5 Green 6 Blue 7 Violet 8 Slate 9 White Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, PVC Part No. 1579 1651 1653 1655 MIL-W-76 Type HW Operating Temperature • -20°C to +80°C Wire Size AWG mm2 14 2.08 12 3.29 10 5.32 8 8.61 Stranding AWG mm 41/30 41 x 0.25 65/30 65 x 0.25 105/30 105 x 0.25 133/29 133 x 0.28 Insulation Thickness Inch mm 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 Nominal Diameter Inch mm 0.164 4.17 0.183 4.65 0.210 5.33 0.259 6.58 Insulation Colors White Black Red Materials • Stranded tinned copper conductor • PVC insulation Availability 100 ft (30.5 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 385 Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, PVC Part No. MIL-DTL-16878/2 (Type C) UL VW-1 Operating Temperature • -55°C to +105°C Materials • Stranded tinned copper conductor • PVC insulation 202207 202007 201807 201819 201619 201419 201219 Wire Size AWG 22 20 18 18 16 14 12 mm2 0.35 0.56 0.90 0.96 1.23 1.94 3.08 Stranding AWG 7/30 7/28 7/26 19/30 19/29 19/27 19/25 mm 7 x 0.25 7 x 0.32 7 x 0.40 19 x 0.25 19 x 0.29 19 x 0.36 19 x 0.45 Insulation Thickness Inch 0.017 0.017 0.017 0.017 0.019 0.019 0.019 mm 0.43 0.43 0.43 0.43 0.47 0.47 0.47 Nominal Diameter Inch 0.064 0.072 0.082 0.084 0.093 0.108 0.127 mm 1.63 1.83 2.08 2.13 2.36 2.74 3.23 Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Availability 100 ft (30.5 m) 1000 ft (305 m) 386 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, PVC/Nylon Part No. UL THHN, THWN, TFN, TFFN Operating Temperature • -40°C to +90°C (THHN, TFN, TFFN) • -40°C to +75°C (THWN) Materials • Stranded or solid bare copper conductor • PVC/nylon insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Wire Size Stranding PVC Insulation Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 Nominal Diameter Inch mm 0.086 2.18 0.079 2.01 0.099 2.51 541816 541801 541626 AWG 18 18 16 mm 0.81 0.82 1.32 AWG 16/30 Solid 26/30 mm 16 x 0.25 1 x 1.02 26 x 0.25 541419 14 2.07 19/0.0147 19 x 0.37 0.015 0.38 0.113 2.87 541401 14 2.08 Solid 1 x 1.63 0.015 0.38 0.103 2.62 541219 12 3.29 19/0.0185 19 x 0.47 0.015 0.38 0.132 3.35 541201 12 3.31 Solid 1 x 2.06 0.015 0.38 0.120 3.05 541019 10 5.26 19/0.0234 19 x 0.59 0.020 0.51 0.166 4.22 541001 10 5.26 Solid 1 x 2.59 0.020 0.51 0.141 3.58 540819 8 8.38 19/0.0295 19 x 0.75 0.030 0.76 0.219 5.56 540619 6 13.32 19/0.0372 19 x 0.94 0.030 0.76 0.257 6.53 540419 4 21.09 19/0.0469 19 x 1.19 0.040 1.02 0.329 8.36 540219 2 33.63 19/0.0591 19 x 1.50 0.040 1.02 0.390 9.91 540001 1/0 53.39 19/0.0745 19 x 1.89 0.050 1.27 0.488 12.40 2 UL Type TFFN TFN TFFN THHN, THWN THHN, THWN THHN, THWN THHN, THWN THHN, THWN THHN, THWN THHN, THWN THHN, THWN THHN, THWN THHN, THWN THHN, THWN Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 387 Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, PVC/Nylon Part No. MIL-DTL-16878/17 (Type B/N) Operating Temperature • -55°C to +105°C Materials • Stranded tinned copper conductor • PVC/nylon insulation 182607 182407 182419 182219 182019 181807 181819 181619 181419 Wire Size AWG 26 24 24 22 20 18 18 16 14 Stranding mm2 0.14 0.23 0.24 0.38 0.62 0.90 0.96 1.23 1.94 AWG 7/34 7/32 19/36 19/34 19/32 7/26 19/30 19/29 19/27 mm 7 x 0.16 7 x 0.20 19 x 0.13 19 x 0.16 19 x 0.20 7 x 0.40 19 x 0.25 19 x 0.29 19 x 0.36 PVC Insulation Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 Nominal Diameter Inch mm 0.045 1.14 0.050 1.27 0.051 1.30 0.058 1.47 0.066 1.68 0.074 1.88 0.076 1.93 0.082 2.08 0.097 2.46 Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length 388 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 1000 V Hook-Up Wire 1000 V, PVC Part No. MIL-W-76 Type MWP Operating Temperature • -55°C to +90°C Materials • Stranded or solid tinned copper conductor • PVC insulation 302407 302207 302201 302010 301816 301626 301619 301441 Wire Size AWG 24 22 22 20 18 16 16 14 mm2 0.23 0.35 0.32 0.51 0.81 1.32 1.23 2.08 Stranding AWG 7/32 7/30 Solid 10/30 16/30 26/30 19/29 41/30 mm 7 x 0.20 7 x 0.25 1 x 0.64 10 x 0.25 16 x 0.25 26 x 0.25 19 x 0.29 41 x 0.25 Insulation Thickness Inch mm 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 Nominal Diameter Inch mm 0.056 1.42 0.064 1.63 0.057 1.45 0.069 1.75 0.079 2.01 0.092 2.34 0.088 2.24 0.106 2.69 Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Availability 100 ft (30.5 m) 1000 ft (305 m) Bulk, cut to length Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 389 Wire > Hook-Up Wire > 1000 V Hook-Up Wire 1000 V, PVC Part No. MIL-W-76 B Type MW Operating Temperature • -40°C to +80°C Materials • Stranded or solid tinned copper conductor • PVC insulation Availability 100 ft (30.5 m) 1000 ft (305 m) 390 1550 1561/24 1551 1561 1553 1563 1555 1565 1557 1559 1560 Wire Size AWG 24 24 22 22 20 20 18 18 16 14 12 Stranding AWG 7/32 Solid 7/30 Solid 10/30 Solid 16/30 Solid 26/30 41/30 65/30 mm2 0.23 0.20 0.35 0.32 0.51 0.52 0.81 0.82 1.32 2.08 3.29 mm 7 x 0.20 1 x 0.51 7 x 0.25 1 x 0.64 10 x 0.25 1 x 0.81 16 x 0.25 1 x 1.02 26 x 0.25 41 x 0.25 65 x 0.25 Insulation Thickness Inch mm 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 Nominal Diameter Inch mm 0.056 1.42 0.052 1.32 0.062 1.57 0.057 1.45 0.069 1.75 0.064 1.63 0.079 2.01 0.072 1.83 0.092 2.34 0.106 2.69 0.125 3.18 Colors* 1 - 19 1-6 1 - 19 1-6 1 - 19 1-6 1 - 19 1-6 1 - 19 1 – 10 1 - 10 Insulation Colors 1 White 5 Yellow 9 Slate 2 Black 6 Blue 10 Violet 13 White/ Green 14 White/ Yellow 3 Red 7 Brown 11 White/ Black 15 White/Blue 4 Green 8 Orange 12 White/Red 16 White/ Brown 17 White/ Orange 18 White/ Slate 19 White/ Violet Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 600/150 V Hook-Up Wire 600/150 V, Irradiated PVC Soldering Iron Resistant Part No. MIL-DTL-16878/1 (Type B) (600 V) UL AWM 1429 (150 V) CSA AWM I A/B FT1 (150 V) Operating Temperature • -55°C to +105°C (MIL) • -55°C to +80°C (AWM, CSA) Materials • Stranded tinned copper conductor • Irradiated PVC insulation 7053 7054 7054/19 7055 7055/19 7056 7056/19 7057 7057/19 7058/19 Wire Size AWG 26 24 24 22 22 20 20 18 18 16 mm2 0.14 0.23 0.24 0.35 0.38 0.56 0.62 0.90 0.96 1.32 Stranding AWG 7/34 7/32 19/36 7/30 19/34 7/28 19/32 7/26 19/30 19/0.0117 mm 7 x 0.16 7 x 0.20 19 x 0.13 7 x 0.25 19 x 0.16 7 x 0.32 19 x 0.20 7 x 0.40 19 x 0.25 19 x 0.30 Insulation Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 Nominal Diameter Inch mm 0.039 0.99 0.044 1.12 0.045 1.14 0.050 1.27 0.052 1.32 0.058 1.47 0.060 1.52 0.068 1.73 0.070 1.78 0.076 1.93 Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Availability 100 ft (30.5 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 391 Wire > Hook-Up Wire > 1000/300 V Hook-Up Wire 1000/300 V, Irradiated PVC Soldering Iron Resistant Part No. MIL-DTL-16878/2 (Type C) (1000 V) UL AWM 1430 (300 V) CSA REW XLPVC FT1 (300 V) Operating Temperature • -55°C to +105°C Materials • Stranded tinned copper conductor • Irradiated PVC insulation 7130 7131 7132 7133 7134 7035* 7036* Wire Size AWG 24 22 20 18 16 14 12 mm2 0.23 0.35 0.56 0.89 1.32 2.07 3.29 Stranding AWG 7/32 7/30 7/ 28 7/26 19/0.0117 19/0.0147 19/0.0185 mm 7 x 0.20 7 x 0.25 7 x 0.32 7 x 0.40 19 x 0.30 19 x 0.37 19 x 0.47 Insulation Thickness Inch mm 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 Nominal Diameter Inch mm 0.056 1.42 0.062 1.57 0.070 1.78 0.080 2.03 0.088 2.24 0.103 2.62 0.122 3.10 Colors 1 – 10, 29 1 – 10 1 – 10 1 – 10, 29 1 – 10, 29 1 – 10, 29 1 – 10, 29 *UL AWM 3317 Insulation Colors 1 White 2 Black 3 Red 4 Green 5 Yellow 6 Blue 7 Brown 8 Orange 9 Slate 10 Violet 29 Yellow/Green Availability 100 ft (30.5 m) 1000 ft (305 m) 392 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire Hook-Up Wire 3000/600 V, XLPE Part No. 7044 7045 7046 7047 7048 MIL-DTL-16878/4 (Type D) (3000 V) UL AWM 3271 (600 V) VW-1 CSA CL 1251 XLPE (600 V) Wire Size AWG 18 16 14 12 10 mm2 0.81 1.32 2.08 3.29 5.32 Stranding AWG 16/30 26/30 41/30 65/30 105/30 mm 16 x 0.25 26 x 0.25 41 x 0.25 65 x 0.25 105 x 0.25 Insulation Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Nominal Diameter Inch mm 0.111 2.82 0.119 3.02 0.138 3.51 0.155 3.94 0.184 4.67 Insulation Colors White Black Red Operating Temperature • -55°C to +105°C (MIL) • -55°C to +125°C (UL, CSA) Materials • Stranded tinned copper conductor • Cross-linked polyolefin insulation Availability 100 ft (30.5 m) 1000 ft (305 m) 1000/300 V, XLPE MIL-DTL-16878/2 (Type C) (1000 V) UL AWM 3266 (300 V) VW-1 CSA CL 1252 XLPE (300 V) Operating Temperature • -55°C to +105°C (MIL) • -55°C to +125°C (UL, CSA) Part No. 7024 7025 7026 Wire Size AWG 22 20 18 mm2 0.38 0.62 0.96 Stranding AWG 19/34 19/32 19/30 mm 19 x 0.16 19 x 0.20 19 x 0.25 Insulation Thickness Inch mm 0.016 0.41 0.016 0.41 0.016 0.41 Nominal Diameter Inch mm 0.064 1.63 0.072 1.83 0.080 2.03 Insulation Colors White Black Red Materials • Stranded tinned copper conductor • Cross-linked polyolefin insulation Availability 100 ft (30.5 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 393 Wire > Hook-Up Wire Hook-Up Wire 600/150 V, XLPE Part No. 7012 7013 7014 MIL-DTL-16878/1 (Type B) (600 V) UL AWM 3265 (150 V) VW-1 CSA AWM I A/B FT1 (150 V) Wire Size AWG 22 20 18 mm2 0.38 0.62 0.96 Stranding AWG 19/34 19/32 19/30 mm 19 x 0.16 19 x 0.20 19 x 0.25 Insulation Thickness Inch mm 0.011 0.28 0.011 0.28 0.011 0.28 Nominal Diameter Inch mm 0.054 1.37 0.06 1.52 0.070 1.78 Insulation Colors White Black Operating Temperature • -55°C to +105°C (MIL) • -55°C to +125°C (UL, CSA) Materials • Stranded tinned copper conductor • Cross-linked polyolefin insulation Availability 100 ft (30.5 m) 1000 ft (305 m) 394 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, XLPE UL AWM 3173, 3195, 3196 UL SIS CSA AWM I A/B CSA CL 1251 XLPE Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Operating Temperature • -20°C to +125°C Materials • Stranded or solid tinned copper conductor • Slate cross-linked polyethylene insulation Part No. M4030 M4010 M4001 M4011 M4002 M4012 M4003 M4013 M4004 M4014 M4005 M4035 M4015 M4036 M4016 M4037 Wire Size AWG mm2 18 0.81 18 0.90 18 0.82 16 1.43 16 1.31 14 2.29 14 2.08 12 3.29 12 3.31 10 5.28 10 5.26 8 8.63 8 8.38 6 13.6 6 13.3 4 21.6 Stranding AWG mm 16/30 16 x 0.25 7/26 7 x 0.48 Solid 1 x 1.02 7/24 7 x 0.51 Solid 1 x 1.29 7/22 7 x 0.64 Solid 1 x 1.63 19/0.0185 19 x 0.47 Solid 1 x 2.06 19/0.0234 19 x 0.59 Solid 1 x 2.59 133/29 133 x 0.29 19/0.0295 19 x 0.75 133/27 133 x 0.36 19/0.0372 19 x 0.94 133/25 133 x 0.45 Insulation Thickness Inch mm 0.031 0.79 0.031 0.79 0.031 0.79 0.031 0.79 0.031 0.79 0.031 0.79 0.031 0.79 0.031 0.79 0.031 0.79 0.031 0.79 0.031 0.79 0.047 1.19 0.047 1.19 0.062 1.57 0.062 1.57 0.062 1.57 Nominal Diameter Inch mm 0.110 2.79 0.112 2.84 0.105 2.67 0.123 3.12 0.115 2.92 0.140 3.56 0.130 3.30 0.160 4.06 0.150 3.81 0.180 4.57 0.170 4.32 0.270 6.86 0.250 6.35 0.340 8.64 0.320 8.13 0.400 10.16 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. UL Style 3173 3173 3173 3173 3173 SIS, 3173 SIS, 3173 SIS, 3173 SIS, 3173 SIS, 3173 SIS, 3173 SIS, 3195 SIS, 3195 SIS, 3196 SIS, 3196 SIS, 3196 395 Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, XLPE Part No. UL AWM 3173 UL SIS CSA AWM I A/B FT2 CSA CL1251 XLPE Operating Temperature • -40°C to +125°C (AWM) • -40°C to +150°C (CSA CL) • -40°C to +90°C (SIS) 752010 751816 751626 751441* 751265* 751000* 758133** Wire Size AWG 20 18 16 14 12 10 8 Stranding mm2 0.51 0.81 1.32 2.08 3.29 5.32 8.63 AWG 10/30 16/30 26/30 41/30 65/30 105/30 133/29 mm 10 x 0.25 16 x 0.25 26 x 0.25 41 x 0.25 65 x 0.25 105 x 0.25 133 x 0.29 Insulation Thickness Inch mm 0.031 0.79 0.031 0.79 0.031 0.79 0.031 0.79 0.031 0.79 0.031 0.79 0.047 1.19 Nominal Diameter Inch mm 0.099 2.51 0.109 2.77 0.122 3.10 0.136 3.45 0.155 3.94 0.180 4.57 0.263 6.68 *UL SIS. **UL AWM 3195 only. Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Materials • Stranded tinned copper conductor • Cross-linked polyethylene insulation Availability 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length 396 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 50 V Hook-Up Wire 50 V, XLPE Part No. 631816 631619 631419 SAE J1128 Type GXL Operating Temperature • -40°C to +125°C Wire Size AWG 18 16 14 mm2 0.81 1.23 1.94 Stranding AWG 16/30 19/29 19/27 mm 16 x 0.25 19 x 0.29 19 x 0.36 Insulation Thickness Inch mm 0.023 0.58 0.023 0.58 0.023 0.58 Nominal Diameter Inch mm 0.093 2.36 0.102 2.59 0.113 2.87 Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Materials • Stranded bare copper conductor • Cross-linked polyethylene insulation Availability 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 397 Wire > Hook-Up Wire > 250 V Hook-Up Wire 250 V, PTFE Operating Temperature • -60°C to +200°C Materials • Stranded or solid silver-plated copper conductor • PTFE insulation MIL-DTL-16878/6 (Type ET) UL VW-1 NEMA HP3 Wire Size Part No. AWG 32 32 32 30 30 28 28 28 26 26 26 24 24 22 22 20 20 33201 33219 2840/7 2841/7 2841/1 2842/7 2842/19 2842/1 2843/7 2843/19 2843/1 2844/7 2844/19 2845/7 2845/19 32007 32019 mm2 0.03 0.04 0.03 0.06 0.05 0.09 0.09 0.08 0.14 0.15 0.13 0.23 0.24 0.35 0.38 0.56 0.62 5 Yellow 6 Blue 7 Brown 8 Orange *May contain multiple lengths Stranding AWG Solid 19/44 7/40 7/38 Solid 7/36 19/40 Solid 7/34 19/38 Solid 7/32 19/36 7/30 19/34 7/28 19/32 Insulation Thickness mm 1 x 0.20 19 x 0.05 7 x 0.08 7 x 0.10 1 x 0.25 7 x 0.12 19 x 0.08 1 x 0.32 7 x 0.16 19 x 0.10 1 x 0.40 7 x 0.20 19 x 0.13 7 x 0.25 19 x 0.16 7 x 0.32 19 x 0.20 Inch 0.006 0.006 0.006 0.006 0.006 0.006 0.006 0.006 0.006 0.006 0.006 0.006 0.006 0.006 0.005 0.006 0.006 mm 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.13 0.15 0.15 Nominal Diameter Inch mm 0.019 0.48 0.022 0.56 0.022 0.56 0.024 0.61 0.022 0.56 0.027 0.69 0.027 0.69 0.025 0.64 0.031 0.79 0.031 0.79 0.028 0.71 0.036 0.91 0.036 0.91 0.042 1.07 0.042 1.07 0.050 1.27 0.052 1.32 NEMA HP3 Type Colors — — ETXBAB ETXBBB ETXBBA ETXBCB ETXBCE ETXBCA ETXBDB ETXBDE ETXBDA ETXBEB ETXBEE ETXBFB ETXBFE ETXBGB ETXBGE Z2 Z2 Z1 Z1 Z1 Z1 Z1 Z1 Z1 Z1 Z1 Z1 Z1 Z1 Z1 Z2 Z2 Insulation Colors Z2 Insulation Colors Z1 1 White 2 Black 3 Red 4 Green Availability 100 ft (30.5 m) 1000 ft (305 m)* 9 Slate 10 Violet 0 Black 1 Brown 2 Red 3 Orange 4 Yellow 5 Green 6 Blue 7 Violet 8 Slate 9 White These wires also available in 500 ft (152 m) put-ups. 398 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, PTFE Part No. 13207 13001 12819 12819UL* 11807 MIL-DTL-16878/4 (Type E) UL VW-1 NEMA HP3 Operating Temperature • -60°C to +200°C Wire Size AWG 32 30 28 28 18 Stranding mm 0.03 0.05 0.09 0.09 0.90 2 AWG 7/40 Solid 19/40 19/40 7/26 mm 7 x 0.08 1 x 0.25 19 x 0.07 19 x 0.07 7 x 0.40 Insulation Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 Nominal Diameter Inch mm 0.029 0.74 0.030 0.76 0.036 0.91 0.036 0.91 0.068 1.73 NEMA HP-3 EXBAB EXBBA — — EXBHB *UL AWM 1212 and AWM 1213 and -55°C to +105°C temperature range. Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Materials • Stranded or solid silver-plated copper conductor • PTFE insulation Availability 100 ft (30.5 m) 1000 ft (305 m)* *May contain multiple lengths Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 399 Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, PTFE Part No. MIL-DTL-16878/4 (Type E) (600 V) UL AWM 1213* NEMA HP3 Operating Temperature • -60°C to +200°C (MIL) • -60°C to +105°C (UL) Materials • Stranded or solid silver-plated copper conductor • PTFE insulation Availability 100 ft (30.5 m) 1000 ft (305 m)† 5851 5852 5853 5853/19 2853/1 5854 5854/7 2854/1 5855 5855/7 2855/1 5856 5856/7 2856/1*** 5857 2857/1*** 5858 5859† 5859/12† 5859/10† AWG 30 28 26 26 26 24 24 24 22 22 22 20 20 20 18 18 16 14 12 10 mm2 0.06 0.09 0.14 0.15 0.13 0.24 0.23 0.20 0.38 0.35 0.32 0.62 0.56 0.52 0.96 0.82 1.23 1.94 3.08 4.74 Stranding AWG 7/38 7/36 7/34 19/38 Solid 19/36 7/32 Solid 19/34 7/30 Solid 19/32 7/28 Solid 19/30 Solid 19/29 19/27 19/25 37/26 mm 7 x 0.10 7 x 0.13 7 x 0.16 19 x 0.10 1 x 0.40 19 x 0.13 7 x 0.20 1 x 0.51 19 x 0.16 7 x 0.25 1 x 0.64 19 x 0.20 7 x 0.32 1 x 0.81 19 x 0.25 1 x 1.02 19 x 0.29 19 x 0.36 19 x 0.45 37 x 0.40 Insulation Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.011 0.27 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 Nominal Diameter Inch mm 0.032 0.81 0.035 0.89 0.039 0.99 0.039 0.99 0.036 0.91 0.044 1.12 0.044 1.12 0.040 1.02 0.050 1.27 0.050 1.27 0.045 1.14 0.058 1.47 0.058 1.47 0.052 1.32 0.069 1.75 0.061 1.55 0.080 2.03 0.095 2.41 0.114 2.90 0.134 3.40 NEMA HP3 Type EXBBB EXBCB EXBDB EXBDE EXBDA EXBEE EXBEB EXBEA EXBFE EXBFB EXBFA EXBGE EXBGB EXBGA EXBHE EXBHA EXBJE EXBKE EXBLE EXBMG *Voltage rating not specified. ***White, black, red only. †White only, not UL AWM 1213. †May contain multiple lengths Insulation Colors White Black Red Green 400 Wire Size Yellow Blue Brown Orange Slate Violet Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 1000/300 V Hook-Up Wire 1000/300 V, PTFE Part No. MIL-DTL-16878/5 (TYPE EE) (1000V) UL AWM 1180 (300V) NEMA HP3 Operating Temperature • -60°C to +200°C Materials • Stranded or solid silver-plated copper conductor • PTFE insulation 5874 5875 5876 5877 5878 5879 5879/10 5879/12 5879/8* Wire Size AWG 24 22 20 18 16 14 10 12 8 mm2 0.24 0.38 0.62 0.96 1.23 1.94 4.74 3.08 8.61 Stranding AWG 19/36 19/34 19/32 19/30 19/29 19/27 37/26 19/25 133/29 mm 19 x 0.13 19 x 0.16 19 x 0.20 19 x 0.25 19 x 0.29 19 x 0.36 37 x 0.40 19 x 0.45 133 x 0.29 Insulation Thickness Inch mm 0.015 0.37 0.014 0.36 0.014 0.36 0.015 0.37 0.016 0.41 0.017 0.43 0.017 0.43 0.017 0.43 0.020 0.51 Nominal Diameter Inch mm 0.054 1.37 0.060 1.52 0.068 1.73 0.079 2.01 0.089 2.26 0.106 2.69 0.145 3.68 0.125 3.18 0.209 5.31 NEMA HP3 Type EEXBEE EEXBFE EEXBGE EEXBHE EEXBJE EEXBKE EEXBMG EEXBLE EEXBNL *Not UL AWM 1180. Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Parts 5878, 5879, 5879/8, 5879/10, 5879/12: white only. Availability 100 ft (30.5 m) 1000 ft (305 m)* *May contain multiple lengths Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 401 Wire > Hook-Up Wire > 1000 V Hook-Up Wire 1000 V, PTFE Part No. 22807 22407 22207 22007 MIL-DTL-16878/5 (Type EE) UL VW-1 NEMA HP3 Operating Temperature • -60°C to +200°C Wire Size AWG 28 24 22 20 Stranding mm 0.09 0.23 0.35 0.56 2 AWG 7/36 7/32 7/30 7/28 mm 7 x 0.13 7 x 0.20 7 x 0.25 7 x 0.32 Insulation Thickness Inch mm 0.015 0.38 0.015 0.38 0.014 0.36 0.015 0.38 Nominal Diameter Inch mm 0.045 1.14 0.054 1.37 0.058 1.47 0.068 1.73 NEMA HP-3 EEXBCB EEXBEB EEXBFB EXBGB Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Materials • Stranded silver-plated copper conductor • PTFE insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m)* *May contain multiple lengths 402 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, ETFE or PTFE SAE AS22759/11 (MIL-DTL-22759/11) SAE AS22759/16 (MIL-DTL-22759/16) Operating Temperature • -55°C to +200°C (PTFE) • -55°C to +150°C (ETFE) Materials • Stranded silver-plated copper conductors (SAE AS22759/11) • Stranded tinned copper conductor (SAE AS22759/16) • ETFE or PTFE insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m)* PTFE, SAE AS22759/11, -55°C to +200°C, Silver-Plated Copper Conductors Insulation Wire Size Stranding Thickness Part No. AWG mm Inch mm AWG mm2 AT261938 26 0.15 19/38 19 x 0.10 0.010 0.25 AT241936 24 0.24 19/36 19 x 0.13 0.009 0.23 AT221934 22 0.38 19/34 19 x 0.16 0.009 0.23 AT201932 20 0.62 19/32 19 x 0.20 0.011 0.28 AT181930 18 0.96 19/30 19 x 0.25 0.010 0.25 AT161929 16 1.23 19/29 19 x 0.29 0.010 0.25 AT141927 14 1.94 19/27 19 x 0.36 0.011 0.27 AT121925 12 3.08 19/25 19 x 0.45 0.013 0.32 AT103726 10 4.74 37/26 37 x 0.40 0.015 0.38 AT813329 8 8.61 133/29 133 x 0.29 0.019 0.48 Nominal Diameter Inch mm 0.038 0.97 0.043 1.09 0.049 1.24 0.058 1.47 0.068 1.73 0.075 1.90 0.090 2.29 0.111 2.82 0.139 3.53 0.202 5.13 ETFE, SAE AS22759/16, -55°C to +150°C, Tinned Copper Conductors Insulation Wire Size Stranding Thickness Part No. AWG mm Inch mm AWG mm2 AZ241936 24 0.24 19/36 19 x 0.13 0.011 0.27 AZ221934 22 0.38 19/34 19 x 0.16 0.011 0.28 AZ201932 20 0.62 19/32 19 x 0.20 0.011 0.28 AZ181930 18 0.96 19/30 19 x 0.25 0.012 0.29 AZ161929 16 1.23 19/29 19 x 0.29 0.013 0.33 AZ141927 14 1.94 19/27 19 x 0.36 0.013 0.33 AZ123728 12 2.97 37/28 37 x 0.32 0.014 0.34 AZ103726 10 4.74 37/26 37 x 0.40 0.015 0.38 AZ813329 8 8.63 133/29 133 x 0.29 0.018 0.47 AZ413325 4 21.6 133/25 133 x 0.45 0.026 0.66 Nominal Diameter Inch mm 0.045 1.14 0.052 1.32 0.060 1.52 0.071 1.80 0.079 2.01 0.093 2.36 0.114 2.90 0.139 3.53 0.199 5.05 0.312 7.92 *May contain multiple lengths Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 403 Wire > Hook-Up Wire Hook-Up Wire Wire Wrap, PVDF or ETFE Part No. 5951 5952 5953 5954 UL 1422, 1423, 1516, 1523 VW-1 Operating Temperature • -40°C to +125°C (PVDF) • -70°C to +150°C (ETFE) • +105°C (UL) Materials • Silver-plated solid copper conductors • PVDF or ETFE insulation Availability 100 ft (30.5 m) (ETFE) 1000 ft (305 m) (PVDF or ETFE) 404 Part No. 1805 1806* 1807 1808** Wire Size AWG mm2 30 0.05 28 0.08 26 0.13 24 0.20 Insulation Thickness Inch mm 0.005 0.11 0.006 0.14 0.006 0.14 0.005 0.11 Nominal Diameter Inch mm 0.019 0.51 0.024 0.61 0.027 0.69 0.030 0.76 Wire Size AWG mm2 30 0.05 28 0.08 26 0.13 24 0.20 Insulation Thickness Inch mm 0.005 0.11 0.006 0.14 0.006 0.14 0.005 0.11 Nominal Diameter Inch mm 0.020 0.51 0.024 0.61 0.027 0.69 0.030 0.76 UL Style 1423 1422 1422 1423 UL Style 1516 1523 1523 1516 *Not available in orange. **Not available in violet or orange. Insulation Colors White Black Red Green Yellow Blue Brown Orange Slate Violet Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire Hook-Up Wire Test Lead Wire, EPR Rubber Part No. 1632 1635 1636  perating Temperature O • -30°C to +90°C Wire Size AWG 20 20 18 mm2 0.52 0.52 0.83 Insulation Thickness AWG mm Inch mm 41/36 41 x 0.13 0.040 1.02 41/36 41 x 0.13 0.047 1.19 65/36 65 x 0.13 0.045 1.14 Stranding Nominal Diameter Inch mm 0.118 3.00 0.132 3.35 0.137 3.48 Breakdown Voltage (RMS) Working Voltage (RMS) 6000 12,000 20,000 1500 3000 5000 Insulation Colors Black Red Voltage Rating • See table Materials • Stranded tinned copper conductors • EPR rubber insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 405 Wire > Hook-Up Wire > 600 V Hook-Up Wire 600 V, Silicone Rubber Part No. UL AWM 3212, 3213, 3214 CSA AWM I A/B FT2 Operating Temperature • -40°C to +150°C Materials • Stranded tinned copper conductor • White silicone rubber insulation 392207 392010 391816 391626 391441 391265 391000 398133 396133 394133 392259 391259 390001 390002 390004 Wire Size AWG 22 20 18 16 14 12 10 8 6 4 2 1 1/0 2/0 4/0 Stranding mm 0.35 0.51 0.81 1.32 2.08 3.29 5.32 8.61 13.57 21.55 33.15 41.96 53.10 67.43 106.82 2 AWG 7/30 10/30 16/30 26/30 41/30 65/30 105/30 133/29 133/27 133/25 259/26 259/25 259/24 1330/30 2107/30 mm 7 x 0.25 10 x 0.25 16 x 0.25 26 x 0.25 41 x 0.25 65 x 0.25 105 x 0.25 133 x 0.29 133 x 0.36 133 x 0.45 259 x 0.40 259 x 0.45 259 x 0.51 1330 x 0.25 2107 x 0.25 Insulation Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.078 1.98 0.078 1.98 0.078 1.98 0.078 1.98 Nominal Diameter Inch mm 0.124 3.15 0.131 3.33 0.141 3.58 0.154 3.91 0.168 4.27 0.187 4.75 0.212 5.38 0.295 7.49 0.339 8.61 0.395 10.03 0.460 11.68 0.532 13.51 0.578 14.68 0.639 16.23 0.837 21.26 UL AWM 3212 3212 3212 3212 3212 3212 3212 3213 3213 3213 3213 3214 3214 3214 3214 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length 406 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 600 V Hook-Up Wire High-Temperature Appliance Wire 600 V, Silicone Rubber, Glass Braid UL AWM 3070, 3071, 3074, 3075 UL SF-2, SFF-2 CSA SEW-2, SEWF-2 Operating Temperature • -40°C to +200°C (UL SF-2, CSA SEW-2) • -40°C to +150°C (UL SFF-2, CSA SEWF-2) Part No. M4101 M4110 M4102 M4111 M4103 M4112 M4104 M4113 M4105 Wire Size AWG mm2 18 0.82 18 0.81 16 1.31 16 1.32 14 2.08 14 2.08 12 3.08 12 3.29 10 4.92 Stranding AWG mm 7/0.0152 7 x 0.39 16/30 16 x 0.25 7/0.0192 7 x 0.49 26/30 26 x 0.25 7/0.0242 7 x 0.61 41/30 41 x 0.25 19/25 19 x 0.45 65/30 65 x 0.25 19/23 19 x 0.57 Insulation Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.048 1.22 Materials • Stranded tinned copper conductor • Silicon rubber insulation • Glass braid jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Nominal Diameter Inch mm 0.124 3.15 0.130 3.30 0.136 3.45 0.140 3.56 0.152 3.86 0.160 4.06 0.166 4.22 0.180 4.57 0.221 5.61 Approval UL CSA 3071, SF-2 SEW-2 3070, SFF-2 SEWF-2 3071, SF-2 SEW-2 3070, SFF-2 SEWF-2 3071, SF-2 SEW-2 3070, SFF-2 SEWF-2 3074, SF-2 SEW-2 3070, SFF-2 SEWF-2 3075, SF-2 SEW-2 Insulation Colors White Black Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 407 Wire > Hook-Up Wire > 600 V Hook-Up Wire High-Temperature Type SRML Motor Lead 600 V, Silicone Rubber UL AWM 3101, 3231, 3278 CSA SEW-2, SEWF-2 Operating Temperature • -40°C to +200°C (AWM 3231, SEW-2) • -40°C to +150°C (AWM 3101, 3278, SEWF-2) Part No. M4114 M4115 M4116 M4117 M4118 M4120 M4121 M4122 M4123 Wire Size AWG mm2 10 5.32 8 8.29 6 13.6 4 21.1 2 33.5 1/0 53.5 2/0 68.8 3/0 85.3 4/0 107 Stranding AWG mm 105/30 105 x 0.25 133/.0111 133 x 0.28 133/27 133 x 0.36 133/.0177 133 x 0.45 133/.0223 133 x 0.57 259/.0202 259 x 0.51 259/.0229 259 x 0.58 259/.0255 259 x 0.65 259/.0286 259 x 0.73 Insulation Thickness Inch mm 0.047 1.19 0.062 1.57 0.062 1.57 0.062 1.57 0.062 1.57 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 Materials • Stranded tinned copper conductor • Silicon rubber insulation • Black or white glass braid jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Nominal Diameter Inch mm 0.230 5.84 0.305 7.75 0.345 8.76 0.400 10.16 0.470 11.94 0.605 15.37 0.660 16.76 0.715 18.16 0.785 19.94 UL AWM Style CSA Type 3101 3278 3278 3231 3231 3231 3231 3231 3231 SEWF-2 SEWF-2 SEWF-2 SEW-2 SEW-2 SEW-2 SEW-2 SEW-2 SEW-2 Insulation Colors White Black 408 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire Hook-Up Wire High Voltage, Silicone Rubber UL 3239 Part No. UL AWM 3239 Operating Temperature • -40°C to +150°C Materials • Stranded tinned copper conductor • Silicone rubber insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 392297 392275 392262 392250 392245 392240 392097 392075 392062 392050 392045 392040 391897 391875 391862 391850 391845 391840 391699 391697 391675 391662 391650 391645 391640 391499 391497 391475 391462 391450 391445 391440 Wire Size AWG 22 22 22 22 22 22 20 20 20 20 20 20 18 18 18 18 18 18 16 16 16 16 16 16 16 14 14 14 14 14 14 14 White mm2 0.35 0.35 0.35 0.35 0.35 0.35 0.51 0.51 0.51 0.51 0.51 0.51 0.81 0.81 0.81 0.81 0.81 0.81 1.32 1.32 1.32 1.32 1.32 1.32 1.32 2.08 2.08 2.08 2.08 2.08 2.08 2.08 Black Stranding AWG 7/30 7/30 7/30 7/30 7/30 7/30 10/30 10/30 10/30 10/30 10/30 10/30 16/30 16/30 16/30 16/30 16/30 16/30 26/30 26/30 26/30 26/30 26/30 26/30 26/30 41/30 41/30 41/30 41/30 41/30 41/30 41/30 mm 7 x 0.25 7 x 0.25 7 x 0.25 7 x 0.25 7 x 0.25 7 x 0.25 10 x 0.25 10 x 0.25 10 x 0.25 10 x 0.25 10 x 0.25 10 x 0.25 16 x 0.25 16 x 0.25 16 x 0.25 16 x 0.25 16 x 0.25 16 x 0.25 26 x 0.25 26 x 0.25 26 x 0.25 26 x 0.25 26 x 0.25 26 x 0.25 26 x 0.25 41 x 0.25 41 x 0.25 41 x 0.25 41 x 0.25 41 x 0.25 41 x 0.25 41 x 0.25 Insulation Thickness Inch mm 0.097 2.46 0.075 1.90 0.062 1.57 0.050 1.27 0.045 1.14 0.040 1.02 0.097 2.46 0.075 1.90 0.062 1.57 0.050 1.27 0.045 1.14 0.040 1.02 0.097 2.46 0.075 1.90 0.062 1.57 0.050 1.27 0.045 1.14 0.040 1.02 0.150 3.81 0.097 2.46 0.075 1.90 0.062 1.57 0.050 1.27 0.045 1.14 0.040 1.02 0.150 3.81 0.097 2.46 0.075 1.90 0.062 1.57 0.050 1.27 0.045 1.14 0.040 1.02 Nominal Diameter Inch mm 0.224 5.69 0.180 4.57 0.154 3.91 0.131 3.33 0.120 3.05 0.11 2.79 0.231 5.87 0.187 4.75 0.161 4.09 0.137 3.48 0.127 3.23 0.117 2.97 0.241 6.12 0.197 5.00 0.171 4.34 0.147 3.73 0.137 3.48 0.127 3.23 0.360 9.14 0.254 6.45 0.210 5.33 0.184 4.67 0.160 4.06 0.150 3.81 0.140 3.56 0.374 9.50 0.268 6.81 0.224 5.69 0.198 5.03 0.174 4.42 0.164 4.17 0.154 3.91 Voltage 40 kV 30 kV 25 kV 20 kV 15 kV 10 kV 40 kV 30 kV 25 kV 20 kV 15 kV 10 kV 40 kV 30 kV 25 kV 20 kV 15 kV 10 kV 50 kV 40 kV 30 kV 25 kV 20 kV 15 kV 10 kV 50 kV 40 kV 30 kV 25 kV 20 kV 15 kV 10 kV Red Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 409 Wire > Hook-Up Wire Hook-Up Wire High Voltage, Silicone Rubber UL 3239 Part No. UL AWM 3239 Operating Temperature • -40°C to +150°C Materials • Stranded tinned copper conductor • Silicone rubber insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) 410 391297 391275 391262 391250 391245 391099 391097 391045 391040 390897 390862* 390845 390662* 390645 390462* 390262* Wire Size AWG 12 12 12 12 12 10 10 10 10 8 8 8 6 6 4 2 mm2 3.29 3.29 3.29 3.29 3.29 5.32 5.32 5.32 5.32 8.61 8.61 8.61 13.57 13.57 21.55 34.45 Insulation Thickness mm Inch mm 65 x 0.25 0.097 2.46 65 x 0.25 0.075 1.90 65 x 0.25 0.062 1.57 65 x 0.25 0.050 1.27 65 x 0.25 0.045 1.14 105 x 0.25 0.150 3.81 105 x 0.25 0.097 2.46 105 x 0.25 0.045 1.14 105 x 0.25 0.040 1.02 133 x 0.28 0.097 2.46 133 x 0.28 0.062 1.57 133 x 0.28 0.045 1.14 133 x 0.36 0.062 1.57 133 x 0.36 0.045 1.14 133 x 0.45 0.062 1.57 259 x 0.40 0.062 1.57 Stranding AWG 65/30 65/30 65/30 65/30 65/30 105/30 105/30 105/30 105/30 133/29 133/29 133/29 133/27 133/27 133/25 259/26 Nominal Diameter Inch mm 0.287 7.29 0.243 6.17 0.217 5.51 0.193 4.90 0.183 4.65 0.418 10.62 0.312 7.92 0.208 5.28 0.198 5.03 0.363 9.22 0.293 7.44 0.259 6.58 0.337 8.56 0.303 7.70 0.393 9.98 0.463 11.76 Voltage 40 kV 30 kV 25 kV 20 kV 15 kV 50 kV 40 kV 15 kV 10 kV 40 kV 25 kV 15 kV 25 kV 15 kV 25 kV 25 kV *Not UL Recognized. Insulation Colors White Black Red Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire Hook-Up Wire High Voltage, Silicone Rubber Part No. UL VW-1 Operating Temperature • -40°C to +200°C Materials • Stranded silver-plated copper conductor • White silicone rubber insulation 39X2220 39X2215 39X2205 39X2025 39X2020 39X2015 39X1825 39X1660 39X1645 39X1635 39X1620 39X1460 39X1260 Wire Size AWG 22 22 22 20 20 20 18 16 16 16 16 14 12 mm2 0.35 0.35 0.35 0.62 0.62 0.62 0.96 1.32 1.23 1.23 1.33 1.94 3.08 Stranding AWG 7/30 7/30 7/30 19/32 19/32 19/32 19/30 26/30 19/29 41/32 41/32 19/27 19/25 mm 7 x 0.25 7 x 0.25 7 x 0.25 19 x 0.20 19 x 0.20 19 x 0.20 19 x 0.25 26 x 0.25 19 x 0.28 41 x 0.20 41 x 0.20 19 x 0.36 19 x 0.45 Insulation Thickness Inch mm 0.050 1.27 0.040 1.02 0.020 0.51 0.063 1.60 0.055 1.40 0.040 1.02 0.055 1.40 0.162 4.11 0.125 3.18 0.105 2.67 0.053 1.33 0.157 3.99 0.178 4.51 Nominal Diameter Inch mm 0.130 3.30 0.110 2.79 0.070 1.78 0.166 4.22 0.150 3.81 0.120 3.05 0.160 4.06 0.384 9.75 0.306 7.77 0.269 6.83 0.164 4.17 0.385 9.78 0.445 11.30 Voltage 20 kV 15 kV 5 kV 25 kV 20 kV 15 kV 25 kV 60 kV 45 kV 35 kV 20 kV 60 kV 60 kV Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 411 Wire > Hook-Up Wire > 600 V Hook-Up Wire High Temperature 600 V, Mica-Glass, PTFE Part No. UL AWM 5107 CSA AWM I A/B Operating Temperature • -55°C to +538°C • -55°C to +450°C (UL, CSA) 3112010 3111816 3111626 3111441 3111265 3111000 3118133 3116133 3114133 3112133 Wire Size AWG 20 18 16 14 12 10 8 6 4 2 mm2 0.51 0.81 1.32 2.08 3.29 5.32 8.63 13.6 21.6 34.4 Stranding AWG 10/30 16/30 26/30 41/30 65/30 105/30 133/29 133/27 133/25 133/23 mm 10 x 0.25 16 x 0.25 26 x 0.25 41 x 0.25 65 x 0.25 105 x 0.25 133 x 0.28 133 x 0.36 133 x 0.36 133 x 0.57 Insulation Thickness Inch mm 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.030 0.76 0.030 0.76 0.030 0.76 0.030 0.76 0.035 0.89 Nominal Diameter Inch mm 0.101 2.57 0.111 2.82 0.124 3.15 0.138 3.51 0.157 3.99 0.206 5.23 0.260 6.60 0.304 7.72 0.361 9.17 0.444 11.28 Materials • Stranded nickel-plated copper conductor • Mica-glass tape insulation • Tan PTFE-impregnated fiberglass jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length 412 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 600 V Hook-Up Wire High Temperature 600 V, PTFE/Glass Braid Part No. UL AWM 5196 CSA AWM I A/B 3131816 3131626 3131441 3131265 3131000 3138133 3136133 Wire Size AWG 18 16 14 12 10 8 6 mm2 0.81 1.32 2.08 3.29 5.32 8.61 13.6 Stranding AWG 16/30 26/30 41/30 65/30 105/30 133/29 133/27 mm 16 x 0.25 26 x 0.25 41 x 0.25 65 x 0.25 105 x 0.25 133 x 0.29 133 x 0.36 Insulation Thickness Inch mm 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 0.016 0.41 Nominal Diameter Inch mm 0.109 2.77 0.122 3.10 0.136 3.45 0.155 3.94 0.180 4.57 0.232 5.89 0.315 8.00 Operating Temperature • -55°C to +250°C Materials • Stranded nickel-plated copper conductor • White PTFE tape insulation • Double fiberglass serve • Tan PTFE-impregnated fiberglass jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 413 Wire > Hook-Up Wire > 600 V Hook-Up Wire Type TGGT High-Temperature 600 V, PTFE/Glass Braid Part No. UL AWM 5196, 5251 CSA AWM 1 A/B M70562* M70563 M70564 M70565 M70566 M70567 Wire Size AWG 2 1 1/0 2/0 3/0 4/0 Stranding mm2 36.6 41.1 53.5 68.8 85.3 107 AWG 133/0.0223 259/0.0177 259/0.0202 259/0.0227 259/0.0255 259/0.0286 mm 133 x 0.57 259 x 0.45 259 x 0.51 259 x 0.58 259 x 0.65 259 x 0.73 Insulation Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 Nominal Diameter Inch mm 0.445 11.30 0.485 12.32 0.535 13.59 0.685 17.40 0.645 16.38 0.710 18.03 *UL AWM 5196. Operating Temperature • -55°C to +250°C Materials • Flexible nickel-covered stranded copper conductor • White PTFE tape insulation • Tan high-temperature-saturantcoated glass braid jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length 414 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > 600 V Hook-Up Wire Welding Cable 600 V, EPDM Part No. Operating Temperature • -50°C to +105°C Materials • Stranded bare copper conductor • Black EPDM rubber jacket 6112 6113 6115 6116 6117 6118 6119 6120 Wire Size AWG 6 4 2 1 1/0 2/0 3/0 4/0 Stranding AWG mm mm2 13.5 266/30 266 x 0.25 19.9 392/30 392 x 0.25 32.6 644/30 644 x 0.25 39.7 784/30 784 x 0.25 52.0 1026/30 1026 x 0.25 63.5 1254/30 1254 x 0.25 81.8 1615/30 1615 x 0.25 104 2056/30 2056 x 0.25 Insulation Thickness Inch 0.060 0.060 0.060 0.080 0.080 0.080 0.080 0.080 mm 1.52 1.52 1.52 2.03 2.03 2.03 2.03 2.03 Nominal Diameter Inch 0.320 0.375 0.440 0.515 0.550 0.590 0.660 0.725 mm 8.13 9.53 11.18 13.08 13.97 14.99 16.76 18.42 CurrentCarrying Voltage Capacity Drop* A V 75 3.30 100 2.80 200 3.60 250 3.80 300 3.60 375 3.37 450 3.40 550 3.30 *Voltage drop per 100 ft (30.5 m) at 60°C. Availability Bulk, cut to length Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 415 Wire > Hook-Up Wire > Photovoltaic > 1000/2000 V Hook-Up Wire 1000/2000 V Photovoltaic Wire, XLPE, PVC Wire Size Part No. UL 4703 PV VW-1 (2000 V) UL Sunlight Resistant Operating Temperature • -40°C to +90°C Materials • Stranded tinned copper conductor • Black cross-linked polyethylene insulation • Black PVC jacket Stranding Insulation/Jacket Thickness Nominal Diameter AWG mm2 AWG mm Inch mm Inch mm PV1430 14 2.08 41/30 41 x 0.25 0.063/ 0.032 1.60/ 0.81 0.267 6.78 PV1230 12 3.29 65/30 65 x 0.25 0.063/ 0.032 1.60/ 0.81 0.286 7.26 PV1030 10 5.32 105/30 105 x 0.25 0.063/ 0.032 1.60/ 0.81 0.311 7.90 PV0830A* 8 8.51 168/30 168 x 0.25 0.078/ 0.032 1.98/ 0.81 0.390 9.91 PV0630A* 6 13.5 266/30 266 x 0.25 0.078/ 0.032 1.98/ 0.81 0.433 11.00 PV0430A* 4 21.3 420/30 420 x 0.25 0.078/ 0.032 1.98/ 0.81 0.491 12.47 PV0230A* 2 33.7 665/30 665 x 0.25 0.078/ 0.032 1.98/ 0.81 0.558 14.17 *UL 4703 PV only. Availability 100 ft (30.5 m) 1000 ft (305 m) 416 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > Photovoltaic > 600/1000 V Hook-Up Wire 600/1000 V Photovoltaic Wire, LSZH, LSZH Part No. UL 4703 PV VW-1 (600 V) UL Sunlight Resistant TÜV 2 PFG 1169 (1000 V) IEC 60332-1 IEC 60754-1 and 60754-2 Operating Temperature • -40°C to +125°C • -40°C to +90°C (TÜV and UL) • +120°C maximum temperature at conductor (TÜV) Wire Size Stranding Insulation/Jacket Thickness Nominal Diameter AWG mm2 AWG mm Inch mm Inch mm PVT1430 14 2.5 50/30 50 x 0.25 0.045/ 0.032 1.14/ 0.81 0.230 5.84 PVT1228 12 4.0 56/28 56 x 0.32 0.045/ 0.032 1.14/ 0.81 0.252 6.40 PVT1028 10 6.0 84/28 84 x 0.32 0.045/ 0.032 1.14/ 0.81 0.275 6.99 PVT0826 8 10 78/26 78 x 0.40 0.060/ 0.032 1.52/ 0.81 0.340 8.64 PVT0626 6 16 128/26 128 x 0.40 0.060/ 0.032 1.52/ 0.81 0.386 9.80 PVT0426 4 25 199/26 199 x 0.40 0.060/ 0.032 1.52/ 0.81 0.436 11.07 PVT0226 2 35 279/26 279 x 0.40 0.060/ 0.032 1.52/ 0.81 0.484 12.29 Materials • Stranded tinned copper conductor • Black cross-linked LSZH insulation • Black cross-linked LSZH jacket Availability 100 ft (30.5 m) 1000 ft (305 m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 417 Wire > Hook-Up Wire > EcoWire > 600 V Hook-Up Wire EcoWire™ 600 V, mPPE Innovative EcoWire combines increased performance with a minimized environmental impact. EcoWire’s modified polyphenylene ether (mPPE) insulation is inherently lighter, tougher, and more durable than PVC. The result is UL AWM wire that is up to 45% smaller in diameter and Part No. 6710 6711 6712 6713 6714 6715 6715S 6716 6717 6717S 6718 6719 White Black Red Green 418 Conductor Size AWG mm2 28 0.07 26 0.14 24 0.22 22 0.35 20 0.51 18 0.81 18 0.82 16 1.32 14 2.09 14 2.08 12 3.31 10 5.37 Yellow Blue Brown Orange 40% lighter than PVC-based counterparts, while offering 10x better abrasion resistance. Plus, the non-halogenated insulation contains no heavy metal pigments, allowing it to help manufacturers meet Waste Electrical and Electronic Equipment (WEEE) requirements. UL AWM 11028 VW-1 CSA AWM I A/B FT1 CE compliant Operating Temperature • -40°C to +105°C Materials • Stranded or solid tinned copper conductors • Modified polyphenylene ether insulation Availability 100 ft (30.5 m) 1000 ft (305 m) Stranding AWG mm 7/36 7 x 0.12 7/34 7 x 0.16 7/32 7 x 0.20 7/30 7 x 0.25 10/30 10 x 0.25 16/30 16 x 0.25 Solid Solid 26/30 26 x 0.25 41/30 41 x 0.25 Solid Solid 65/30 65 x 0.25 105/30 105 x 0.25 Insulation Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.011 0.28 0.011 0.28 0.011 0.28 0.012 0.30 0.012 0.30 Wire Diameter Inch mm 0.034 0.86 0.038 0.97 0.043 1.09 0.049 1.24 0.055 1.40 0.067 1.70 0.059 1.50 0.081 2.06 0.096 2.44 0.086 2.18 0.117 2.97 0.144 3.66 Slate Violet Green/Yellow Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > Ribbon Cable > 150/600 V Hook-Up Wire 150/600 V Ribbon Cable, PVC 26 AWG (0.14 mm2) Stranding: 7/34 (7 x 0.16 mm) Insulation thickness: 0.010 (0.25 mm) Cable height: 0.039 (0.99 mm) MIL-DTL-16878/1 (Type B) (600 V) UL AWM 2713 (150 V) VW-1 Part No. Conductors 3550 3550/14 3551 3551/16 3553 10 14 15 16 30 Materials • Stranded tinned copper conductors • Color-coded PVC insulation bonded into a flat configuration Availability 100 ft (30.5 m) mm 9.96 13.87 14.68 15.85 29.72 24 AWG (0.23 mm2) Operating Temperature • -20°C to +105°C (MIL) • -20°C to +80°C (AWM) Conductor Color Coding • Brown, red, orange, yellow, green, blue, violet, slate, white, black . . . repeats Width Inch 0.392 0.546 0.585 0.624 1.170 Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) Cable height: 0.044 (1.12 mm) Part No. Conductors 3540/7 3541/7 3542/7 10 15 20 Width Inch 0.440 0.660 0.880 mm 11.18 16.76 22.35 24 AWG (0.24 mm2) Stranding: 19/36 (19 x 0.12 mm) Insulation thickness: 0.010 (0.25 mm) Cable height: 0.044 (1.12 mm) Part No. Conductors 3540 3541 3542 3543 10 15 20 30 Width Inch 0.440 0.660 0.880 1.320 mm 11.18 16.76 22.35 33.53 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Cable height: 0.050 (1.27 mm) Part No. Conductors 3530/7 3531/7 3532/7 3533/7 10 15 20 30 Width Inch 0.500 0.750 1.000 1.500 mm 12.70 19.05 25.40 38.10 22 AWG (0.38 mm2) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.010 (0.25 mm) Cable height: 0.051 (1.29 mm) Part No. Conductors 3530 3531 3532 3533 10 15 20 30 Width Inch 0.510 0.765 1.020 1.530 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. mm 12.95 19.43 25.91 38.86 419 Wire > Hook-Up Wire > Ribbon Cable > 300/1000 V Hook-Up Wire 300/1000 V Ribbon Cable, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Cable height: 0.065 (1.65 mm) MIL-DTL-16878/2 (Type C) (1000 V) UL AWM 2555 (300 V) Part No. Conductors 3505 3510 3515 3520 5 10 15 20 Width Inch 0.310 0.620 0.930 1.240 mm 7.87 15.75 23.62 31.50 Operating Temperature • -20°C to +105°C (MIL) • -20°C to +80°C (AWM) Conductor Color Coding • Brown, red, orange, yellow, green, blue, violet, slate, white, black . . . repeats Materials • Stranded tinned copper conductors • Color-coded PVC insulation bonded into a flat configuration Availability 100 ft (30.5 m) 420 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > Bus Bar Wire Hook-Up Wire Bus Bar Wire Part No CID AA-59551 Type S ASTM B33 Material • Electrolytic soft-drawn and annealed solid tin-plated copper conductor Availability 100 ft (30.5 m) 1000 ft (305 m) 938 936 934 932 299/3 299/2 299/1 299 298 297 296 295 286 289 910 908 906 AWG 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 Wire Size CMA 16 25 40 64 100 159 253 404 640 1020 1620 2580 4110 6530 10380 16510 26250 Diameter mm2 .008 0.01 0.02 0.03 0.05 0.08 0.12 0.20 0.32 0.51 0.82 1.31 2.08 3.31 5.26 8.37 13.3 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Inch 0.004 0.005 0.006 0.008 0.010 0.013 0.016 0.020 0.025 0.032 0.040 0.051 0.064 0.081 0.102 0.129 0.162 mm 0.10 0.13 0.15 0.20 0.25 0.33 0.41 0.51 0.64 0.81 1.02 1.30 1.63 2.06 2.59 3.28 4.11 421 Wire > Hook-Up Wire Kits Hook-Up Wire Kits Part No. Alpha’s hook-up wire kits contain an assortment of 100 ft (30.5 m) spools of hook-up wire suitable for military or UL/CSA applications. These kits have been designed for use by technicians, engineers, and designers in the R&D lab or maintenance shop. Each kit contains a stripping tool and five spools of hook-up wire in a unique, rackmounted, transparent dispensing tube. The tube and rack system keeps hook-up wire neat, clean, and conveniently at hand. Operating Temperature • -40°C to +80°C (HU-KIT-10, 30) • -40°C to +105°C (HU-KIT-20, 40) Wire Type Wire Size AWG mm Colors 2 HU-KIT-40 UL AWM 1007 UL AWM 1569 CSA TR 64 24 0.23 HU-KIT-30 MIL-W-76B Type MW 24 0.23 HU-KIT-20 UL AWM 1007 UL AWM 1569 CSA TR 64 22 0.36 HU-KIT-10 MIL-W-76B Type MW 22 0.36 White Black Red Green Blue White Black Red Green Blue White Black Red Green Blue White Black Red Green Blue Wire Length (each order) Feet Meters Reorder No. 100 30.5 3050 100 30.5 1550 100 30.5 3051 100 30.5 1551 Note: Each kit includes a cut-and-strip tool. Voltage Rating • 1000 V (HU-KIT-10, 30) • 300 V (HU-KIT-20, 40) Materials • Stranded tinned copper conductor • Color-coded PVC insulation Availability 1 box 422 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Hook-Up Wire > Dearborn™ Bulk Hook-Up Wire Dearborn™ Bulk Hook-Up Wire We support your high-volume needs with large put-ups for a wide range of both military and UL style PVC hook-up wire. Dearborn bulk wire has the same high quality as all Alpha wire and cable, but is available in put-ups of 5000 ft (1524 m) and above. Many styles are available in barrel packs as well. Bulk PVC wire options include: • Stranded and solid conductors • Bare or tinned copper • Standard and semirigid PVC • Variety of temperature ranges Popular Bulk Wire Styles Style MIL-DTL-16878/1 (Type B) MIL-DTL-16878/2 (Type C) MIL-DTL-16878/3 (Type D) MIL-W-76 Type MWP UL AWM 1007 UL AWM 1028 UL AWM 1061 UL AWM 1231 UL AWM 1569 UL AWM 1581 UL MTW UL TW Insulation PVC PVC PVC PVC PVC PVC SR-PVC PVC PVC PVC PVC PVC AWG Range 32 – 14 24 – 22 16 24, 12 24 - 10 24 - 10 30 - 20 24 - 10 28 - 16 28 - 16 20 – 10 24 - 10 Temperature -55°C to +105°C -55°C to +105°C -20°C to +105°C -55°C to +90°C -20°C to +80°C -20°C to +105°C -10°C to +80°C -20°C to +105°C -20°C to +105°C -20°C to +80°C -20°C to +90°C -20°C to +60°C For more styles and conductor options please contact your Alpha Wire Sales Representative. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 423 Toll Free: 1-800-52 ALPHA | www.alphawire.com
781816TYL013
物料型号:文档中提供了多种不同型号的Hook-Up Wire,包括不同绝缘材料和温度范围的电线。
器件简介:Alpha Wire提供的Hook-Up Wire适用于各种应用场景,包括控制柜、工厂设备、高温烤箱和越野建筑设备等。这些线材有多种绝缘材料可选,以满足不同温度、耐磨损、电气性能、耐油、溶剂和化学品的需求。
引脚分配:文档中没有提到具体的引脚分配信息,通常这与电线的用途和设计有关。
参数特性: - 导体类型:绞合和实心铜导体,可提供裸铜或镀锡,以及其他特殊应用需求的镀层。 - 绝缘材料:包括PVC、XL-PVC、mPPE、PTFE、XLPE、硅橡胶、PDVF、ETFE、TGGT、MG等,每种材料都有其特定的温度范围和特性。 - 认证:UL、CSA和Mil-spec合规性。
功能详解:Alpha Wire的Hook-Up Wire设计具有良好的一致性和低毛刺,便于处理、剥离和终端连接。部分产品还具有颜色编码的绝缘,便于电路识别。
应用信息:这些线材适用于多种环境和设备,包括高密度布线、高电压材料、灵活性需求、耐辐射、冠状放电和臭氧等。
封装信息:文档提供了不同AWG尺寸的线材的绝缘厚度和名义直径,以及可用的颜色和包装长度(如100英尺、500英尺和1000英尺)。
781816TYL013 价格&库存
很抱歉,暂时无法提供与“781816TYL013”相匹配的价格&库存,您可以联系我们找货
