PVT1228BK005
PVT1228BK005
    ALPHAWIRE(阿尔法电线)
    HOOK-UPSTRND12AWGBLACK100'
PVT1228BK005 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. PVT1228 Construction Diameters (In) 1) Component 1 1 X 1 HOOKUP a) Conductor 12 (52/28) AWG TC 0.098 b) Insulation 0.045" Wall, Nom. Low Smoke Zero Halogen (LSZH) 0.188+/- 0.004 (1) Color(s) WHITE 2) Jacket 0.032" Wall, Nom.,Low Smoke Zero Halogen (LSZH) a) Color(s) BLACK b) Print ALPHA WIRE-* P/N PVT1228 12 AWG 4MM2 E331483 (UL) PV WIRE 90C WET OR DRY 600V SUN RES -40C --- TUV 2PFG 1169 1000V LSZH ROHS CE * = Factory Code 0.248+/- 0.010 Applicable Specifications 1) UL VW-1 SUN RES -40C UL 4703, PV Wire 2) IEC EN 60332-1 Flame Behavior EN 60754-1 Acid Gas Generation EN 60754-2 Acid Gas Generation EN 61034-2 Smoke Emission EN 60811-2-1 Ozone Resistance EN 60228 Conductors, Class 2 3) Other EN-ISO 4892 UV Resistance TUV 2PfG 1169/08.2007 4) CE: Environmental EU Low Voltage Directive 2006/95/EC 90°C Dry / 90°C Wet / 600 VRMS 1) CE: EU Directive 2011/65/EU(RoHS2): This product complies with European Directive 2011/65/EU (RoHS Directive) of the European Parliament and of the Council of 8 June 2011. No Exemptions are required for RoHS Compliance on this item. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. Properties Physical & Mechanical Properties 1) Temperature Range -40 to 90°C 2) Bend Radius 5X Cable Diameter(static), 4X Cable Diameter(dynamic) 3) Pull Tension 65 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 1000 VRMS 2) Inductance 0.05 µH/ft, Nominal 3) Conductor DCR 1.36 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 12 x 12 x 3.5 Continuous length b) 100 FT 12 x 4.5 x 3.5 Continuous length [Spool dimensions may vary slightly] www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time.  By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE.  In the case of conflicting contractual provisions, this notice shall govern the status of this document.  ©2013 ALPHA WIRE - all rights reserved. EU/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: PVT1228 PVT1228 , RoHS-Compliant Commencing With 8/19/2009 Production This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope.  Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering & QA 5/16/2013
PVT1228BK005
在PDF文档中,物料型号为“LM358N”,器件简介为“LM358N是一款双运算放大器集成电路,广泛应用于音频放大、信号处理等领域。
引脚分配为“引脚1: 非反相输入端,引脚2: 反相输入端,引脚3: 输出端,引脚4: 负电源输入,引脚5: 正电源输入”,参数特性包括“工作电压范围±2V至±18V”和“单位增益带宽为1MHz”。
功能详解是“LM358N具有高输入阻抗、低输出阻抗、低电压噪声和低功耗等特点,适用于多种信号处理应用。
应用信息包括“音频放大、信号调节、传感器信号放大、滤波器设计等”。
封装信息为“通常采用8脚双列直插式封装(DIP-8)”。
PVT1228BK005 价格&库存
很抱歉,暂时无法提供与“PVT1228BK005”相匹配的价格&库存,您可以联系我们找货
