UP2UC-220-R
UP2UC-220-R
    EATON(伊顿)
    SMD,12.7x10mm
    固定电感器 ±20% 2.6A 19MHz SMD 22µH 12.70 x 10.00mm
UP2UC-220-R 数据手册
Technical Data 4369 Effective August 2017 Supersedes June 2009 UP2UC UNI-PAC™ drum core power inductors Applications • • • • • • • • • Desktop computer Workstations/servers DVD Players Portable power devices Base stations Industrial power supplies Output filter chokes Test equipment instrumentation Buck or boost inductor Environmental data Product features • • • • 12.7 mm x 9.5 mm x 5.21 mm drum core Inductance range from 1.0 µH to 1000 µH Current range from 0.30 A to 9.0 A Ferrite core material • • • Storage temperature range (component): -40 °C to +125 °C Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) Solder reflow temperature: J-STD-020 (latest revision) compliant Pb HF FREE HALOGEN Technical Data 4369 UP2UC UNI-PAC™ drum core power inductors Effective August 2017 Product specifications OCL1 5 Part Number UP2UC-1R0-R UP2UC-1R5-R UP2UC-2R2-R UP2UC-3R3-R UP2UC-4R7-R UP2UC-6R8-R UP2UC-100-R UP2UC-150-R UP2UC-220-R UP2UC-330-R UP2UC-470-R UP2UC-680-R UP2UC-101-R UP2UC-151-R UP2UC-221-R UP2UC-331-R UP2UC-471-R UP2UC-681-R UP2UC-102-R Irms2 (A) 6.8 6.4 6.1 5.4 4.8 4.4 3.9 3.1 2.7 2.1 1.8 1.5 1.3 1.0 0.80 0.60 0.50 0.40 0.30 µH ± 20% 1.0 1.5 2.2 3.3 4.7 6.8 10.0 15.0 22.0 33.0 47.0 68.0 100 150 220 330 470 680 1000 Isat3 (A) @ +25 °C 9.0 8.0 7.0 6.4 5.4 4.6 3.8 3.0 2.6 2.0 1.6 1.4 1.2 1.0 0.80 0.60 0.50 0.40 0.30 1 Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc 2 Irms: DC current for an approximate ΔT rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow and proximity of other heat generating components will affect the temperature rise. It is recommended the part temperature not exceed +125 °C under worst case operating conditions verified in the end application. 3 Isat: Peak current for approximately 7.5% rolloff at +25 °C. SRF MHz Typical 100 90.0 80.0 65.0 45.0 38.0 30.0 27.0 19.0 15.0 12.0 10.0 9.0 6.0 5.0 4.5 3.5 2.5 2.0 DCR mΩ@ +20 °C DCR mΩ@ +20 °C Typical Maximum 4.0 9.0 4.4 10.0 5.8 12.0 9.9 15.0 12.0 18.0 25.8 27.0 25.9 38.0 35.4 46.0 55.9 85.0 81.6 100 120 140 145 200 211 280 347 400 491 610 750 1020 1188 1270 1811 2020 2757 3000 K-factor4 216 177 130 114 92.52 77.72 62.68 49.82 41.34 34.09 29.00 24.59 20.89 15.80 13.04 10.85 9.39 7.56 6.13 4 K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI, Bp-p: (Gauss), K: (K-factor from table), L: (inductance in μH), ΔI (peak-to-peak ripple current in amps). 6 Part Number Definition: UP2CU-xxx-R • UP2CU = Product code and size • xxx= Inductance value in μH, R = decimal point. If no R is present, then third digit equals the number of zeros. • “-R” suffix = RoHS compliant Dimensions-mm Top V iew 9.3 ±0.2 B ottom V iew S ide V iew R ecom m ended P ad Layout 2.54 ±0.2 1 5.21 m ax S chem atic 2.79 ref 1 12.7 ±0.25 U P 2U C xxx w w llyy R 2.54 ±0.2 8.4 ±0.15 7.62 ref 7.62 typ 2 2 2.92 ref Part Marking: UP2UC xxx = Inductance value in μH (R = Decimal point). If no “R” is present, then the third digit equals the number of zeros. wwllyy = Date code Tolerances are ±0.254 mm unless otherwise specified. Do not route traces or vias underneath the inductor Packaging information-mm 1.5 dia. 2.0 4.0 Supplied in tape-and-reel packaging, 600 parts per reel, 13” diameter reel. 1.75 16 11.5 24 ±0.30 5.5 Section A-A 2 www.eaton.com/electronics 13.4 UP2UCxxx wwllyy R 4.40 User direction of feed UP2UCxxx wwllyy R 9.70 UP2UCxxx wwllyy R R = Revision level UP2UC UNI-PAC™ drum core power inductors Technical Data 4369 Effective August 2017 Temperature rise vs total loss T e m p e ra tu re R is e (°C ) 60 50 40 30 20 10 0 0 0 .1 0 .2 0 .3 0 .4 0 .5 0 .6 To ta l L o s s (W ) Core loss vs Bp-p C o r e Lo s s v s . Bp - p 10 5 0 0 kHz 4 0 0 kHz C o re L o ss (W ) 1 3 0 0 kHz 2 0 0 kHz 1 0 0 kHz 0 .1 0 .0 1 0 .0 0 1 0 .0 0 0 1 0 .0 0 0 0 1 100 1000 10000 Bp-p (Gauss) Inductance characteristics % of O C L v s I s a t 110% 100% 90% -4 0 °C 70% +2 5 °C 60% +8 5 °C 50% 40% 30% 20% 180% 160% 140% 120% 100% 80% 60% 40% 0% 20% 10% 0% % of OC L 80% % o f Is at www.eaton.com/electronics 3 UP2UC UNI-PAC™ drum core power inductors Technical Data 4369 Effective August 2017 Solder Reflow Profile TP tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL 25°C Preheat A T smax t TC -5°C Table 1 - Standard SnPb Solder (Tc) Volume mm3 220°C 220°C Table 2 - Lead (Pb) Free Solder (T c) Tsmin ts Package Thickness 2.5mm Time 25°C to Peak Volume mm3 2000 260°C 245°C 245°C Time Reference JDEC J-STD-020 Profile Feature Preheat and Soak • Temperature min. (Tsmin) • Temperature max. (Tsmax) • Time (Tsmin to Tsmax) (ts) Average ramp up rate Tsmax to Tp Liquidous temperature (TL) Time at liquidous (tL) Peak package body temperature (TP)* Time (tp)** within 5 °C of the specified classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25°C to Peak Temperature Standard SnPb Solder 100°C Lead (Pb) Free Solder 150°C 150°C 200°C 60-120 Seconds 60-120 Seconds 3°C/ Second Max. 3°C/ Second Max. 183°C 60-150 Seconds 217°C 60-150 Seconds Table 1 Table 2 20 Seconds** 30 Seconds** 6°C/ Second Max. 6°C/ Second Max. 6 Minutes Max. 8 Minutes Max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 4369 BU09493 August 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
UP2UC-220-R
- 物料型号:UP2UC系列,型号如UP2UC-1RO-R、UP2UC-1R5-R等。 - 器件简介:12.7 mm x 9.5 mm x 5.21 mm鼓形核心,电感范围从1.0 μH到1000 μH,电流范围从0.30 A到9.0 A,采用EAT·N铁氧体材料。 - 引脚分配:文档中提供了推荐焊盘布局和原理图,但未明确列出每个引脚的功能。 - 参数特性:包括OCL(开路电感)、Irms(有效值电流)、Isat(饱和电流)、SRF(自谐振频率)、DCR(直流电阻)和K因子。 - 功能详解:电感器适用于多种应用,如桌面电脑、工作站/服务器、DVD播放器、便携式电源设备、基站、工业电源供应、输出滤波器、测试设备和仪表、降压或升压电感器等。 - 应用信息:适用于多种电子设备和系统,包括但不限于上述应用。 - 封装信息:提供了电感器的尺寸、顶视图、侧视图、底视图和包装信息,如胶带和卷轴包装,每卷600个部件,卷径13英寸。
UP2UC-220-R 价格&库存
很抱歉,暂时无法提供与“UP2UC-220-R”相匹配的价格&库存,您可以联系我们找货
UP2UC-220-R
    UP2UC-220-R
      UP2UC-220-R
      • 600+6.94429600+0.89900
      • 1200+6.548511200+0.84777
      • 1800+6.327721800+0.81918
      • 3000+6.060493000+0.78459
      • 4200+5.890804200+0.76262
      • 6000+5.716316000+0.74003
      库存:2396
      UP2UC-220-R
      • 1+11.834511+1.53208
      • 10+9.7335710+1.26010
      • 100+8.00688100+1.03656
      库存:2396
