DR124-330-R
DR124-330-R
    EATON(伊顿)
    SMD
    FIXED IND 33UH 2.6A 97 MOHM SMD
DR124-330-R 数据手册
Technical Data 4141 Effective April 2014 Supersedes November 2011 Coiltronics DR124 Series Low profile power inductors Applications • Notebook power, LCD panels • Computer, DVD players, and portable power devices • DC-DC Converters • Buck, boost, forward, and resonant converters • Noise filtering and filter chokes Environmental data Product description • Lead free, RoHS compliant • 125°C maximum total temperature operation • Low profile surface mount inductor • 12.5mm x 12.5mm x 4.5mm shielded drum core • Inductance range from 0.47μH to 1000μH • Current range from 24.4 to 0.44 Amps • Frequency range up to 1MHz • Ferrite core material • Storage temperature range (Component): -40°C to +125°C • Operating temperature range: -40°C to +125°C (ambient + self-temperature rise) • Solder reflow temperature: J-STD-020D compliant Packaging: • Supplied in tape and reel packaging, 750 per reel Pb The Coiltronics brand of magnetics (formerly of the Bussmann Division of Cooper Industries) is now part of Eaton’s Electrical Group, Electronics Division. Coiltronics is now part of Eaton Same great products plus even more. Technical Data 4141 DR124 Series Low profile power inductors Effective April 2014 Product specifications Part Number Rated Inductance (μH) OCL1 μH±20% Irms2 Amps Isat3 Amps DCR mΩ @20°C Typ DCR mΩ @20°C Max K-factor4 DR124-R47-R 0.47 0.42 16.0 24.40 2.2 2.7 17.51 DR124-1R0-R 1.0 0.83 13.9 18.00 3.00 3.6 12.50 DR124-1R5-R 1.5 1.37 11.1 14.00 4.75 5.7 9.73 DR124-2R2-R 2.2 2.04 9.1 11.45 5.92 7.1 7.96 DR124-3R9-R 3.9 3.80 7.0 8.40 12.50 15.0 5.84 DR124-4R7-R 4.7 4.88 6.5 7.65 13.50 16.2 5.15 DR124-6R8-R 6.8 6.10 5.6 6.47 18.06 21.7 4.61 DR124-8R2-R 8.2 7.45 5.2 6.22 21.67 26.0 4.17 DR124-100-R 10 8.94 4.5 5.80 23.33 28.0 3.81 DR124-120-R 12 11.5 4.1 4.96 31.67 38.0 3.50 DR124-150-R 15 14.2 3.6 4.62 37.30 44.8 3.02 DR124-180-R 18 16.2 3.4 4.32 46.97 56.4 2.82 DR124-220-R 22 20.7 3.2 3.83 53.99 64.8 2.50 DR124-270-R 27 25.7 2.8 3.44 66.67 80.0 2.24 DR124-330-R 33 31.2 2.6 3.12 80.83 97.0 2.04 DR124-390-R 39 37.3 2.3 2.85 110.00 132.0 1.86 DR124-470-R 47 44.0 2.2 2.63 124.66 149.6 1.72 DR124-560-R 56 54.9 2.0 2.35 144.32 173.2 1.54 DR124-680-R 68 67.1 1.8 2.13 183.33 220.0 1.39 DR124-820-R 82 80.5 1.7 1.94 212.72 255.3 1.27 DR124-101-R 100 95.1 1.5 1.79 256.67 308.0 1.17 DR124-121-R 120 111 1.3 1.65 311.18 373.4 1.08 DR124-151-R 150 146 1.3 1.44 371.02 445.2 0.94 DR124-181-R 180 179 1.1 1.30 501.66 602.0 0.87 DR124-221-R 220 216 1.0 1.15 558.00 669.6 0.77 DR124-271-R 270 256 0.88 1.09 725.00 870.0 0.71 DR124-331-R 330 327 0.83 0.92 825.00 990.0 0.63 DR124-471-R 470 460 0.68 0.74 1242.50 1491.0 0.53 DR124-681-R 680 669 0.56 0.65 1845.83 2215.0 0.45 DR124-821-R 820 825 0.53 0.62 2109.17 2351.0 0.40 DR124-102-R 1000 998 0.44 0.53 2898.00 3477.00 0.37 1. Open Circuit Inductance Test Parameters: 100kHz, 0.25V, 0.0Adc. 2. Irms: DC current for an approximate ∆T of 40°C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed 125°C under worst case operating conditions verified in the end application. 3. Isat Amps peak for approximately 25% rolloff (@25°C). 2 www.eaton.com/elx 4. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K*L*∆I, Bp-p (mT), K: (K factor from table), L: (Inductance in μH), ∆I (Peak to peak ripple current in Amps). 5. Part Number Definition: DR124-xxx-R - DR124 = Product code and size; -xxx = Inductance value in uH; - R = decimal point; If no R is present, third character = # of zeros. - “-R” suffix = RoHS compliant DR124 Series Low profile power inductors Technical Data 4141 Effective April 2014 Dimensions - mm FRONT VIEW BOTTOM VIEW TOP VIEW SCHEMATIC RECOMMENDED PCB LAYOUT 2.05 Typ. 13.8 5.00 1 Typ 2 4.5 Max 12.50 Max 1 1 12.50 Max DR124-### wwllyy R 2 5.50 2 10 3.85 Dimensions are in millimeters. wwlly = Date code, R = Revision level. Packaging information - mm 1.5 dia +0.1/-0.0 1.5 dia min A 1.75 4.0 12.6 Bo B1 Ko 11 DR124-### wwllyy R Ao=13.2 mm Bo=13.2 mm A1=10mm B1=10 mm Ko=5.2 mm A1 Ao SECTION A-A 16.0 24.0 A User direction of feed Parts packaged on 13" Diameter reel, 750 parts per reel. Core loss 100 500kHz 1MHz 10 100kHz 1 Core Loss (W) 300kHz 200kHz 0.1 0.01 0.001 0.0001 1 10 100 1000 Bp-p (m T) www.eaton.com/elx 3 Technical Data 4141 DR124 Series Low profile power inductors Effective April 2014 Temperature rise vs. loss 120 Temperature Rise (°C) 100 80 60 40 20 0 0 0.4 0.8 1.2 1.6 2 Total Pow er Loss (W) Inductance characteristics OCL vs. Isat 120.0 100.0 +85°C % OCL 80.0 +25°C 60.0 40.0 -40°C 20.0 0.0 0.0 20.0 40.0 60.0 % Isat 4 www.eaton.com/elx 80.0 100.0 120.0 DR124 Series Low profile power inductors Technical Data 4141 Effective April 2014 Solder reflow profile TP TC -5°C Temperature 25°C Preheat A Volume mm3 220°C 220°C Table 2 - Lead (Pb) Free Solder (T c) Tsmin Package Thickness 2.5mm ts Time 25°C to Peak Volume mm3 2000 260°C 245°C 245°C Time Reference JDEC J-STD-020D Profile Feature Preheat and Soak Standard SnPb Solder 100°C • Temperature min. (Tsmin) • Temperature max. (Tsmax) • Time (Tsmin to Tsmax) (ts) Average ramp up rate Tsmax to Tp Liquidous temperature (TL) Time at liquidous (tL) Peak package body temperature (TP)* Time (tp)** within 5 °C of the specified classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25°C to Peak Temperature Lead (Pb) Free Solder 150°C 150°C 200°C 60-120 Seconds 60-120 Seconds 3°C/ Second Max. 3°C/ Second Max. 183°C 60-150 Seconds 217°C 60-150 Seconds Table 1 Table 2 20 Seconds** 30 Seconds** 6°C/ Second Max. 6°C/ Second Max. 6 Minutes Max. 8 Minutes Max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. North America Eaton’s Electrical Group Electronics Division 1225 Broken Sound Parkway NW Suite F Boca Raton, FL 33487-3533 Tel: 1-561-998-4100 Fax: 1-561-241-6640 Toll Free: 1-888-414-2645 Eaton’s Electrical Group Electronics Division P.O. Box 14460 St. Louis, MO 63178-4460 Tel: 1-636-394-2877 Fax: 1-636-527-1607 Europe Eaton’s Electrical Group Electronics Division Burton-on-the-Wolds Leicestershire, LE 12 5th UK Phone: +44 (0) 1509 882 600 Fax: +44 (0) 1509 882 786 Eaton’s Electrical Group Electronics Division Avda Santa Eulalia, 290 Terrassa, Barcelona 08223 Spain Phone: +34-93-736-2813 Fax: +34-93-783-5055 Asia Pacific Eaton’s Electrical Group Electronics Division No.2, #06-01 Serangoon North Avenue 5 Singapore 554911 Tel: +65 6645 9888 Fax: +65 6728 3155 The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton’s Electrical Group Electronics Division 114 Old State Road Ellisville, MO 63021 United States www.eaton.com/elx © 2014 Eaton All Rights Reserved Publication No. 4141 — BU-SB14114 April 2014 Eaton is a registered trademark. All other trademarks are property of their respective owners. www.eaton.com/elx 5
DR124-330-R 价格&库存
很抱歉,暂时无法提供与“DR124-330-R”相匹配的价格&库存,您可以联系我们找货
DR124-330-R
  • 1+8.380171+1.08489
  • 10+6.8949810+0.89262
  • 100+5.67101100+0.73416
库存:1445
DR124-330-R
  • 1+7.18560
  • 10+6.02134
  • 100+4.91338
  • 250+4.53487
  • 500+4.27615
  • 750+4.12882
  • 1500+3.89764
  • 2250+3.76828
  • 3750+3.66647
  • 7500+3.53710
库存:750
