Technical Data 4311
Effective November 2015
Supersedes March 2007
SD52
High power density, low profile shielded power inductors
Applications
Desktop computers
Notebook and laptop regulators
Graphics cards
Digital cameras, media devices
Environmental Data
Storage temperature range: -40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise).
Solder reflow temperature: J-STD-020D compliant
Product description
Octagonal shape shielded drum core
Inductance range from 1.2 uH to 150 uH
Current range from 0.28 A to 3.14 A
5.6 mm x 5.2 mm footprint surface mount
package in a 2.0 mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
HALOGEN
Pb HF
FREE
SD52
Technical Data 4311
Product Specifications
Part Number6
OCL1 (μH) ±20%
Part marking
Irms2
(A)
Isat3
(A)
DCR4 (Ω)
typ.
(V us) typ.
SD52-1R2-R
1.20
A
2.33
3.14
0.0279
1.49
SD52-2R2-R
2.20
B
1.98
2.30
0.0385
2.03
SD52-3R5-R
3.50
C
1.73
1.82
0.0503
2.57
SD52-4R7-R
4.70
D
1.63
1.64
0.0568
2.84
SD52-6R8-R
6.80
E
1.39
1.28
0.0777
3.65
SD52-100-R
10.0
F
1.11
1.11
0.1215
4.19
SD52-150-R
15.0
G
0.97
0.88
0.1618
5.27
SD52-220-R
22.0
H
0.86
0.73
0.2042
6.35
SD52-270-R
27.0
J
0.73
0.65
0.2864
7.16
SD52-330-R
33.0
K
0.70
0.61
0.3074
7.70
SD52-470-R
47.0
L
0.58
0.50
0.4465
9.32
SD52-680-R
68.0
M
0.47
0.42
0.6829
11.21
SD52-101-R
100
N
0.39
0.35
1.0000
13.37
SD52-151-R
150
O
0.31
0.28
1.6100
17.00
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc.
2. Irms: DC current for an approximate ∆T of 40 °C without core loss. De-rating is necessary for AC currents.
Temperature rise is dependent upon several factors, including the PCB pad layout, trace thickness and width, air-flow
and proximity to other heat generating components. It is recommended the part temperature not exceed 125 °C under
worst case operating conditions and therefore, the temperature rise should be verified in the end use application.
3. Isat: Peak current for approximately 30% rolloff at +20 °C.
4. DCR limits @ 20°C.
5. Applied Volt-Time product (V-us) across the inductor at 100 kHz necessary to generate a core loss equal to 10% of
the total losses for 40 °C temperature rise.
6. Part number definition: SD52-xxx-R
SD52= Product code and size
-xxx=Inductance value in µH, R= decimal point - If no R is present, then last character equals the number of zeros
Dimensions (mm)
1
SCHEMATIC
RECOMMENDED PCB LAYOUT
Pin #1 indicator
5.2 max
xxxx
52
5.6 m
max
Part marking
0.65
±0.10
1
2.0
2 plcs
2
5.2 max
m
1.3
2 plcs
2
6.0
2.0 max
m
Part Marking: 1st digit= the inductance value per part marking designator, 2nd digit = bi-weekly production date code, 3rd digit = last digit of
the year produced, 4th digit= internal manufacturing code.
52 = the product size code.
Do not route traces or vias underneath the inductor.
Packaging information (mm)
Parts packaged on 13” Diameter reel, 3,500 parts per reel.
4.00
2.00 ± 0.05
1.5 Dia
min.
1.5 Dia.
+0.1/-0.0
A
3.0
Ao=5.72mm
Bo=5.72mm
Ko=2.30mm
Ko
SECTION A-A
B
Bo
5.50
A
Ao
A
80
8.0
Direction of feed
2
www.eaton.com/elx
1.75
10.2
+/-0.3
SD52
Technical Data 4311
DC current vs.temperature
SD52-1R2
90.0
80.0
70.0
60.0
50.0
40.0
30.0
20.0
10.0
0.0
0.0
0.5
1.0
1.5
2.0
IDC (A)
SD52-101
100.0
Temperature Rise (Deg. C)
100.0
2.5
3.0
3.5
90.0
80.0
70.0
60.0
50.0
40.0
30.0
20.0
10.0
0.0
0.00
4.0
0.10
0.20
0.30
0.40
IDC (A)
0.50
0.60
0.70
Inductance characteristics
OCL vs Isat
SD52
100
90
80
OCL (%)
70
60
50
40
30
40
50
60
70
80
% of Isat
90
100
110
120
130
140
Core loss
% of Losses from Irms (maximum)
Irms DERATING WITH CORE LOSS
% of applied V us
www.eaton.com/elx
3
SD52
Technical Data 4311
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“SD52-101-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3500+11.019943500+1.42369
- 7000+10.825857000+1.39862
- 国内价格 香港价格
- 1+17.973031+2.32198
- 10+14.7928610+1.91113
- 100+12.16285100+1.57135
- 1000+10.700121000+1.38238
- 国内价格
- 1+2.98286
- 200+1.15442
- 500+1.11381
- 1000+1.09372
