FP1107R1-R23-R
FP1107R1-R23-R
    EATON(伊顿)
    SMD,11x7.2mm
    固定电感器 Nonstandard 230nH ±10% 55A 0.29mΩ
FP1107R1-R23-R 数据手册
Technical Data 4342 Effective June 2017 Supersedes August 2009 FP1107 High frequency, high current power inductors Applications • • • • • • • SMD Device Environmental data • Product features • • • • • • • 7.2 x 11.0 x 7.5mm surface mount package Ferrite core material High current carrying capacity, low core losses Controlled DCR tolerance for sensing circuits Inductance range from 70nH to 510nH Current range from 18 amps to 140 amps Frequency range up to 2MHz Multi-phase regulators Voltage Regulator Module (VRM) Desktop and server VRMs and EVRDs Data networking and storage systems Graphics cards and battery power systems Point-of-load modules DCR sensing • • Storage temperature range (component): -40 °C to +125 °C Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) Solder reflow temperature: J-STD-020 (latest revision) compliant Pb HF FREE HALOGEN  Technical Data 4342 Effective June 2017 Product Specifications Part Number7 R1 Version FP1107R1-R07-R FP1107R1-R12-R FP1107R1-R15-R FP1107R1-R23-R FP1107R1-R30-R FP1107R1-R40-R FP1107R1-R51-R R2 Version FP1107R2-R07-R FP1107R2-R12-R FP1107R2-R15-R FP1107R2-R23-R FP1107R2-R30-R FP1107R2-R40-R FP1107R2-R51-R OCL1 ± 10% (nH) FLL2 Min. (nH) Irms3 (Amps)Isat14 @ 25°C (Amps) Isat25 @ 125°C (Amps) DCR (mΩ) @ 20°C 70 120 150 230 300 400 510 50 86 108 166 217 288 364 70 120 150 230 300 400 510 50 86 108 166 217 288 364 55 140 90 70 45 35 25 18 123 72 56 36 28 20 14.5 42 140 90 70 45 35 25 18 123 72 56 36 28 20 14.5 K-factor6 0.29 ± 8% 361.1 361.1 361.1 361.1 361.1 361.1 361.1 0.47 ± 6.4% 363.3 363.3 363.3 363.3 363.3 363.3 363.3 4 Isat1: Peak current for approximately 20% rolloff at +25°C. 5 Isat2: 1 Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.10Vrms, 0.0Adc 2 Full Load Inductance (FLL) Test Parameters: 100kHz, 0.1Vrms, Isat1 5 Peak current for approximately 20% rolloff at +125°C. 3 Irms: DC current for an approximate temperature rise of 40°C without core loss. Derating is necessary for AC currents. PCB pad layout, trace thickness and width, air-flow and proximity of other heat generating components will affect the temperature rise. It is recommended the part temperature not exceed 125°C under worst case operating conditions verified in the end application. 6 K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI * 10-3, Bp-p : (Gauss), K: (K-factor from table), L: (inductance in nH), ΔI (peak-to-peak ripple current in amps). 7 Part Number Definition: FP1107Rx-Rxx-R • Rx is the DCR indicator • FP1107 = Product code and size • Rxx= Inductance value in μH, R = decimal point • “-R” suffix = RoHS compliant Dimensions- mm T op V iew B ottom V iew S ide V iew FP1107R 1-R = 7.50 max FP1107R 2-R = 7.20 max 7.2 m ax 1 b 1.90 +/-0.15 R ecom m ended P ad Layout S chem atic 2.1 1 3.1 1 1107R x R xx 11.0 m ax 5.0 5.8 typ 2 w w llyy R C 2 2 a The nominal DCR is measured from point “a” to point”b.” Part Marking: 1107Rx (Rx = DCR Indicator) Rxx = Inductance value in μH. (R = Decimal point) wwllyy = Date code R = Revision level Packaging information - mm 1.5 dia. 4.0 2.0 1.75 1 11.5 11.1 24 +/-0.3 1107Rx Rxx wwllyy R 2 7.6 1.5 dia. 12.0 Section A-A User direction of feed Supplied in tape-and-reel packaging, 640 parts per reel, 13” diameter reel. 2 www.eaton.com/electronics Section B-B 7.4 FP1107 High frequency, high current power inductor Technical Data 4342 Effective June 2017 Temperature rise vs total loss T e m p e ra tu re R is e (°C ) 80 60 40 20 F P 1107R 1 F P 1107R 2 0 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 T o ta l L o s s (W ) Core loss vs Bp-p 1MHz 10 500kHz 300kHz 200kHz 1 Co re L o ss (W ) 100kHz 0 .1 0 .0 1 0 .0 0 1 100 1000 10000 B p - p (G a u ss) Inductance characteristics % o f O C L v s % o f I sa t1 100% -40°C % of OCL 80% + 25°C 60% 40% + 125°C 20% 0% 0% 20% 40% 60% 80% 100% 120% 140% % o f I sa t1 www.eaton.com/electronics 3 FP1107 High frequency, high current power inductor Technical Data 4342 Effective June 2017 Solder Reflow Profile TP TC -5°C Temperature TL 25°C Preheat A T smax Table 1 - Standard SnPb Solder (Tc) tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s t Volume mm3 220°C 220°C Table 2 - Lead (Pb) Free Solder (T c) Tsmin Package Thickness 2.5mm ts Time 25°C to Peak Volume mm3 2000 260°C 245°C 245°C Time Reference JDEC J-STD-020 Profile Feature Preheat and Soak • Temperature min. (Tsmin) • Temperature max. (Tsmax) • Time (Tsmin to Tsmax) (ts) Average ramp up rate Tsmax to Tp Liquidous temperature (TL) Time at liquidous (tL) Peak package body temperature (TP)* Time (tp)** within 5 °C of the specified classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25°C to Peak Temperature Standard SnPb Solder 100°C Lead (Pb) Free Solder 150°C 150°C 200°C 60-120 Seconds 60-120 Seconds 3°C/ Second Max. 3°C/ Second Max. 183°C 60-150 Seconds 217°C 60-150 Seconds Table 1 Table 2 20 Seconds** 30 Seconds** 6°C/ Second Max. 6°C/ Second Max. 6 Minutes Max. 8 Minutes Max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 4342 June 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
FP1107R1-R23-R 价格&库存
很抱歉,暂时无法提供与“FP1107R1-R23-R”相匹配的价格&库存,您可以联系我们找货
FP1107R1-R23-R
    FP1107R1-R23-R
    • 1+15.777991+2.02624
    • 10+13.0040510+1.67001
    • 100+10.69353100+1.37329
    库存:6856
