Technical Data 4140
Effective August 2017
Supersedes September 2011
SD8328
Low profile shielded drum core power inductors
Applications
Buck or boost inductor
Noise filtering output filter chokes
Notebook and laptop power/display
LCD Monitors/displays/televisions
Battery chargers, LCD bias supplies
Battery and Industrial power systems
Computer, DVD and media players
Portable power devices
DC-DC converters
Environmental data
Product features
9.5 mm x 8.3 mm x 3.0 mm surface mount
inductor
Ferrite core material
Inductance range from 2.7 µH to 100 µH
Current range from 0.8 A to 6.6 A
Frequency range up to 1 MHz
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Technical Data 4140
Product specifications
Rated
Inductance (µH)
2.5
3.3
4.7
7.3
10
15
22
33
47
68
100
Part Number
SD8328-2R5-R
SD8328-3R3-R
SD8328-4R7-R
SD8328-7R3-R
SD8328-100-R
SD8328-150-R
SD8328-220-R
SD8328-330-R
SD8328-470-R
SD8328-680-R
SD8328-101-R
OCL1
µH±30%
2.7
3.4
5.0
7.6
9.1
14.5
21.1
31.9
44.9
64.2
97.0
Irms2
(A)
6.6
6.1
4.5
3.4
3.3
2.35
1.85
1.45
1.30
0.98
0.80
1. Open Circuit Inductance Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc.
2. Irms: DC current for an approximate ΔT of 40 °C without core loss. Derating is necessary for AC
currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating
components will affect the temperature rise. It is recommended that the temperature of the part
not exceed +125 °C under worst case operating conditions verified in the end application.
3. Isat Amps peak for approximately 35% rolloff (@ +25 °C)
Isat3
(A)
4.5
4.0
3.6
2.9
2.6
2.0
1.7
1.4
1.2
1.0
0.8
DCR mΩ
@ +20 °C Typ
12
14
19
30
36
53
76
120
150
220
330
DCR mΩ
@ +20 °C Max
15.6
18.0
24.7
39
45
69
99
156
194
286
430
K-factor4
43
33
23
15
11
7.2
4.9
3.3
2.3
1.6
1.1
4. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K*L*ΔI, Bp-p (mT), K: (K factor from table), L: (Inductance in µH), ΔI
(Peak to peak ripple current in Amps).
5. Part Number Definition: SD8328-xxx-R
SD8328 = Product code and size; -xxx = Inductance value in µH;
R = decimal point; If no R is present, third character equals number of zeros.
-R suffix = RoHS compliant
Dimensions-mm
BOTTOM VIEW
TOP VIEW
1
2.5
typ
8.3
max
FRONT VIEW
RECOMMENDED PCB LAYOUT
SCHEMATIC
2.9
1.2
typ
3.0
max
1
1.8
XXX
wwlly R
9.5
max
6.3
typ
5.7
LEFT VIEW
2
2
Part Marking: xxx = Inductance value in μH. (R = Decimal point). If no R is present, third character = number of zeros
Do not route traces or vias underneath the inductor
Packaging information-mm
Supplied in tape-and-reel packaging, 1280 parts per reel, 13” diameter reel.
2
www.eaton.com/electronics
wwlly - or - wwllyy = Date code
R = Revision level
SD8328
Technical Data 4140
Temperature rise vs total loss
160
Temperature Rise (ºC)
140
120
100
80
60
40
0.2
0.4
0.6
0.8
1.0
Total Power Loss (W)
Core loss vs Bp-p
10
500kHz
300kHz
1MHz
200kHz
1
Core Loss (W)
100kHz
0.1
0.01
0.001
0.0001
1
10
100
1000
Bp-p (mT)
Inductance characteristics
OCL Vs. Isat
120.0%
100.0%
% OCL
80.0%
60.0%
+85 Deg.C
40.0%
+25 Deg.C
20.0%
-40 Deg.C
0.0%
0.0%
20.0%
40.0%
60.0%
80.0%
100.0%
120.0%
% Isat
3
SD8328
Technical Data 4140
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4140 BU-SB111112
August 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“SD8328-100-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1280+11.345321280+1.45527
- 2560+10.700802560+1.37260
- 3840+10.341413840+1.32650
- 6400+10.174716400+1.30511
- 国内价格
- 1280+10.26829
- 2560+9.85756
- 3840+9.69327
- 6400+9.36468
- 15360+9.28253
