FPV1507-500-R
FPV1507-500-R
    EATON(伊顿)
    固定电感器 ±10% - 20A 500nH 14.60 x 13.50mm 非标准
FPV1507-500-R 数据手册
Technical Data 10347 Effective May 2016 Supersedes April 2015 FPV1507 Dual conductor high current power inductor Applications • Multi-phase power supplies • Compatible with Picor® Cool-Power® ZVS Buck-Boost Regulator Family (Picor part number series PI37xx) Environmental Data Description • Dual conductor, two-turn construction • Magnetically shielded • 15.1 mm x 8.6 mm footprint surface mount package in a 6.6 mm height • Ferrite core material • Halogen free, lead free, RoHS compliant • Storage temperature range (component): -55 °C to +125 °C • Operating temperature range: -55 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020D compliant HALOGEN Pb HF FREE Picor® and Cool-Power® are trademarks of Vicor Corporation. FPV1507 Dual conductor high current power inductor  Technical Data 10347 Effective May 2016 Product Specifications Part Number5 OCL1 (nH) ±10% Irms2 (A) Isat3 (A) DCR4 (mΩ) @ 20°C Q minimum reference only FPV1507-500-R 500 20 40 1.15 ± 0.173 135 FPV1507-650-R 650 20 31 1.15 ± 0.173 135 1. Open Circuit Inductance (OCL) Test Parameters: 1.0 MHz, 0.1 Vrms, 0.0 Adc, +25 °C (Pins 1-3, short 2-4) 2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed 125 °C under worst case operating conditions verified in the end application. 3. Isat : Peak current for approximately 2% rolloff @ +25 °C 4. DCR measured from Pins (1-2) and (3-4) 5. Part Number Definition: FPV1507-xxx-R FPV1507 = Product code and size xxx= Inductance value in nH, -R suffix = RoHS compliant 6. Q test parameters: 1 MHz, 0.1 Vrms, +25 ºC, (Pins 1-3, short 2-4) Note: Hipot: 200 Vdc minimum for 2 seconds, 0.1 mA pins (1-2) to (4-3) Dimensions (mm) Recommended Pad Layout 14.6 ±0.5 4 1 FPV1507-XXX wwllyy R 10.1 ±0.5 3 2 1.15 ±0.1 8.3 ±0.3 0.7 ±0.2 6.3 ±0.30 A 1.4 4 1 2.3 ±0.3 B Part marking: FPV1507-XXX (XXX= inductance value in nH), wwllyy=date code, R=revision level Soldering surfaces to be coplanar within 0.1 millimeters Pins 2 & 4 are connected through the PCB trace www.eaton.com/elx Schematic 0.50 3 2 2.60 DCR measured from point “A” to point “B” 2 14.6 2.60 0.56 Resist area 3.30 1 4 2 3 FPV1507 Dual conductor high current power inductor Technical Data 10347 Effective May 2016  Packaging information (mm) Supplied in tape and reel packaging, 600 parts per 13” diameter reel 4.0 1.5 dia 2.0 A 1.5 dia 1.75 FPV1507-XXX wwllyy R 11.5 14.90 6.6 24.0 +/-0.3 8.60 Section A – A 16.0 A User direction of feed Inductance characteristics FPV1505-500-R 110% FPV1507-650-R 100% -55°C 90% 70% 60% +25°C 50% 40% 30% +125°C 20% 10% 0% 0 5 10 15 20 25 30 35 40 45 50 55 60 65 IDC (A) % of OCL % of OCL 80% 110% 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% -55°C +25°C +125°C 0 5 10 15 20 25 30 35 40 45 50 55 IDC (A) www.eaton.com/elx 3 FPV1507 Dual conductor high current power inductor  Technical Data 10347 Effective May 2016 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb Solder (Tc) Package Thickness Volume mm3
FPV1507-500-R 价格&库存
很抱歉,暂时无法提供与“FPV1507-500-R”相匹配的价格&库存,您可以联系我们找货
FPV1507-500-R
  • 600+17.97285600+2.32609
  • 1200+16.951211200+2.19387
  • 1800+16.381531800+2.12014
  • 3000+15.792923000+2.04396
库存:597
FPV1507-500-R
  • 1+17.842211+2.30919
  • 10+14.7021910+1.90280
  • 100+12.09007100+1.56473
库存:597
FPV1507-500-R
  • 600+15.73909
  • 15000+11.61866
库存:57000
FPV1507-500-R
  • 1+17.410801+2.21750
  • 10+17.2475010+2.19670
  • 100+16.38450100+2.08680
  • 600+15.78980600+2.01100
  • 1200+15.195101200+1.93530
  • 4800+14.856904800+1.89220
库存:575
