Technical Data 4328
Effective October 2015
Supersedes May 2008
HC1
High current inductor
Applications
Product description
Distributed power systems DC-DC converters
General-purpose low voltage supplies
Computer systems
Servers
Industrial Equipment
Data networking and storage systems
Environmental data
Designed for high current, low voltage
applications
Storage temperature range (component):
-40°C to +125°C
Low DCR, high efficiency
Foil construction for higher frequency circuit
designs
Operating temperature range: -40°C to +125°C
(ambient + self-temperature rise).
Solder reflow temperature: J-STD-020D
Frequency range 1kHz to 1MHz
Ferrite core material
Pb
HC1
Technical Data 4328
Product specifications
Part number
OCL1 (μH) ±15%
lrms2 amps (approx.)
lsat3 amps (approx.)
DCR (Ω) maximum @ 20°C
Volt-μsec4 (V μs) ref.
HC1-R22-R
0.218
51.42
40.5
0.00036
1.83
HC1-R30-R
0.291
51.42
31.8
0.00036
1.83
HC1-R57-R
0.572
37.83
33.4
0.00068
3.66
HC1-R87-R
0.866
28.01
31.0
0.00123
5.49
HC1-1R0-R
1.12
28.01
25.4
0.00123
5.49
HC1-1R7-R
1.66
22.30
22.2
0.0020
7.33
HC1-2R3-R
2.29
22.30
16.7
0.0020
7.33
HC1-3R6-R
3.59
16.76
13.4
0.0035
9.16
HC1-5R1-R
5.15
12.79
11.2
0.0057
10.99
HC1-7R8-R
7.85
12.79
6.7
0.0057
10.99
HC1-100-R
10.5
12.79
5.3
0.0057
10.99
1. OCL (Open Circuit Inductance) Test parameters: 300kHz, .25Vrms, 0.0Adc & Isat.
2. Irms Amps for approximately ΔT of 40°C. DC current for an approximate ΔT of 40°C without
core loss. Derating is necessary for AC currents. It is recommended that the temperature of the part
not exceed 125°C under worst case operating conditions verified in the end application.
3. Isat Amps Peak for approximately 30% rolloff @ 20°C.
4. Applied Volt-Time product (V-μs) across the inductor. This value represents the applied V-μs at 200kHz
necessary to generate a core loss equal to 10% of the total losses for 40°C temperature rise.
See Core Loss Graph.
5. Part number definition - HC1-xxx-R:
HC1 = Product code and size
-xxx = Inductance value
R = Decimal point (if no “R” is present, last character equals number of zeros )
-R Suffix = RoHS compliant
Dimensions–mm
Top View
Side View
Recommended Pad Layout
Front View
4.5
4.5
13.0
Max.
1
10.0
Max.
4.9 Typ.
1
10.0
2
2
14.5
2.2
Typ.
13.0
Max.
Schematic
(Componenet Side)
wwllyy = Date code R = Revision level
Packaging information (mm)
Supplied in tape and reel packaging, 250 parts per reel, 13” diameter reel.
4.0
1.5 dia
+0.1/-0.0
2.0
1.5 dia
min
A
1.7
1
11.5
HC1-XXX
wwllyyR
13.4
24.0
+/-0.3
2
2.0
10.3
SECTION A-A
20.0
A
13.4
User direction of feed
2
www.eaton.com/elx
HC1
Technical Data 4328
Core loss
Irms Derating With Core Loss
50
70
Hz
50
k
100
k
Hz
80
400
k
300 Hz
kH
z
200
kH
z
% of Losses from Irms (maximum)
60
90
92
94
95
96
97
98
99
10
40
50
60
70
80 90
100
200
300
400
500
600
800
1000
% of Applied Volt-μ-Seconds
www.eaton.com/elx
3
HC1
Technical Data 4328
Inductance characteristics
HC1 Inductor (R22, 7R8)
100
100
90
90
80
80
OCL (%)
OCL (%)
HC1 Inductor (R87)
70
70
60
60
50
40
50
60
70
80
90
100
110
50
120
40
50
% of I sat
100
90
90
80
80
OCL (%)
OCL (%)
100
70
40
50
60
70
80
90
100
110
50
120
40
50
60
70
% of I sat
% of I sat
HC1 Inductor (R30, 100)
HC1 Inductor (1R0)
100
110
120
80
90
100
110
120
80
90
100
110
120
100
90
90
80
OCL (%)
OCL (%)
90
60
100
70
80
70
60
60
40
50
60
% of Isat
4
80
70
60
50
70
HC1 Inductor (R57, 2R3, 3R6, 5R1)
HC1 Inductor (1R7)
50
60
% of I sat
www.eaton.com/elx
70
80
90
100
110
120
50
40
50
60
% of I sat
70
HC1
Technical Data 4328
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HC1-1R7-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+17.47688
- 10+11.94400
