E74D350LPN482MA41M
E74D350LPN482MA41M
    NCC(贵弥功)
    DIP
    CAP ALUM 4800UF 20% 35V SCREW
E74D350LPN482MA41M 数据手册
UNITED CHEMI-CON U N ITE D CH EMI- CON CUSTOMER: CUSTOMER PN: UCC PN: UCC MAXCIM NO.: TECHNICAL DATA SHEET DIMENSIONAL CRITERIA mm X in E74D350LPN482MA41M 86552 ELECTRICAL CRITERIA CAPACITANCE (120Hz/25°C): CAPACITANCE TOLERANCE: RATED VDC SURGE VDC (30 sec): MAX. ESR (120Hz/25°C): MAX. ESR (20-40kHz/25°C): MAX. IRMS (120Hz/85°C): MAX. IRMS (20-100kHz/85°C): MAX. DCL (VDC/5:00/25°C): MECHANICAL CRITERIA MAX. VIBRATION: TERMINAL THREAD THREAD DEPTH MAX. TERMINAL TORQUE: TYP. WEIGHT: 4800 ± 20 35 44 26.6 11.7 6.7 9.3 1.640 F % V V m m A A mA 10-55Hz 10-32 5.6 2 43 10g +105 -55 2000 ± 20 150 1.640 1000 ± 15 130 3.280 °C °C Hrs % % mA Hrs % % mA OPERATING CRITERIA MAX. TEMPERATURE: MIN. TEMPERATURE: LOAD LIFE (VDC/105°C): MAX. CAP. (measured value): MAX. ESR (specified value): MAX. DCL (VDC/5:00/25°C): SHELF LIFE (85°C): MAX. CAP. (measured value): MAX. ESR (specified value): MAX. DCL (VDC/5:00/25°C): D L H F J S 1.375 1.625 1.719 0.500 0.063 0.313 - 0.040 0.080 0.080 0.016 0.040 0.010 + + + + + + 0.040 0.080 0.080 0.016 0.040 0.010 MARKING N I PP ON CHEM I-C ON 747D 105°C 4800uF 35V Date Code + positive mm Nm grams 10-32 IRMS FREQUENCY MULTIPLIERS 120Hz 400Hz 1kHz 5k-100kHz 0.90 0.95 0.98 1.00 IRMS AMBIENT MULTIPLIERS 25°C 45°C 65°C 85°C 2.00 1.70 1.40 1.00 105°C 0.50 SPECIAL RoHS compliant ISSUE: 1 DATE: 2/2/00 TDS NO.: AUTHOR: DATE: TDS-07-0420 TMASH 13-JUNE-07
E74D350LPN482MA41M 价格&库存
很抱歉,暂时无法提供与“E74D350LPN482MA41M”相匹配的价格&库存,您可以联系我们找货
