ROB-10V682MK9#
ROB-10V682MK9#
    ELNAAMERICA
    DIP
    6800µF 10V Aluminum Capacitors Radial, Can 1000 Hrs @ 85°C
ROB-10V682MK9# 数据手册
ROB ROB MINIATURE ALUMINUM ELECTROLYTICCAPACITORS CAPACITORSFOR FORAUDIO AUDIO MINIATURE ALUMINUM ELECTROLYTIC ® ® For Audio GREEN CAP Miniature Standard Capacitors for Audio TONEREX ●   ● Adopting the newly developed formation method and composite electrolytic paper for audio application has reduced distortion, achieving high-quality sound. All lead wires are oxygen-free copper wires to reduce distortion. Marking color : Gold print on a black sleeve Specifications Item Performance ー40 to +85 ±20 Less than 0.01CV or 4 whichever is larger (after 5 minutes) C : Rated capacitance (µF) ; V: Rated voltage (V) Category temperature range (℃) Tolerance at rated capacitance (%) Leakage current (µA) Rated voltage (V) tanδ (max.) Tangent of loss angle (tanδ) 6.3 0.24 10 0.20 16 0.16 35 0.12 50 0.10 63 0.09 100 0.08 (20℃,120Hz) 0.02 is added to every 1000µF increase over 1000µF Test time Leakage current Percentage of capacitance change Tangent of the loss angle Endurance (85℃) (Applied ripple current) Shelf life (85℃) Applicable standards 1000 hours The initial specified value or less Within ±20% of initial value 150% or less of the initial specified value Test time : 1000 hours. Other have same as endurance. Voltage application treatment : According to JIS C5101 -1 JIS C5101-1, -4 1998 (IEC 60384-1 1992, -4 1985) Outline Drawing Coefficient of Frequency for Rated Ripple Current Unit : mm Sleeve Vent (except φ5) Rated voltage (V) φd±0.05 copper wire (tinned) Frequency (Hz) CV (µF×WV) 6.3 to 16 F±0.5 φD±0.5max. L+αmax. 50 to 100 5 min. 15min. 6.3 2.5 0.6 α 8 3.5 0.6 10 5.0 0.6 12.5 5.0 0.8 120 1k 10k 100k 0.8 0.8 0.8 0.8 0.8 1 1 1 1 1 1.1 1.5 1.2 1.6 1.2 1.2 1.7 1.3 1.9 1.3 1.2 1.7 1.3 1.9 1.3 Part numbering system (example : 25V100µF) ROB 5 2.0 0.6 50・60 All CV value ≤1000 1000< ≤1000 1000< 25 to 35 φD F φd 25 0.14 (20℃,120Hz) (20℃) 16 7.5 0.8 ̶ Series code 18 7.5 0.8 25 V Rated voltage symbol 101 M G3 # ̶ Rated capacitance Capacitance symbol tolerance symbol Taping (Forming) symbol Casing symbol 2.0 (φ10,16L or less : 1.5) 1.5 Case symbol Case φD×L (mm) 5×11 6.3×11 8×11.5 Casing Symbol E3 F3 G3 Case φD×L (mm) 10×12.5 10×16 10×20 Casing Symbol H3 H4 H5 Case Case Casing Symbol φD×L (mm) 16×31.5 Ⅰ5 16×35.5 Ⅰ6 18×35.5 J6 18×40 φD×L (mm) 12.5×20 12.5×25 16×25 Casing Symbol J7 J8 K8 K9 6.3 Rated voltage (V) Rated capacitance (µF) Item Case φD×L (mm) 10 ̶ ̶ ̶ ̶ ̶ 22 ̶ 1 2.2 3.3 4.7 10 Case Rated ripple current (mArms) ̶ ̶ ̶ ̶ ̶ ̶ φD×L (mm) ̶ ̶ ̶ ̶ ̶ 16 Rated ripple current (mArms) ̶ ̶ ̶ ̶ ̶ 5×11 50 Case φD×L (mm) ̶ ̶ ̶ ̶ 25 Rated ripple current (mArms) ̶ ̶ ̶ ̶ Case 35 Rated ripple current φD×L (mm) ̶ ̶ ̶ (mArms) ̶ ̶ ̶ 5×11 25 Case φD×L (mm) ̶ ̶ ̶ ̶ 50 Rated ripple current (mArms) ̶ ̶ ̶ ̶ Case φD×L (mm) 63 Rated ripple current (mArms) Case φD×L (mm) ̶ ̶ ̶ 100 Rated ripple current (mArms) ̶ ̶ ̶ Case φD×L (mm) Rated ripple current (mArms) 5×11 10 5×11 20 5×11 25 5×11 35 5×11 35 6.3×11 60 8×11.5 70 8×11.5 100 10×12.5 120 5×11 35 5×11 40 5×11 45 5×11 50 5×11 60 5×11 60 6.3×11 75 6.3×11 80 6.3×11 5×11 15 5×11 25 5×11 30 6.3×11 40 33 5×11 55 5×11 65 5×11 70 6.3×11 80 90 8×11.5 110 8×11.5 115 10×16 160 47 5×11 65 5×11 75 6.3×11 95 6.3×11 100 8×11.5 120 8×11.5 130 10×12.5 165 10×20 210 100 6.3×11 110 6.3×11 120 8×11.5 150 165 10×12.5 210 10×16 250 10×20 285 12.5×20 340 620 8×11.5 220 8×11.5 185 8×11.5 200 10×12.5 265 10×16 310 10×20 365 12.5×20 440 12.5×20 470 16×25 330 10×12.5 265 10×12.5 290 10×16 350 10×20 410 12.5×20 500 12.5×20 540 12.5×25 620 16×31.5 820 470 10×12.5 315 10×16 380 10×20 460 12.5×20 550 12.5×25 640 16×25 800 16×25 840 18×35.5 1000 1000 10×20 550 12.5×20 670 12.5×25 810 16×25 1000 16×25 1050 2200 12.5×25 980 16×25 1200 16×25 1350 16×35.5 1650 18×35.5 1900 3300 16×25 1300 16×31.5 1600 16×35.5 1800 18×40 2100 4700 16×31.5 1700 16×35.5 1900 18×35.5 2400 6800 16×35.5 2100 18×40 2600 18×40 2800 10000 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ 16×31.5 ̶ ̶ ̶ ̶ ̶ 1200 ̶ ̶ ̶ ̶ ̶ 18×35.5 ̶ ̶ ̶ ̶ ̶ 1500 ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ ̶ (Note) Rated ripple current : 85℃, 120Hz NOTE : Design, ‌ Specifications are subject to change without notice. It is recommended that you shall obtain technical specifications from ELNA to ensure that the component is suitable for your use. 171 CAT.No.2015/2016E FOR AUDIO ALUMINUM Standard Ratings
ROB-10V682MK9# 价格&库存
很抱歉,暂时无法提供与“ROB-10V682MK9#”相匹配的价格&库存,您可以联系我们找货
