FKN1WSJR-52-3R9
FKN1WSJR-52-3R9
    YAGEO(国巨)
    AXIAL-D3.5X9MM
    插件电阻 - 3.9Ω ±5% 1W -
FKN1WSJR-52-3R9 数据手册
Through-hole resistors Fusible & Flame-Proof Type Wirewound Resistors Normal & Miniature Style [ FKN Series ] FEATURES Power Rating 1/2W, 1W, 2W, 3W, 4W, 5W, 7W Resistance Tolerance ±1%, ±5% T.C.R. ±350ppm/°C Flameproof Multi-layer Coating Meets UL-94V-0 Flameproof Feature Meets Overload Test UL-1412 DERATING CURVE INTRODUCTION The resistor element is a resistive wire which is wound in a single layer on a ceramic rod, with tinned connecting wires of electrolytic copper welded to the end-caps. The ends of the resistive wire are connected to the caps by welding. The resistors are coated with layers of green color flame-proof lacquer. Overload protection without risk of fire. Wide range of overload currents. For resistors operated in ambient temperatures above 40°C, power rating must be derated in accordance with the curve below. Rated Load (%) 40 70 155 275 °C 100 3W-7WS 1/2WS-3WS 80 60 40 20 50 Ambient Temperature (°C) 100 150 200 250 300 FUSING CHARACTERISTICS R≤2.0Ω Fusing time within 60 seconds at 36 times of rated power R>2.0Ω Fusing time within 60 seconds at 25 times of rated power Fusing residual resistive value at least 100 times rated resistance DIMENSIONS Unit: mm ød H L øD 5th color code: white STYLE DIMENSION Normal Miniature L øD H ød - FKN50S/FKN1SS 6.3±0.5 2.5±0.3 28±2.0 0.55±0.05 FKN-50 FKN1WS/FKN2SS 9.0±0.5 3.5±0.3 26±2.0 0.55±0.05 FKN100 FKN2WS 11.5±1.0 4.6±0.5 35±2.0 0.8±0.05 FKN200 FKN3WS 15.5±1.0 5.2±0.5 33±2.0 0.8±0.05 FKN5WS 17.5±1.0 6.2±0.5 32±2.0 0.8±0.05 FKN7WS 24.5±1.0 8.2±0.5 38±2.0 0.8±0.05 FKN300 FKN400 FKN500 Note: FKN1WS ( for MB Type ) ød = 0.8±0.05 mm 47 ELECTRICAL CHARACTERISTICS Normal STYLE STYLE FKN-50 FKN100 FKN200 Power Rating at 40°C Power Rating at 70°C 1/2W Maximum working voltage PxR Voltage Proof on Insulation 300V Resistance Range (±1%) Resistance Range (±5%) 0.5Ω - 47Ω Operating Temp. Range -40°C to +155°C Temperature Coefficient ±350ppm/°C FKN300 FKN400 FKN500 3W 4W 5W 1W 2W 0.5Ω - 100Ω 0.47Ω - 150Ω 0.56Ω - 330Ω 1Ω - 620Ω 0.5Ω - 100Ω 0.47Ω - 150Ω 0.56Ω - 330Ω 1Ω - 620Ω Note: Special value is available on request MINIATURE STYLE STYLE FKN50S FKN1WS/FKN1SS FKN2WS/FKN2SS FKN3WS Power Rating at 40°C Power Rating at 70°C 1/2W Maximum working voltage PxR Voltage Proof on Insulation 200V Resistance Range (±1%) Resistance Range (±5%) 2.5Ω - 22Ω Operating Temp. Range -40°C to +155°C Temperature Coefficient ±350ppm/°C 1W FKN5WS FKN7WS 5W 7W 2W 3W 0.47Ω - 100Ω 0.47Ω - 150Ω 0.47Ω - 240Ω 0.56Ω - 330Ω 1Ω - 620Ω 0.47Ω - 100Ω 0.47Ω - 150Ω 0.47Ω - 240Ω 0.56Ω - 330Ω 1Ω - 620Ω 300V Note: Special value is available on request ENVIRONMENTAL CHARACTERISTICS PERFORMANCE TEST TEST METHOD APPRAISE Short Time Overload IEC 60115-1 4.13 10 times rated power for 5 Sec. ±2.0%+0.05Ω Voltage Proof on Insulation IEC 60115-1 4.7 In V-Block for 60 sec., test voltage as above table No Breakdown Temperature Coefficient IEC 60115-1 4.8 Between -40°C to +155°C By type Insulation Resistance IEC 60115-1 4.6 in V-block for 60 Sec. >100MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of Marking IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of coatings and markings Robustness of Terminations IEC 60115-1 4.16 Direct load for 10 Sec. in the direction of the terminal leads ≥2.5kg (24.5N) Damp Heat Steady State IEC 60115-1 4.24 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV ±5.0%+0.05Ω Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±5.0%+0.05Ω Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  +155°C  Room Temp. (5 cycles) ±1.0%+0.05Ω Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body ±1.0%+0.05Ω Accidental Overload Test IEC 60115-1 4.26 4 times RCWV for 1 Min. No evidence of flaming or arcing Note: Rated Continuous Working Voltage (RCWV) =  Power Rating x Resistance Value or Max. working voltage listed above, whichever less. Revision: 2020
FKN1WSJR-52-3R9 价格&库存
很抱歉,暂时无法提供与“FKN1WSJR-52-3R9”相匹配的价格&库存,您可以联系我们找货
FKN1WSJR-52-3R9
  • 1+2.026521+0.26268
