EMZR350ADA331MHA0G
EMZR350ADA331MHA0G
    NCC(贵弥功)
    DIP
    330µF 35V Aluminum Capacitors Radial, Can - SMD 80 mOhm @ 100kHz 2000 Hrs @ 105°C
EMZR350ADA331MHA0G 数据手册
Tentative No.840A/Mar.2014 Vertical Surface Mount Type Aluminum Electrolytic Capacitors Solvent resistant type RoHS Compliant SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance dc M Leakage Current Dissipation Factor (tan ) dc tan Low Temperature Characteristics (Max. Impedance Ratio) dc Endurance . of the initial value Shelf Life of the initial value Surge Voltage Test . dc dc Appearance of the initial value DIMENSIONS mm ( W W Code D A 7.7 8 6.6 C W P 6.6 1.9 1.1 1.1 MARKING 3Q 330 VZR dc A 16 C E H Please contact us for mass production schedule. NIPPON CHEMI-CON CORPORATION 1 Tentative No.840A/Mar.2014 Vertical Surface Mount Type Aluminum Electrolytic Capacitors PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 E MZ R 9 10 11 12 13 DA 14 M 15 16 17 18 G Supplement code Capacitance tolerance code Series code STANDARD RATINGS Cap dc tan ESR Rated ripple current Part No. 16 Please contact us for mass production schedule. NIPPON CHEMI-CON CORPORATION
EMZR350ADA331MHA0G 价格&库存
很抱歉,暂时无法提供与“EMZR350ADA331MHA0G”相匹配的价格&库存,您可以联系我们找货
