EM256513VR
EM256513VR
    EATON(伊顿)
    P=5.08mm
    接线端子 间距:5.08mm 1x13P 自由悬挂
EM256513VR 数据手册
EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single Row EM2565 Series EuroMag Terminal Blocks Pluggable Block (Mates with EM2575 Series); 5.08 Centers Dimensions - in (mm) HORIZONTAL 0.197 (5.00) 0.200 (5.08) 0.10 (2.54) 0.39 (10.0) Position Position L (mm) 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 14 15 16 17 18 19 20 21 22 23 24 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 0.13 (3.3) L 0.57 (14.5) Compliance References 02 03 04 05 06 07 08 09 10 11 12 13 L (mm) 0.39 (10.0) 0.11 (2.8) 0.08 (2.1) VERTICAL To convert to inches, divide by 25.4 L 0.47 (12.0) 0.47 (12.0) WIRE ENTRY 0.11 (2.8) 0.13 (3.3) 0.13 (3.3) WIRE ENTRY 1.02 (26.0) 0.09 (2.4) 0.33 (8.3) RIGHT LEFT 1.0 (2.54) 0.200 (5.08) 0.200 (5.08) Part Numbering System # of Positions Orientation n Wire Entry (Vertical Orientation Only) 02 to 24 H - horizontal V - vertical L - left R - right En Mn 2n 5n 6n 5 nn n Series Edge Connectors, One-Sided Boards 0.72 (18.3) EuroMag Series EM256503H Plug & Header SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Consult factory for 0.40” (10.16mm) Wire Range: #12-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M3.0 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 7 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified n Mating Header: EM2575 pg. 92 For additional product information, visit www.eaton.com/connectors 89
EM256513VR
1. 物料型号:EM2565系列 2. 器件简介:EuroMag端子台,可插拔模块(与EM2575系列配合使用),中心间距为5.08mm。 3. 引脚分配:表格列出了从2到24个位置的端子长度,单位为毫米。 4. 参数特性: - 额定电流:16A - 额定电压:300V - 导线范围:#12-24 AWG - 外壳材料:UL评级94V0热塑性材料 - 接触材料:镀锡黄铜 - 螺丝尺寸:M3.0镀锌钢 - 操作温度:最大105°C,最小-40°C - 扭矩等级:7磅-英寸 - 结构:模具至长度 - 认证信息:文件E62622;CE认证 5. 功能详解:端子台适用于边缘连接器、单面板。 6. 应用信息:适用于需要端子连接的应用,如电源分配、信号传输等。 7. 封装信息:提供了水平和垂直方向的尺寸信息,以及导线入口的详细尺寸。
EM256513VR 价格&库存
很抱歉,暂时无法提供与“EM256513VR”相匹配的价格&库存,您可以联系我们找货
