CFR-50JB-52-16K
CFR-50JB-52-16K
    YAGEO(国巨)
    插件,D3.3xL9mm
    插件电阻 - 16KΩ ±5% 1/2W -350~+500ppm/℃
CFR-50JB-52-16K 数据手册
           Inductive Position Sensor Evaluation Kits Both LX3301A and LX3302A currently have a linear position sensor evaluation kit and a rotary position sensor evaluation kit available. An evaluation kit includes a corresponding evaluation board, a programmer, a GUI, and applicable cables. There are also separate evaluation boards and programmers available for order upon request. The programmer provides simple interface between the evaluation board and the laptop, together with the Integrated Programming and Calibration Environment (IPCE) GUI, it allows data capturing, measuring and auto calibration of the device. Some key features of the IPCE are o Simplified Sensor System Calibration and Testing o Programs EEPROM o Simulates Position Output o Auto Calibration o Stand Alone TCP/IP Addressable Software for Production LXM9518 Programmer Integrated Programming and Calibration Environment (IPCE) IPCE Measurement Window, Provides Instant Data Capturing Function The IPCE, together with the programmer, would allow instant data capturing either by manually click on  the "capture data" button, or automatically through TCP/IP protocol.  All data captured could be easily  saved into an excel file by using the "Save Datalog" button.    IPCE Auto-Calibration Simulation Window, Provides Optimal Calibration of the Sensor with a Single Click The IPCE could simulate any collected data by loading up the data file through the "Load Bench Data  From File" function, after loading the data, click on "Run Simulation And Open Manual Calibration  Environment" button, the simulated result would show in the below window.  IPCE provides a single  click "Auto Calibration" function which would automatically find and present the optimal calibration  result.        Part Number Part Description LXE3301AR001 LXE3301AL003 Evaluation Board  LX3301A Linear    Evaluation Board  LXE3302AR001 LXE3302AL002 LX3301A Rotary    LX3302A Rotary    Evaluation Board  LX3302A Linear    Evaluation Board  Part Specification 18mm Diameter, 0.7mm Typical Airgap, 120 degree Rotary Position Sensor  100mm Measurement Range, 2mm Typical Airgap Linear Position Sensor  18mm Diameter, 0.7mm Typical Airgap, 120 degree Rotary Position Sensor  100mm Measurement Range, 2mm Typical Airgap Linear Position Sensor  LXK3301AR001 LX3301A Rotary  18mm Diameter, 0.7mm Typical Airgap, 120 degree Rotary Position Sensor  Evaluation Kit  with Programmer  LX3301A Linear  100mm Measurement Range, 2mm Typical Airgap Linear Position Sensor with  Evaluation Kit  Programmer  LX3302A Rotary  18mm Diameter, 0.7mm Typical Airgap, 120 degree Rotary Position Sensor  Evaluation Kit  with Programmer  LX3302A Linear  100mm Measurement Range, 2mm Typical Airgap Linear Position Sensor with  Evaluation Kit  Programmer  Programmer  Programmer    LXK3301AL003   LXK3302AR001 LXK3302AL002     LXM9518                                              https://www.microsemi.com/product‐directory/inductive‐sensor‐interface/5482‐inductive‐sensor‐evaluation‐kits 10‐22‐18
CFR-50JB-52-16K 价格&库存
很抱歉,暂时无法提供与“CFR-50JB-52-16K”相匹配的价格&库存,您可以联系我们找货
CFR-50JB-52-16K
    CFR-50JB-52-16K
    • 1+0.885961+0.11496
    • 10+0.4408510+0.05720
    • 25+0.3672025+0.04765
    • 50+0.3213050+0.04169
    • 100+0.28244100+0.03665
    • 250+0.24009250+0.03115
    • 500+0.21345500+0.02770
    • 1000+0.190751000+0.02475
    • 5000+0.150255000+0.01950
    库存:2427
    CFR-50JB-52-16K
    • 1+0.853601+0.10870
    • 10+0.4268010+0.05440
    • 25+0.3160025+0.04030
    • 100+0.27290100+0.03480
    • 250+0.23910250+0.03040
    • 500+0.21340500+0.02720
    • 1000+0.179601000+0.02290
    • 5000+0.162105000+0.02060
    • 10000+0.1283010000+0.01630
    库存:9602
