ED3950/X
ED4100/X
1-24 poles, Spacing 5.0 mm
insert required no. of poles x
1-n poles, Spacing 5.0 mm
How to order see page 5
Ratings:
Rated Voltage
300 V
Rated Current
15 A
Wire Size
AWG 28-12
Rating Impulse Voltage/Dirt Level
250 V
12 A (T60)
2.5 mm 2
4 kV/3
Ratings:
Rated Voltage
Rated Current
Wire Size
Test Voltage
Max. Rated Cross Section
Single Wire (solid)
Stranded Wire (flexible)
Stranded wire with Ferrules
2.5 mm
2.5 mm 2
1.5 mm 2
Single Wire (solid)
2.5 mm
on request
on request
Dimensions
Spacing
Stripped Length
5.0 mm
8.5 mm
Materials
Insulating Material
Flammability Class
Temperature Range
Cage Clamp
Contact
Dimensions
Spacing
PCB Hole Diameter
Stripped Length
5.0 mm
1.0 mm (2x)
9.0 mm
PA
UL94 V-0
-30 C/+105 C
Stainless Steel
Cu
Materials
Insulating Material
Flammability Class
Temperature Range
Tension Spring
Wire Guard
PA
UL94 V-0
-30 C/+105 C
Stainless Steel
Cu
Color
Green
58
2
300 V
10 A
AWG 20-14
250 V
17.5 A (T60)
1.5 mm 2
2 kV
2
Color
Slade Grey
ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444
58
很抱歉,暂时无法提供与“ED3950/12”相匹配的价格&库存,您可以联系我们找货
