Through-hole resistors
Low Ohmic
Metal Plate Type
Cement Resistors
Normal Style [ SLR Series ]
FEATURES
Power Rating
2W, 3W, 5W, 7W, 10W, 3W+3W, 5W+5W
Resistance Tolerance
±5%, ±10%
T.C.R.
±250ppm/°C
DERATING CURVE
40 70
Rated Load (%)
155
275 °C
100
INTRODUCTION
3W-10W
3W+3W, 5W+5W
80
As resistors in radio and television receivers,
hazardous conditions such as smoking and
redheat can be completely prevented by the
proper choice of power resistors.
2W
60
The materials used and the construction
techniques ensure excellent flame resistance,
arc resistance and moisture resistance as well
as self-extinguishing capabilities. They will
withstand the most rigorous loading test.
40
Ambient Temperature (°C)
100 150 200 250 300
TEMPERATURE RISE
Temperature Rise (°C)
250
10W, 5W+5W
200
7W, 3W+3W
5W
150
3W
100
2W
50
60
80
100 120
Rated Load (%)
DIMENSIONS
Unit: mm
B
B
A
A
C
C
RM
RM
D
RM
d
STYLE
DIMENSION
Normal
A
B
C
D
ød
RM
SLR200
8±1
13±1
3.5±1
5±1
0.6±0.05
9±1
SLR300
13±1
13±1
3.5±1
5±1
0.6±0.05
9±1
SLR500
18±1
14±1
3.5±1
5±1
0.8±0.05
10±1
SLR700
18±1
26±1
3.5±1
5±1
0.8±0.05
20±1
SLR10A
20±1
26±1
3.5±1
5±1
0.8±0.05
20±1
SLR303
18±1
26±1
12±1
5±1
0.8±0.05
10±1
SLR505
20±1
26±1
12±1
5±1
0.8±0.05
10±1
71
Note:
ELECTRICAL CHARACTERISTICS
STYLE
SLR200
Power Rating at 40°C
Power Rating at 70°C
SLR300
SLR500
SLR700
SLR10A
SLR303
SLR505
3W
5W
7W
10W
3W+3W
5W+5W
2W
Maximum Working Voltage
PxR
Dielectric Withstanding Voltage
500V
700V
Resistance range
0.01Ω - 0.68Ω
0.01Ω - 1Ω
Operating Temp. Range
-55°C to +155°C
Temperature Coefficient
±250ppm/°C
1,000V
0.01Ω - 3.3Ω
700V
(0.1Ω+0.1Ω) (0.5Ω+0.5Ω)
(0.1Ω+0.1Ω) (1.8Ω+1.8Ω)
Note: Special value is available on request
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage)
±2.0%+0.05Ω
Voltage Proof on Insulation
IEC 60115-1 4.7
In V-Block for 60 sec., test voltage as above table
No Breakdown
IEC 60115-1 4.8
Between -40°C to +155°C
By type
Insulation Resistance
IEC 60115-1 4.6
in V-block for 60 Sec.
>1,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
coatings and markings
Robustness of Terminations
IEC 60115-1 4.16
Direct load for 10 Sec. in the direction of the terminal leads
≥2.5kg (24.5N)
Periodic-pulse Overload
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off)
±2.0%+0.05Ω
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±5.0%+0.1Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±5.0%+0.1Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±2.0%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body
±1.0%+0.05Ω
Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 2020
很抱歉,暂时无法提供与“SLR500JB-0R15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11.650391+1.50914
