Female Card Edge
.156” [3.96 mm] Contact Centers, .720” [18.29 mm] Insulator Height,
.045” [1.14 mm] square / .031” [0.79 mm] X .062” [1.57 mm] Wire Wrap
SPECIFICATIONS
• Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board
• PBT insulator
• Molded-in key available
• 3 Amps current rating per contact for contacts fully energized
(for 5 Amps application, consult factory)
• 30 milli Ohms maximum at rated current
• UL Flammability Rating: 94V-0
READOUT
Female Card Edge
CANTILEVER
CONTACT
.188” [4.78]
DUAL (D)
HALF LOADED (H)
TERMINATION TYPE
.750”
[19.05]
.750”
[19.05]
.062” X .031” [1.57 X 0.79]
POSTS, (KK)
.031” X .062” [0.79 X 1.57]
90° TWISTED POSTS, (KL)
.750”
[19.05]
.045” [1.14] SQUARE POSTS
(WW)
MOUNTING STYLE
Ø.125”
[3.18]
#4-40
.250”
[6.35]
CLEARANCE
HOLE (H)
82
NO MOUNTING
EARS (N)
THREADED
INSERT (I)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
PART NUMBER OPTIONS
E B M 43 D KK H - Sxxx
MODIFICATION CODE (Consult Factory)
OMIT FOR STANDARD
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze (Standard)
(Consult factory for other materials.)
Refer to Page 7 for Operating/Processing Temperatures
MOUNTING STYLE (Opposite page)
H = Clearance Hole
N = No Mounting
I = Threaded Inserts
CONTACT FINISH - RoHS Compliant
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
.000010” Gold
.000030” Gold
.000010” Gold
.000030” Gold
Contact Surface
S = .000010” Gold
M = .000030” Gold
E = .000100” Pure Tin, Matte
B
C
G
Y
Termination
.000005” Gold
.000005” Gold
Overall Plating
.000010” Gold
.000010” Gold
TERMINATION TYPE (Opposite Page)
KK = .062” X .031” [1.57 mm X 0.79 mm] Post
KL = .031” X .062” [0.79 mm X 1.57 mm] Post,
Twisted 90°
WW = .045” [1.14 mm] Square Post
READOUT (Opposite Page)
D = Dual Row
H = Half Loaded
CONTACT CENTERS
M = .156” [3.96 mm]
Female Card Edge
NUMBER OF CONTACT POSITIONS
See Chart Below
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
E
D
B
C
.350 [8.89] INSERTION DEPTH
.360 [9.14]
.216 [5.49]
.250 [6.35]
.720 [18.29]
REFER TO TERMINATION TYPE
.188 [4.76] (WW)
.198 [5.03] (KK, KL)
.156 [3.96]
A
TYP.
F
2
1
4
3
6
5
8
7
10
9
92 94 96 98 100
91 93 95 97 99
REFER TO MOUNTING STYLE
CONTACT MARKINGS
2 4 6 . . . 96 98 100
1 3 5 . . . 95 97 99
INCHES
MILLIMETERS
POSITIONS/
CONTACTS
A±.008
B±.008
C±.015
D±.010
E±.020
F±.015
A±0.20
B±0.20
C±0.38
D±0.25
E±0.51
F±0.38
06/12
10/20
12/24
15/30
18/36
20/40
22/44
25/50*
28/56
30/60*
31/62*
36/72
43/86
50/100*
0.780
1.404
1.716
2.184
2.652
2.964
3.276
3.744
4.212
4.524
4.680
5.460
6.552
7.644
1.100
1.724
2.036
2.504
2.972
3.284
3.596
4.064
4.532
4.844
5.000
5.780
6.872
7.964
1.224
1.848
2.160
2.628
3.096
3.408
3.720
4.188
4.656
4.968
5.124
5.904
6.996
8.088
1.534
2.158
2.470
2.938
3.406
3.718
4.030
4.498
4.966
5.278
5.434
6.214
7.306
8.398
1.784
2.408
2.720
3.188
3.656
3.968
4.280
4.748
5.216
5.528
5.684
6.464
7.556
8.648
0.980
1.604
1.916
2.384
2.852
3.164
3.476
3.944
4.412
4.724
4.880
5.660
6.752
7.844
19.81
35.66
43.59
55.47
67.36
75.29
83.21
95.10
106.98
114.91
118.87
138.68
166.42
194.16
27.94
43.79
51.71
63.60
75.49
83.41
91.34
103.23
115.11
123.04
127.00
146.81
174.55
202.29
31.09
46.94
54.86
66.75
78.64
86.56
94.49
106.38
118.26
126.19
130.15
149.96
177.70
205.44
38.96
54.81
62.74
74.63
86.51
94.44
102.36
114.25
126.14
134.06
138.02
157.84
185.57
213.31
45.31
61.16
69.09
80.98
92.86
100.79
108.71
120.60
132.49
140.41
144.37
164.19
191.92
219.66
24.89
40.74
48.67
60.55
72.44
80.37
88.29
100.18
112.06
119.99
123.95
143.76
171.50
199.24
* Consult factory for availability.
83
很抱歉,暂时无法提供与“ESM12DKKI”相匹配的价格&库存,您可以联系我们找货
