TR50JBC33R0
TR50JBC33R0
    SEI
    TO-220-2
    插件电阻 TO220-2 33Ω ±5% 50W ±50ppm/℃
TR50JBC33R0 数据手册
TR Series Stackpole Electronics, Inc. TO-220 and TO-247 Style Power Resistor Resistive Product Solutions Features: • • • • • • • • TR30/35/50/50H comes in TO-220 style power package TR100 available in TO-247 style power package TR30/35/50H/100 has single screw mounting to heat sink Molded case for environmental protection Electrically isolated case Non-inductive package RoHS compliant and halogen free REACH compliant Electrical Specifications Type/Code Package Style TR30 TO-220 TR35 TO-220 TR50 TO-220 TR50H TO-220 TR100 TO-247 Power Rating (W) Maximum Power Ohmic Range (Ω) and Tolerance @ 25ºC Working TCR (ppm/ºC) Rating (W) (3) (1) @ 25ºC Voltage (V)\ 0.5% 1% 5% 10% with Heat Sink ± 50 10 - 100K ± 100 5.05 - 100K 3.01 - 100K 3.3 - 100K ± 200 10 - 100K 3.01 - 100K 3.3 - 100K 30 2.25 350 ± 300 1.02 - 3.01 1.1 - 3 0.05 - 1 Unspecified(2) ± 50 10 - 10K ± 100 5.05 - 10K 3.01 - 10K 3.3 - 10K ± 200 10 - 10K 3.01 - 10K 3.3 - 10K 35 2.5 350 ± 300 1.02 - 3.01 1.1 - 3 (2) 0.05 - 1 Unspecified ± 50 10 - 10K ± 100 5.05 - 10K 3.01 - 10K 3.3 - 10K ± 200 10 - 10K 3.01 - 10K 3.3 - 10K 50 3 350 ± 300 1.02 - 3.01 1.1 - 3 (2) 0.1 - 1 Unspecified ± 50 10 - 10K ± 100 5.05 - 10K 3.01 - 10K 3.3 - 10K ± 200 10 - 10K 3.01 - 10K 3.3 - 10K 50 2.25 420 ± 300 1.02 - 3.01 1.1 - 3 0.1 - 1 Unspecified(2) ± 50 10 - 100K ± 100 5.05 - 100K 3.01 - 100K 3.3 - 100K ± 200 10 - 100K 3.01 - 100K 3.3 - 100K 100 3.5 750 ± 300 1.02 - 3.01 1.1 - 3 0.05 - 1 Unspecified(2) (1) Lesser of √P*R or maximum working voltage (2) Unspecified TCR. Contact Stackpole. (3) The case temperature is to be used for the definition of the applied power limit. Refer to Power Derating Curve. Thermal resistance: ((T@P0%) - (T max @P10 %)) Rev Date: 7/26/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com TR Series Stackpole Electronics, Inc. TO-220 and TO-247 Style Power Resistor Resistive Product Solutions Mechanical Specifications Type Code W H H1 B B1 D D1 L C T TR30/TR50H 0.409 10.40 0.640 16.25 0.125 3.18 0.512 13.00 0.122 3.10 0.050 1.27 0.030 0.76 0.125 3.18 0.200 5.08 0.125 3.18 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± T1 - H2 - P P1 0.020 0.50 0.070 1.78 ± ± ± ± 0.012 0.30 0.012 0.30 0.010 0.26 0.063 1.60 0.043 1.10 0.005 0.13 0.004 0.10 0.004 0.10 0.010 0.26 0.010 0.26 0.004 0.10 0.010 0.26 TR35 0.400 10.16 0.591 15.00 0.114 2.90 0.531 13.50 0.130 3.30 0.050 1.27 0.031 0.78 0.151 3.84 0.200 5.08 0.181 4.60 0.049 1.25 0.245 6.23 0.020 0.50 0.091 2.30 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± TR50 0.012 0.30 0.012 0.30 0.010 0.25 0.031 0.80 0.030 0.76 0.004 0.10 0.003 0.08 0.012 0.30 0.010 0.25 0.008 0.20 0.004 0.10 0.015 0.38 0.006 0.15 0.010 0.25 0.410 10.41 0.640 16.26 ± ± ± ± 0.010 0.26 0.010 0.26 0.500 12.70 0.130 3.30 0.050 1.27 0.030 0.76 ± ± ± ± ± ± ± ± 0.050 1.27 0.030 0.76 0.005 0.13 0.004 0.10 0.200 5.08 0.125 3.18 0.020 0.50 0.070 1.78 ± ± ± ± 0.010 0.26 0.010 0.26 TR100 0.620 15.75 0.815 20.70 0.210 5.33 0.570 14.48 0.110 2.79 0.143 3.63 0.060 1.52 0.143 3.63 0.400 10.16 0.195 4.95 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± - - - - ± ± ± ± 0.004 0.10 0.010 0.26 0.032 0.81 0.095 2.41 ± ± ± ± 0.010 0.26 0.010 0.26 0.010 0.26 0.050 1.27 0.030 0.76 0.007 0.18 0.004 0.10 0.007 0.18 0.010 0.26 0.010 0.26 0.010 0.26 0.010 0.26 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Mounting Note: (1) When mounting ensure entire ceramic portion of case is mounted on a clean, flat heat sink with an appropriate thermal interface, such as thermal grease. For screw mounting use of a compression washer at a force of 150 to 300 pounds (665 to 1330 N) is recommended without exceeding mounting torque of 8 in-lb (0.9 N-m) to avoid package damage. For clip mounting use of a round or smooth clip in contact area is recommended to avoid a concentrated hot spot on package. (2) TR50/100 must be mounted to heat sink using proper mounting clip for efficient heat dissipation. Rev Date: 7/26/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com TR Series Stackpole Electronics, Inc. TO-220 and TO-247 Style Power Resistor Resistive Product Solutions Performance Characteristics Test Test Specification TR20/30/35/50/50H TR100 Test Method 2 times rated power with applied voltage not to exceed 1.5 times maximum continuous operating voltage for 5 seconds Load Life MIL-R-39009, 2000 hours at rated power Moisture Resistance MIL-STD-202, Method 103B Thermal Shock MIL-STD-202, Method 107G Terminal Strength MIL-STD-202, Method 211, Condition A (Pull Test) 2.4N Vibration, High Frequency MIL-STD-202, Method 204, Condition D Dielectric Strength Insulation Resistance Operating Temperature Range: -65ºC to + 150ºC (TR20/TR30/TR50/TR50H) -65ºC to + 175ºC (TR35/TR100) Short Time Overload ∆R ± (0.3% + 0.001 Ω) ∆R ± (0.5% + 0.001 Ω) ∆R ± (1% + 0.001 Ω) ∆R ± (1% + 0.001 Ω) ∆R ± (0.5% + 0.001 Ω) ∆R ± (0.5% + 0.001 Ω) ∆R ± (0.3% + 0.001 Ω) ∆R ± (0.5% + 0.001 Ω) ∆R ± (0.2% + 0.001 Ω) ∆R ± (0.2% + 0.001 Ω) ∆R ± (0.2% + 0.001 Ω) ∆R ± (0.4% + 0.001 Ω) 1800 VAC 10G Ω min. Power Derating Curve: Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Rev Date: 7/26/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 Minimum 60 seconds 100°C 240°C * N/A www.seielect.com marketing@seielect.com TR Series Stackpole Electronics, Inc. TO-220 and TO-247 Style Power Resistor Resistive Product Solutions Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) YES(1) 100% Matte Sn Always Always TO-220 and TO-247 Style Power Radial Leaded Resistor Special Note (1): RoHS Compliant by means of exemption 7c-I. TR “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Rev Date: 7/26/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com TR Series Stackpole Electronics, Inc. TO-220 and TO-247 Style Power Resistor Resistive Product Solutions Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 T R 3 0 F B D 1 K 0 0 Product Series TR Standard Power Rating Size W 30 30 35 35 50 50 50H 50 100 100 Tolerance Code Tol D 0.5% F 1% J 5% K 10% Packaging Code Description Size 30, 50, 50H B Bulk 35 100 TCR Quantity Code ppm 1000 X unspecified 500 C 50 105 D 100 L 200 M 300 Resistance Value Four characters with the multiplier used as the decimal holder. "L" used as multiplier of -3 10 for any value under 0.1 ohm. 0.05 ohm = 50L0 1.02 ohm = 1R02 100 Kohm = 100K Resources: Thermal Resistance Application Note Rev Date: 7/26/2022 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com
TR50JBC33R0 价格&库存
很抱歉,暂时无法提供与“TR50JBC33R0”相匹配的价格&库存,您可以联系我们找货
TR50JBC33R0
  • 1+51.601691+6.66644
