HDM Series
Stackpole Electronics, Inc.
Moisture Resistant Carbon Film Resistor
Resistive Product Solutions
Features:
Specialized materials, processes and controls ensure a part that is impervious
to moisture
Small size with high power density
Auto sequencing / insertion capable
Low cost replacement in many applications using metal glaze resistors
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Type / Code
Power Rating (W)
@ 70ºC
HDM14
HDM12
0.25
0.5
(1) Lesser of √ P*R
Maximum
Working
Voltage (V) (1)
300
350
Maximum
Overload
Voltage (V)
600
700
Ohmic Range (Ω) and Tolerance
1%, 2%, 5%
1 - 2.2M
or maximum working voltage.
Mechanical Specifications
A
Body Length
0.126 +0.008 / -0
3.20 +0.20 / -0
0.236 ± 0.012
6.00 ± 0.30
Type / Code
HDM14
HDM12
B
Body Diameter
0.071 ± 0.008
1.80 ± 0.20
0.094 ± 0.008
2.40 ± 0.20
C
Lead Length (Bulk)
1.102 ± 0.118
28.00 ± 3.00
1.102 ± 0.118
28.00 ± 3.00
D
Lead Diameter
0.018 ± 0.002
0.45 ± 0.05
0.024 ± 0.001
0.60 ± 0.02
Unit
inches
mm
inches
mm
Performance Characteristics
Test
Performance or Quality Acceptance
TCR - Temperature Coefficient of
Resistance
R < 100K Ω: -500 ~ +350 ppm/ºC
100K Ω ≤ R < 1 M Ω: -700 ~ 0 ppm/ºC
R ≥ 1 M Ω: -1500 ~ 0 ppm/ºC
Test Condition and Method
Measure resistance (R0) at room temperature (t),
after that, measure again the resistance (R) at
100ºC higher than room temperature.
TCR =
R - R0
R0
Overload (Short Time)
Damp heat (Steady State)
Load Life
Pressure Cooker Bias Test
Change of resistance
≤ ± (0.75% + 0.05 Ω)
R < 100K Ω: ≤ ± (3% + 0.05 Ω)
R ≥ 100K Ω: ≤ ± (5% + 0.05 Ω)
R < 100K Ω: ≤ ± (2% + 0.05 Ω)
R ≥ 100K Ω: ≤ ± (3% + 0.05 Ω)
≤ ± (20% + 0.05 Ω)
x
106
(ppm/ºC)
(t + 100) - t
Apply the 2.5 times rated voltage or max overload
voltage whichever is lower for 5 seconds and leave
in room temperature for one hour after test.
In the chamber having temperature 40 ± 2ºC and
relative humidity 93 ± 3%, apply one percent of the
power rating, 1.5 hour ON, 0.5 hour OFF for
1000 hours and leave in room temperature for
At 70 ± 2ºC, apply rated DC voltage 1.5 hour ON,
0.5 hour OFF for 1000 hours and leave in room
121ºC, 2 atm, 98 - 100% R.H.
Apply the rated DC voltage for 100 hours.
Reference standards: JIS C5201-1, IEC60115-1
Operating temperature range is -55ºC to +155ºC
Rev Date: 10/22/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
HDM Series
Power Derating Curve:
Pressure Cooker Test Performance
Recommended Solder Profiles
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
2
www.seielect.com
HDM Series
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
3
www.seielect.com
HDM Series
Repetitive Pulse Information:
If repetitive pulses are applied to resistors, pulse wave form must be less than “pulse limiting voltage”, “pulse limiting
current” or “pulse limiting wattage” calculated by the formula below.
Vp = K√P x R x T/t
lp = K√P/P x T/t
Pp = K2 x P x T/t
Where: Vp:
lp:
Pp:
P:
R:
T:
t:
K:
[Vr:
Note 1:
Note 2:
Note 3:
Note 4:
Note 5:
Note 6:
Pulse limiting voltage (V)
Pulse limiting current (A)
Pulse limiting wattage (W)
Power rating (W)
Nominal resistance (ohm)
Repetitive period (sec)
Pulse duration (sec)
Coefficient: 0.8
Rated Voltage (V), Ir: Rated Current (A)]
If T > 10 → T = 10 (sec), T / t > 1000 → T / t = 1000
If T > 10 and T / t > 1000, “Pulse Limiting power (Single pulse) is applied
If Vp < Vr (lp < lr or Pp < P), Vr (lr, P) is Vp (lp, Pp)
Pulse limiting voltage (current, wattage) is applied at less than rated ambient temperature.
If ambient temperature is more than the rated temperature (70 °C), decrease power rating according to
“Power Derating Curve”
Assure sufficient margin for use period and conditions for “pulse limiting voltage”
If the pulse waveform is not square wave, judge after transform the waveform into square
wave according to the “Waveform Transformation to Square Wave”.
4
www.seielect.com
HDM Series
1.
Discharge curve wave with time constant “t” → Square wave
2.
Damping oscillation wave with time constant of envelope “t” → Square wave
3.
Half-wave rectification wave → Square wave
4.
Triangular wave → Square wave
5.
Special wave → Square wave
5
www.seielect.com
HDM Series
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
HDM
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Leaded Resistor
Axial
YES
100% Matte Sn
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
H
D
Product Series
Description
Moisture Resistant
HDM
Carbon Film
Code
M
Power Rating
Code
W
14
0.25
12
0.5
1
Code
F
G
J
2
J
Tolerance
Tol
Value
1%
E24
2%
5%
T
Code
T
A
Description
Tape and Reel
Ammo
B
Bulk
4
K
Size
All Sizes
All Sizes
14
12
7
Quantity
5000
5000
2000
1000
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
1 ohm = 1R00
10 Kohm = 10K0
2.2 Mohm = 2M20
6
www.seielect.com
很抱歉,暂时无法提供与“HDM14JT100R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+0.125905000+0.01520
- 10000+0.1096010000+0.01330
- 25000+0.1003025000+0.01210
- 国内价格 香港价格
- 1+1.110281+0.13391
- 10+0.9546310+0.11514
- 25+0.6985425+0.08425
- 50+0.5418650+0.06536
- 100+0.36805100+0.04439
- 250+0.30191250+0.03642
- 500+0.24007500+0.02896
- 1000+0.170381000+0.02055
- 国内价格 香港价格
- 5000+0.131645000+0.01588
- 10000+0.1181010000+0.01425
- 25000+0.1084225000+0.01308
- 50000+0.1018450000+0.01229
- 125000+0.09951125000+0.01201
