EBM43DSKN
EBM43DSKN
    SULLINS
    CONNEDGEDUALFMALE86POS0.156
EBM43DSKN 数据手册
8 7 4 5 6 2 3 1 REVISIONS E REV. ECO NO. DESCRIPTION DATE BY A 2898 INITIAL RELEASE 1/16/2014 JHSU D F F B 2X .125 3.18 THRU PRELIMINARY A +.005 +0.13 .370 - .015 9.40 - 0.38 .075 1.91 SEE NOTE 13 E C E .030 0.75 A .180 4.57 .297 7.54 INSERTION DEPTH .025 0.64 .550 13.97 .250 6.35 D D .250±.025 6.35±0.64 A .156 3.96 TYP .200 5.08 .025[0.64] POST F SECTION A-A _ _ M _ _ DSKH 2X .125 3.18 FOR 'H' OR 'I' MOUNTING D C A CONTACT MARKINGS (LETTERS G, I, O, & Q NOT USED) SIZES 06 THRU 25 & 30: 1 2 ... 13 24 ... 29 30 A B ... A B ... H J .200 5.08 .156 3.96 SIZES 28 & 31: 1 2 ... 23 24 ... 30 31 A B ... A B ... J K .043 1.09 MIN PCB LAYOUT RECOMMENDED B A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: SEE PART NUMBER CODING. 3. PLATING: SEE PART NUMBER CODING. 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING. 5. PROCESSING TEMP: SEE PART NUMBER CODING. 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 950 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 3 AMP 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB CONTACT ID SCALE 4 : 1 CONTACTS NOT SHOWN FOR CLARITY SIZES 36 THRU 43: A B ... A B ... X Y 1 2 ... 23 24 ... 42 43 7 6 5 B SIZES 47 & 50: 1 3 ... 97 99 2 4 ... 98 100 CUSTOMER COPY UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 1/16/2014 JHSU Pb RoHS COMPLIANT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE 4 3 A EDGECARD, .156 CC, HP PART NUMBER _ _ M _ _ DSK _ (-S38, S81, S328) SIZE CAGE CODE C 54453 SCALE: 3:1 8 C 2 DWG. NO. REV C12337 A SHEET 1 OF 3 1 FILE NAME: C12337, _ _M_ _DSK_-(OMIT, S38, S81, S328) 8 7 4 5 6 2 3 1 F F C E E D _ _ M _ _ DSKN 2X .125 3.18 THRU D D .245 6.22 D _ _ M _ _ DSKS 2X #4-40 THREADED INSERT C C B B _ _ M _ _ DSKI CUSTOMER COPY UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 1/16/2014 JHSU Pb A RoHS COMPLIANT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER _ _ M _ _ DSK _ (-S38, S81, S328) SIZE CAGE CODE C 54453 SCALE: 2:1 8 7 6 5 4 3 A EDGECARD, .156 CC, HP 2 DWG. NO. REV C12337 A SHEET 2 OF 3 1 FILE NAME: C12337, _ _M_ _DSK_-(OMIT, S38, S81, S328) 8 PART NUMBER F E _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ M06DSK _ M08DSK _ M10DSK _ M12DSK _ M15DSK _ M18DSK _ M20DSK _ M22DSK _ M24DSK _ M25DSK _ M28DSK _ M30DSK _ M31DSK _ M36DSK _ M40DSK _ M43DSK _ M47DSK _ M50DSK _ 7 NO. OF POS. 6 8 10 12 15 18 20 22 24 25 28 30 31 36 40 43 47 50 A±.008[0.20] IN MM 0.780 19.81 1.092 27.74 1.404 35.66 1.716 43.59 2.184 55.47 2.652 67.36 2.964 75.29 3.276 83.21 3.588 91.14 3.744 95.10 4.212 106.98 4.524 114.91 4.680 118.87 5.460 138.68 6.084 154.53 6.552 166.42 7.176 182.27 7.644 194.16 4 5 6 B±.008[0.20] IN MM 1.102 27.99 1.414 35.92 1.726 43.84 2.038 51.77 2.506 63.65 2.974 75.54 3.286 83.46 3.598 91.39 3.910 99.31 4.066 103.28 4.534 115.16 4.846 123.09 5.002 127.05 5.782 146.86 6.406 162.71 6.874 174.60 7.498 190.45 7.966 202.34 2 3 DIMENSIONS C±.015[0.38] D±.010[0.38] IN MM IN MM 1.221 31.01 1.534 38.96 1.533 38.94 1.846 46.89 1.845 46.86 2.158 54.81 2.157 54.79 2.470 62.74 2.625 66.68 2.938 74.63 3.093 78.56 3.406 86.51 3.405 86.49 3.718 94.44 3.717 94.41 4.030 102.36 4.029 102.34 4.342 110.29 4.185 106.30 4.498 114.25 4.653 118.19 4.966 126.14 4.965 126.11 5.278 134.06 5.121 130.07 5.434 138.02 5.901 149.89 6.214 157.84 6.525 165.74 6.838 173.69 6.993 177.62 7.306 185.57 7.617 193.47 7.930 201.42 8.085 205.36 8.398 213.31 E±.020[0.51] IN MM 1.784 45.31 2.096 53.24 2.408 61.16 2.720 69.09 3.188 80.98 3.656 92.86 3.968 100.79 4.280 108.71 4.592 116.64 4.748 120.60 5.216 132.49 5.528 140.41 5.684 144.37 6.464 164.19 7.088 180.04 7.556 191.92 8.180 207.77 8.648 219.66 1 F±.015[0.38] IN MM 1.030 26.16 1.342 34.09 1.654 42.01 1.966 49.94 2.434 61.82 2.902 73.71 3.214 81.64 3.526 89.56 3.838 97.49 3.994 101.45 4.462 113.33 4.774 121.26 4.930 125.22 5.710 145.03 6.334 160.88 6.802 172.77 7.426 188.62 7.894 200.51 F E D D PART NUMBER _ _ M _ _ DSK _-S_ _ _ MODIFICATION CODE C B MATERIAL (INSULATOR/CONTACT) E = PBT/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C FOR 10 SECS MAX R = PPS/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C FOR 120 SECS MAX G = PA9T/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C FOR 20 SECS MAX H = PBT/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C FOR 10 SECS MAX A = PPS/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C FOR 120 SECS MAX J = PA9T/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C FOR 20 SECS MAX (CONSULT FACTORY FOR OTHER MATERIALS) - OMIT FOR STANDARD, EX: 'EBM22DSKH' S38 = BLACK PBT (MATL CODE E AND H ONLY) S81 = GREEN PBT (MATL CODE E AND H ONLY) S328 = BROWN PPS (MATL CODE R AND A ONLY) MOUNTING STYLE H = .125 DIA. CLEARANCE HOLES (PAGE 1) I = #4-40 THREADED INSERT (PAGE 2) S = .125 DIA. SIDE MOUNTING (PAGE 2) N = NO MOUNTING EARS (PAGE 2) C NUMBER OF POSITIONS (CONTACTS PER ROW) PLATING ALL PLATINGS HAVE .000050" NICKEL UNDERPLATE CONTACT SURFACE TERMINATION G = .000010" GOLD .000005" GOLD Y = .000030" GOLD .000005" GOLD B = .000010" GOLD .000100" PURE TIN, MATTE C = .000030" GOLD .000100" PURE TIN, MATTE **E = .000100" PURE TIN, MATTE, OVERALL S = .000010" GOLD OVERALL M = .000030" GOLD .000010" GOLD OVERALL ** OVERALL TIN ONLY AVAILABLE ON MATERIAL CODES E, R AND G B CUSTOMER COPY UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 1/16/2014 JHSU Pb A RoHS COMPLIANT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER _ _ M _ _ DSK _ (-S38, S81, S328) SIZE CAGE CODE C 54453 SCALE: 2:1 8 7 6 5 4 3 A EDGECARD, .156 CC, HP 2 DWG. NO. REV C12337 A SHEET 3 OF 3 1 FILE NAME: C12337, _ _M_ _DSK_-(OMIT, S38, S81, S328)
EBM43DSKN 价格&库存
很抱歉,暂时无法提供与“EBM43DSKN”相匹配的价格&库存,您可以联系我们找货
