FMP100JR-52-47K
FMP100JR-52-47K
    YAGEO(国巨)
    插件,D2.4xL6.3mm
    插件电阻 - 47KΩ ±5% 1W -
FMP100JR-52-47K 数据手册
DATA A SHEET METAL FILM RESISTORS High Power Power, Flameproof FMP Series ±1%, ±5% 1/2W to 3W Product specification – October 25, 2021 V.2 RoHS compliant & Halogen Free Through Hole Resistors Metal Film Resistors Product Specification FMP ORDERING INFORMATION Part number of the high power, flameproof metal film resistor are identified by the series, power rating, tolerance, packing , temperature coefficient, forming and resistance value. PART NUMBER APPLICATIONS Ÿ All general purpose applications Ÿ Power applications FEATURES FMP 200 F T F (1) (2) (3) (4) (5) 52- 100R (6) (7) (1) SERIES FMP Series (2) POWER RATING -50 = 1/2W 3WS = 3W 100 = 1W 300= 3W 200 = 2W Ÿ Ultra miniature size Ÿ Wide resistance range Ÿ High power rating Ÿ High stability Ÿ PPAP ready (FMP-50) Ÿ Flameproof coating equivalent to UL94V-0 Ÿ RoHS compliant & halogen-free (3) TOLERANCE F = ±1% J = ±5% (4) PACKAGING R = Reel Pack B = Bulk T = Box Pack (5) TEMPERATURE COEFFICIENT OF RESISTANCE E = ±50ppm/°C - = Based on spec. F = ±100ppm/°C (6) FORMING 26- = 26mm FFK = FFK Type Forming 52- = 52.4mm FKK = FKK Type Forming 52J = 52.4mm, Φd=0.8±0.05mm FT = FT Type Forming 52E = 52.4mm, Φd=0.70±0.05mm MT = MTsert 73- = 73mm PN = PANAsert M = M Type Forming AV = AVIsert F = F Type Forming FK = FK Type Forming (7) RESISTANCE VALUE E24 & E96 Series Example: 100R = 100Ω, 10K = 10,000Ω, 1M = 1,000,000Ω www.yageo.com Oct. 25, 2021 V.0 2 16 Through Hole Resistors Product Specification Metal Film Resistors FMP DIMENSIONS Unit: mm Ultra Miniature L ψD H ψd FMP-50 3.4 ± 0.3 1.9 ± 0.2 28 ± 2.0 0.45 ±0.05 FMP100 6.3 ± 0.5 2.4 ± 0.2 28 ± 2.0 0.55 ±0.05 FMP200 9.0 ± 0.5 3.9 ± 0.3 26 ± 2.0 0.55 ±0.05 FMP3WS 11.5 ± 1.0 4.5 ± 0.5 35 ± 2.0 0.8±0.05 FMP300 15.5± 1.0 5.0 ± 0.5 33 ± 2.0 0.8±0.05 DERATING CURVE Rated Power (%) 100 80 60 40 20 20 40 70 100 155 Ambient Temperature (°C) ELECTRICAL CHARACTERISTICS CHARACTERISTICS FMP-50 FMP100 FMP200 FMP3WS FMP300 Power Rating at 70 °C 1/2W 1W 2W 3W 3W Maximum Working Voltage 200V 350V 500V 500V 750V Maximum Overload Voltage 400V 600V 700V 700V 1000V Voltage Proof on Insulation 300V 500V 500V 500V 500V Resistance Range 1Ω ~ 4M7Ω for E24 & E96 series value Operating Temp. Range - 55°C to +155°C Temperature Coefficient ±100ppm/°C , ±50ppm/°C(FMP-50 & FMP100 types, R ≥ 10RΩ) Note: For resistance value out of above range is by request. www.yageo.com Oct. 25, 2021 V.0 3 16 Through Hole Resistors Metal Film Resistors Product Specification FMP TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 PROCEDURE APPRAISE 2.5 times RCWV for 5 sec.(Not more than ± 1.0 % + 0.05Ω maximum overload voltage) Voltage Proof on IEC 60115-1 4.7 Insulation In V-Block for 60 sec. test voltage as No Breakdown above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >1,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Robustness of IEC 60115-1 4.16 Terminations Periodic-pulse Overload Direct load for 10 Sec. in the direction of ≥2.5Kg(24.5N) the terminal leads IEC 60115-1 4.39 4 times RCWV(or Umax., whichever less) ±1.0%+0.05Ω 10,000 cycles (1 Sec. on, 25 Sec.off) Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±2.0%+0.05Ω with 0.1 times RCWV(or Umax., whichever less) Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±2.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19 -55°C è Room Temp. è +155°C ±1.0%+0.05Ω è Room Temp.(5 cycles) Resistance to Soldering IEC 60115-1 4.18 Heat 260±3°C for 10±1 Sec., immersed to a ±0.25%+0.05Ω point 3±0.5mm from the body Accidental Overload Test IEC 60115-1 4.26 4 times RCWV(or Umax., whichever less) No evidence of flaming for 1 Min. or arcing Note: RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) www.yageo.com Oct. 25, 2021 V.0 4 16 Through Hole Resistors Metal Film Resistors Product Specification FMP PULSE DIAGRAMS FMP100 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time FMP200 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Oct. 25, 2021 V.0 5 16 Through Hole Resistors Metal Film Resistors Product Specification FMP FMP300 Series: Pmax.: Maximum permissible peak pulse power ti: Pulse duration tp: Pulse repetition time www.yageo.com Oct. 25, 2021 V.0 6 16 Through Hole Resistors Product Specification Metal Film Resistors FMP AXIAL / REEL TAPE SPECIFICATION Unit: mm Ultra Miniature a FMP-50 6 ± 0.5 FMP100 FMP200 6 ± 0.5 A B1-B2 (Max.) 52.4 ± 1.5 1.2 26.0 ± 1.5 1 52.4 ± 1.5 1.2 73.0 ± 1.5 1.5 52.4 ± 1.5 1.2 73.0 ± 1.5 1.5 S (spacing) T (max. deviation of spacing) 5 5 0.5 mm per 5 spacing 6 ± 0.5 FMP3WS 6 ± 0.5 FMP300 5 5 www.yageo.com Oct. 25, 2021 V.0 7 16 Through Hole Resistors Metal Film Resistors Product Specification FMP TAPE ON REEL PACKING TYPE Unit: mm/piece Ultra Miniature Across Flange(A) B Quantity Per Reel FMP-50 66.5 75.5 5,000 FMP100 66.5 75.5 5,000 FMP200 66.5 75.5 2,500 FMP3WS 87 96 2,000 FMP300 87 96 1,000 www.yageo.com Oct. 25, 2021 V.0 8 16 Through Hole Resistors Metal Film Resistors Product Specification FMP TAPE ON BOX PACKING TYPE DIMENSIONS Ultra Miniature A B C Quantity Per Box FMP-50 81 70 260 5,000 FMP100 81 104 260 5,000 FMP200 73 45 258 1,000 FMP3WS 103 78 260 1,000 FMP300 103 78 260 1,000 Unit: mm/piece BULK PACKING Ultra Miniature Piece/Per Inner Box Bag/Per Inner Box Piece Per Bag FMP-50 10,000 10 1,000 FMP100 10,000 10 1,000 FMP200 5,000 5 1,000 FMP3WS 2,000 4 500 FMP300 1,000 2 500 www.yageo.com Oct. 25, 2021 V.0 9 16 Through Hole Resistors Metal Film Resistors Product Specification 16 FMP FORMING M TYPE TYPE DIMENSIONS Ultra Miniature L ψD ψd FMP-50 3.4± 0.3 1.9 ± 0.2 0.45 ± 0.05 6.0 ± 1 10.0 ±1 FMP100 6.3 ± 0.5 2.4 ± 0.2 0.55 ± 0.05 10.0 ± 1 10.0 ± 1 FMP300 15.5 ± 1.0 5.0± 0.5 0.8 ± 0.05 20.0 ± 1 15.0 ± 1 Unit: mm P H www.yageo.com Oct. 25, 2021 V.0 10 Through Hole Resistors Product Specification Metal Film Resistors 16 FMP MHA TYPE Unit: mm TYPE DIMENSIONS Miniature L ψD ψd B H0 HI P P0 9.0±0.5 3.9±0.3 0.55±0.05 17.5Max 19.0±1.0 4.0±1.0 30.0±1.0 15.0±0.3 P1 P2 F W W0 W1 ΨD0 7.5±1.0 3.75±0.5 7.5±0.5 18.0±0.5 5.0Min 9.0±0.5 4.0±0.2 FMP200 MHB TYPE TYPE FMP300 Unit: mm DIMENSIONS ψD ψd B H H0 HI H2 H3 15.5±1.0 5.0±0.5 0.8±0.05 21.0Max. 30Max. 18.0±1.0 5.5(Ref.) 8.0±1.5 16Max. P P0 PI P2 F W W0 W1 ΨD0 30.0±1.0 15.0±0.3 7.5±1.0 3.75±0.8 7.5±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.3 Miniature L www.yageo.com Oct. 25, 2021 V.0 11 Through Hole Resistors Product Specification Metal Film Resistors 16 FMP MHC TYPE Unit: mm TYPE DIMENSIONS Miniature L ψD ψd B H HI P P0 15.5±1.0 5.0±0.5 0.8±0.05 21.0Max. 19.0±1.0 5.25±1.0 30.0±1.0 15.0±0.3 F W W0 W1 ΨD0 10.0±0.5 18.0±0.5 5.0Min. 9.0±0.5 4.0±0.2 FMP300 F TYPE FK TYPE FFK TYPE TYPE DIMENSIONS Ultra Miniature L ψD ψd P h FMP200 9.0±0.5 3.9±0.3 0.55±0.05 6±1 - - FMP300 15.5±1 5.0±0.5 0.8±0.05 8±1 8±1 28 FKK TYPE Unit: mm H Max. HI E Max. Max. 5± 1 18.5 3.5 - 5± 1 25 3.5 3.5±1 hl e www.yageo.com Oct. 25, 2021 V.0 12 Through Hole Resistors Metal Film Resistors Product Specification 16 FMP FT TYPE (Taping Pack) MT TYPE (Taping Pack) Rated Watts : 0.5W TYPE DIMENSIONS Unit: mm Ultra Miniature H1 Max. H2 Max. H3 Max. FMP100 10 18.5 8.5 FMP200 13 21.5 8.5 FMP3WS 16 24.5 8.5 PN TYPE (Taping Pack) AV TYPE (Taping Pack) TYPE DIMENSIONS Unit: mm TYPE DIMENSIONS Unit: mm Ultra Miniature H1 Max. H2 Max. H3 Max. Ultra Miniature H1 Max. H2 Max. H3 Max. FMP100 13 21.5 8.5 FMP100 11.5 20 8.5 FMP200 17 25.5 8.5 FMP200 14.5 23 8.5 FMP3WS 19 27.5 8.5 FMP3WS 17.5 26 8.5 www.yageo.com Oct. 25, 2021 V.0 13 Through Hole Resistors Product Specification Metal Film Resistors 16 FMP MARKING 4-BAND-CODE ±5% COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 0 1 2 3 4 5 6 7 8 9 2nd BAND 0 1 2 3 4 5 6 7 8 9 3rd BAND 0 1 2 3 4 5 6 7 8 9 MULTIPLIER 1Ω 10Ω 100Ω 1KΩ 10KΩ 100K 1MΩ 10MΩ 0.001Ω 0.0001Ω 0.1Ω 0.01Ω TOLERANCE ± 1% (F) ±5% (J) ±1% 5-BAND-CODE www.yageo.com Oct. 25, 2021 V.0 14 Through Hole Resistors Metal Film Resistors Product Specification 16 FMP REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug.2, 2021 - - First issue of this specification Version 1 Oct.12, 2021 Updated the tape specification of FMP200 Version 2 Oct.25, 2021 Add F type for FMP200 series “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Oct. 25, 2021 V.0 15 Through Hole Resistors Metal Film Resistors Product Specification 16 FMP LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Oct. 25, 2021 V.0 16
FMP100JR-52-47K
物料型号:FMP系列,包括FMP-50、FMP100、FMP200、FMP3WS和FMP300。
器件简介:FMP系列是高功率、阻燃的金属膜电阻器,适用于一般用途和电力应用。
引脚分配:文档中没有提供具体的引脚分配信息,但通常这类电阻器会有两端引脚用于连接电路。
参数特性: - 容差:±1%和±5% - 功率范围:1/2W至3W - 工作温度范围:-55°C至+155°C - 温度系数:±50 ppm/°C(FMP-50 & FMP100类型,R≥10R)和±100 ppm/°C - 最大工作电压和过载电压根据不同型号有不同规格
功能详解: - 超小型尺寸 - 符合RoHS标准且无卤素 - 提供PPAP准备(FMP-50)和UL94V-0相当的阻燃涂层 - 电阻值范围为E24和E96系列
应用信息:适用于一般用途和电力应用。
封装信息:提供卷带包装、盒装和散装等多种形式。
FMP100JR-52-47K 价格&库存
很抱歉,暂时无法提供与“FMP100JR-52-47K”相匹配的价格&库存,您可以联系我们找货
FMP100JR-52-47K
  • 1+1.236331+0.16026
  • 10+0.7844310+0.10168
  • 25+0.6556825+0.08499
  • 50+0.5780950+0.07494
  • 100+0.51031100+0.06615
  • 250+0.43609250+0.05653
  • 500+0.38958500+0.05050
  • 1000+0.349991000+0.04537
库存:72866
FMP100JR-52-47K
  • 5000+0.279635000+0.03625
  • 10000+0.2566010000+0.03326
  • 15000+0.2447515000+0.03173
  • 25000+0.2313725000+0.02999
  • 35000+0.2234035000+0.02896
  • 50000+0.2156050000+0.02795
库存:72866
FMP100JR-52-47K
    • 20+0.24506
    • 200+0.19332
    • 600+0.16460
    库存:3159
