MP-0100-15-DW-5H
MP-0100-15-DW-5H
    SULLINS
    CONNEDGEDUALFMALE30POS0.100
MP-0100-15-DW-5H 数据手册
8 7 4 5 6 1 2 3 REVISIONS E D B A F E ECO. NO DESCRIPTION DATE BY A 2319 INITIAL RELEASE 05/17/11 EB 2451 UPDATED PN CODING TO INCLUDES MTL, PLATING OPTIONS, CORRECTED BOM TABLE, ADDED TOLERANCE .010 TO CONTACT GAP DIM 9/21/2011 JH .075 1.91 CARDSLOT B .030±.010 0.77±0.25 .180 4.57 A F +.005 +0.13 .370 9.40 - .015 - 0.38 .125 3.18 2X C REV. E .250 6.35 .610 15.49 .297 7.54 INSERTION DEPTH .060 1.52 D .190±.025 4.83±0.64 TAIL LENGTH A .025 0.64 .100 2.54 TYP F D SECTION A-A MP_ _-_100-_ _- DW- 5H_ _ _ CONTACT MARKINGS 1 3 5 ... 137 139 2 4 6 ... 138 140 .040 1.02 MIN C .200 5.08 ROW SPACING C .200 5.08 .100 2.54 TYP A D 2X .125 3.18 FOR MOUNTING STYLE '1', '2', '5' OR '6' RECOMMENDED PCB LAYOUT B A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: SEE PART NUMBER CODING. 3. PLATING: SEE PART NUMBER CODING. 4. OPERATING TEMPERATURE RATING: SEE PART NUMBER CODING. 5. PROCESSING TEMPERATURE: SEE PART NUMBER CODING. 6. UL FLAMABILITY RATING: 94V-0. 7. DIELECTRIC WITHSTANDING VOLTAGE RATING: 750 VAC MIN. AT SEA LEVEL. 8. CURRENT RATING: 3 AMP PER CONTACT. 9. CONTACT RESISTANCE: 30 MILLIOHMS MAX. 10. INSULATION RESISTANCE: 5000 MEGOHMS MIN. 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: PART SHALL BE MARKED WITH PART NUMBER AND LOT CODE. 13. ACCOMMODATES BOARD THICKNESS: .062 ± .008” [1.57 0.20]. 14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062” [1.57mm] 15. WITHDRAWAL FORCE: 1 OZ MIN. PER CONTACT PAIR USING .062” [1.57mm] PCB TEST BLADE. B REF: _ _C_ _DRS_ (-S_ _ _) CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 04/15/11 EB THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .100 CC, HP PART NUMBER SIZE C MP_ _-_100-_ _-DW-_H_ _ _ CAGE CODE 54453 SCALE: 3:1 2 DWG. NO. C11701 SHEET 1 OF 3 1 REV B FILE NAME: C11701, MP_ _-_100_ _DW-_ H_ _ _, ( REF _ _C_ _DRS_-OMIT, S38, S81, S328) 8 7 4 5 6 1 2 3 2X #4-40 THREADED INSERTS F F D C E E MP_ _-_100-_ _- DW- 6H_ _ _ MP_ _-_100-_ _- DW- 4H_ _ _ D D 2X .125 3.18 THRU 2X #4-40 THREADED INSERTS C C D D .250 6.35 .250 6.35 B B MP_ _-_100-_ _- DW- 1H_ _ _ MP_ _-_100-_ _- DW- 2H_ _ _ CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 04/15/11 EB THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .100 CC, HP PART NUMBER SIZE C MP_ _-_100-_ _-DW-_H_ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11701 SHEET 2 OF 3 1 REV B FILE NAME: C11701, MP_ _-_100_ _DW-_ H_ _ _, ( REF _ _C_ _DRS_-OMIT, S38, S81, S328) 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 04/15/11 EB THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .100 CC, HP PART NUMBER SIZE C MP_ _-_100-_ _-DW-_H_ _ _ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11701 SHEET 3 OF 3 1 REV B FILE NAME: C11701, MP_ _-_100_ _DW-_ H_ _ _, ( REF _ _C_ _DRS_-OMIT, S38, S81, S328)
MP-0100-15-DW-5H 价格&库存
很抱歉,暂时无法提供与“MP-0100-15-DW-5H”相匹配的价格&库存,您可以联系我们找货
