HVA Series
Stackpole Electronics, Inc.
High Voltage Axial Leaded Resistor
Resistive Product Solutions
Features:
High resistance for high voltage circuits
High voltage handling in small package size
Metal film technology
More economical than comparable high voltage resistors
VCR less than 20 ppm/V
RoHS compliant
Halogen free
REACH compliant
Electrical Specifications
Type/Code
Power Rating (W)
HVA05
HVA08
HVA12
0.5
0.8
1.2
Maximum
Working
Voltage (V)
3500
7000
8000
Ohmic Range (Ω) and Tolerance
TCR (ppm/ºC)
1%
± 200
5%
1M - 500M
1M - 500M
1M - 500M
10%
1M - 1G
1M - 1G
Rated voltage = √Power Rating x Nominal Resistance or Maximum Working voltage, whichever is lower.
Mechanical Specifications
Type/Code
Weight
(mg)
HVA05
210
HVA08
330
HVA12
570
L
Body Length
0.236 ± 0.008
6.00 ± 0.20
0.354 ± 0.039
9.00 ± 1.00
0.433 ± 0.039
11.00 ± 1.00
D
Body Diameter
0.098 ± 0.020
2.50 ± 0.50
0.118 ± 0.020
3.00 ± 0.50
0.157 ± 0.020
4.00 ± 0.50
d
Lead Diameter
0.022 ± 0.002
0.55 ± 0.05
0.022 ± 0.002
0.55 ± 0.05
0.022 ± 0.002
0.55 ± 0.05
H
Lead Length (bulk)
1.102 ± 0.118
28.00 ± 3.00
1.102 ± 0.118
28.00 ± 3.00
1.102 ± 0.118
28.00 ± 3.00
Unit
inches
mm
inches
mm
inches
mm
Performance Characteristics
Item
Temperature Coefficient of Resistance (ppm/ºC)
Specification
±200 ppm/ºC
Test Condition and Method
25°C ~ 125°C
Rapid Change of Temperature
±1%
-25°C (30 minutes) / +125°C (30 minutes) - 5 cycles
Damp Heat (steady state)
±5%
Endurance (at 70°C)
±5%
Resistance to Soldering Heat
Reference standards: JIS-C5201-1, IEC60115-1
Operating temperature range is -25ºC to +125ºC
Rev Date: 2/25/2022
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
±1%
1
40 ± 2°C 93 ± 3% R.H. 0.1 x Rated Voltage
90 minutes ON, 30 minutes OFF - 1000 hours
Room temperature. Rated Voltage
260 ± 5°C, 10 ± 1 seconds
www.seielect.com
marketing@seielect.com
HVA Series
Power Derating Curve:
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Rev Date: 2/25/2022
2
www.seielect.com
HVA Series
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
Package /
Termination
Type
HVA
Axial
Standard
Lead-Free
Lead-Free Termination
Mfg. Effective Date
Series RoHS
Composition
(Std Product Series)
Compliant
100% Matte Sn
Always
YES (1)
Lead-Free
Effective Date
Code
(YY/WW)
Always
Note (1): RoHS compliant by means of exemption 7c-I.
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Rev Date: 2/25/2022
3
www.seielect.com
HVA Series
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
H
Product Series
High Voltage Axial
HVA
Leaded Resistor
V
A
Size
Code
W
05
0.5
08
0.8
12
1.2
Code
F
J
K
5
F
Tolerance
Tol
Value
1%
5%
E24
10%
B
Code
A
B
1
M
Packaging
Description
Size
05, 08
Ammo
12
Bulk
all sizes
Resistance Value
Quantity
2000
1000
1000
Four characters with
the multiplier used as
the decimal holder.
1 Mohm = 1M00
50 Mohm = 50M0
1 Gohm = 1G00
Rev Date: 2/25/2022
4
www.seielect.com
很抱歉,暂时无法提供与“HVA05FA25M0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 25+0.36787
- 100+0.27282
- 250+0.24026
- 500+0.19450
- 1000+0.13201
