MR / MRS / TMR Series
Stackpole Electronics, Inc.
Low Resistance Value Resistor – Molded 2 and 4 Leads
Resistive Product Solutions
Features:
Metal element resistors
Tinned copper leads
Low temperature coefficient
Molded bodies
TMR – Kelvin Bridge Test
MRS high stability version
Cut and formed product is available on selected sizes - contact Stackpole for details
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Type/Code
Power Rating (W)
@ 70ºC
Short Time Overload
Dielectric Strength
Ohmic Range (Ω) and
Tolerance
TCR (ppm/ºC)
1%, 5%
(2)
1
0.01 - 0.1
MR1
3
0.005 - 0.2
MR3(3)
(1)
± 50 to ± 400
5 seconds at
5
0.005 - 0.3
MR5(4)
500 VAC
5 X rated power
10
0.01 - 0.5
MR10(5)
TMR3
3
0.005 - 0.2
± 40
TMR5
5
0.005 - 0.3
(1) TCR is value dependent. Contact Stackpole for specific data.
(2) MR1 values 0.05Ω and below are non-magnetic and non-inductive. MR1 values ≥ 0.06Ω are ribbon element wound on ceramic core.
(3) MR3 values 0.1Ω and below are non-magnetic and non-inductive. MR3 values ≥ 0.15Ω are ribbon element wound on ceramic core.
(4) MR5 values 0.15Ω and below are non-magnetic and non-inductive. MR5 values ≥ 0.15Ω are ribbon element wound on ceramic core.
(5) MR10 all values are ribbon element wound on ceramic core.
Mechanical Specifications
MR
Type/Code
MR1
MR3
MR5
MR10
TMR3
TMR5
A
Body Length
0.385
9.78
0.560
14.22
0.925
23.50
1.925
48.90
0.625
15.88
0.940
23.88
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
TMR
C
Lead Length (Bulk)(1)
B
Body Diameter
0.135
3.43
0.205
5.21
0.330
8.38
0.475
12.07
0.205
5.21
0.330
8.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
1.375
34.93
1.375
34.93
1.375
34.93
1.375
34.93
1.375
34.93
1.375
34.93
0.125
3.18
0.125
3.18
0.125
3.18
0.125
3.18
0.125
3.18
0.125
3.18
D
Lead Diameter
0.032
0.81
0.032
0.81
0.036
0.91
0.036
0.91
0.032
0.81
0.036
0.91
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
E
Lead Spacing
(Ref.)
0.125
3.18
0.200
5.08
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
(1) See Packaging Specification for lead length dimension for tape and reel packaged product.
Rev Date: 5/12/2022
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
www.seielect.com
marketing@seielect.com
Performance Characteristics
Test
Test Results
Moisture Resistance
Thermal Shock
Load Life @ 70ºC - 1000 hours
Resistance to Soldering Heat
Short Time Overload
Dielectric Withstanding Voltage
± 5%
± 2%
± 5%
± 2%
± 2%
± 2%
Operating Temperature Range: -55ºC to +275ºC
Power Derating Curve:
TCR X Resistance:
Rev Date: 5/12/2022
2
www.seielect.com
Recommended Solder Profiles
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
Minimum
60 seconds
100°C
240°C
N/A
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
Rev Date: 5/12/2022
3
www.seielect.com
Packaging Specifications
Series
Code
1
3
MR
5
10
A max.(1)
B max
3.311
84.10
3.484
88.50
3.850
97.80
4.764
121.00
13.504
343.00
13.504
343.00
13.504
343.00
13.504
343.00
D(2)
C
0.197
5.00
0.394
10.00
0.394
10.00
0.600
15.24
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
2.063
52.40
2.063
52.40
2.875
73.03
4.375
111.13
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
Tape
Unit
0.250
6.35
0.250
6.35
0.250
6.35
0.250
6.35
inches
mm
inches
mm
inches
mm
inches
mm
Dimension "E":
(1)
(2)
This is a non-critical dimension that does not have a tolerance in the standard.
Range of diameters is from 0.547 inches (13.90 mm) to 1.500 inches (38.10 mm).
Reference value only. The "A" dimension shall be governed by the overall length of the taped component.
The distance between flanges shall be 0.059 inches (1.50 mm) to 0.315 (8.00 mm) greater than the overall component.
The given dimension "D" expresses the standard width spacing. A 26 mm narrow spacing is available as option "N" packaging code.
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
MR
TMR
Description
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
YES
100% Matte Sn
Jan-06
06/01
YES
100% Matte Sn
Jan-06
06/01
Package /
Standard
Termination Series RoHS
Type
Compliant
Low Resistance Value Leaded Resistor Molded 2 Leads
Low Resistance Value Leaded Resistor Molded 4 Leads
Axial
Kelvin
Axial
Kelvin
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the Eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Rev Date: 5/12/2022
4
www.seielect.com
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
Product Series
Code Description
MR
2 Leads
TMR
4 Leads
MRS High Stability
1
2
3
4
5
6
7
8
9
M
R
3
F
T
R
1
Power Rating
Size
W
1
1
3
3
5
5
10
10
Tolerance
Code Tol
1%
F
J
5%
Code
T
B
Rev Date: 5/12/2022
Packaging
Description
Size
Quantity
MR1
2000
MRS3
1000
Tape and Reel
MR3
750
MR5
500
MR10
250
MR1, MR3, MR5 1000
Bulk
MR10
500
TMR3, TMR5
100
5
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
"L" used as multiplier of
-3
10 for any value under
0.1 ohm.
0.005 ohm = 5L00
0.01 ohm = 10L0
0.2 ohm = R200
www.seielect.com
很抱歉,暂时无法提供与“MR5FT50L0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+24.672101+3.20621
- 10+16.4455810+2.13715
- 25+14.2141225+1.84716
- 50+12.8143650+1.66526
- 100+11.62552100+1.51077
- 250+10.32170250+1.34134
- 国内价格 香港价格
- 500+9.50596500+1.23533
- 1000+8.812971000+1.14527
- 1500+8.457011500+1.09901
- 2500+8.054452500+1.04670
- 3500+7.814533500+1.01552
- 5000+7.580165000+0.98506
