Female Card Edge
.100” [2.54 mm] Contact Centers, .560” [14.22 mm] Profile, .400” [10.16 mm] Wide Body,
Double Point Contact, Dip Solder/Wire Wrap/Right Angle/Card Extender
SPECIFICATIONS
Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] PC board
PPS, PBT or PA9T insulator
3 Amps current rating for one contact energized
30 milli Ohms maximum at rated current
UL Flammability Rating: 94V-0
TERMINATION TYPE
Female Card Edge
POINT OF
CONTACT
POINT OF
CONTACT
POINT OF
CONTACT
L
POINT OF
CONTACT
L
POINT OF
CONTACT
POINT OF
CONTACT
.150” [3.81]
.200” [5.08]
ACCOMMODATES
.062” [1.57] PCB
CARD EXTENDER
(PN, PR)
RIGHT ANGLE
(PB, PG, PE, PJ, PU)
DIP SOLDER/WIRE WRAP
(PD, PF, PS, PM)
TERMINATION
TERMINATION
TYPE
PD
DIP SOLDER
PS
PF
* POST LENGTH
L ±.025”ʺ [0.64]
L
FITS MIN.
HOLE SIZE
STANDOFF
.160ʺ [4.06]
.043ʺ [1.09]
YES
DIP SOLDER
.190ʺ [4.83]
.043ʺ [1.09]
YES
DIP SOLDER
.270ʺ [6.86]
.043ʺ [1.09]
YES
PM
WIRE WRAP
.560ʺ [14.22]
.043ʺ [1.09]
YES
PB
RIGHT ANGLE
.100ʺ [2.54]
.043ʺ [1.09]
NO
PG
RIGHT ANGLE
.140ʺ [3.56]
.043ʺ [1.09]
NO
PE
RIGHT ANGLE
.180ʺ [4.57]
.043ʺ [1.09]
NO
PU
RIGHT ANGLE
.250ʺ [6.35]
.043ʺ [1.09]
NO
PJ
RIGHT ANGLE
.500ʺ [12.70]
.043ʺ [1.09]
NO
PR
CARD EXTENDER
.225ʺ [5.73]
N/A
NO
PN
CARD EXTENDER
.595ʺ [15.12]
N/A
NO
* OTHER POST LENGTHS AVAILABLE, CONTACT FACTORY.
MOUNTING STYLE (Standoffs included on straight terminations only.)
64
Ø.125” [3.18]
#4-40
.250” [6.35]
.250” [6.35]
CLEARANCE HOLE
(H)
THREADED INSERT
( I)
Ø.125” [3.18]
.255” [6.48]
SIDE MOUNTING
(S)
NO MOUNTING
EARS (N)
www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
Female Card Edge
PART NUMBER OPTIONS
E B
C 10 D PD H - Sxxx
MATERIALS (INSULATOR/CONTACT)
E = PBT/Phosphor Bronze
R = PPS/Phosphor Bronze
G = PA9T/Phosphor Bronze
H = PBT/Beryllium Copper
A = PPS/Beryllium Copper
J = PA9T/Beryllium Copper
(Consult factory for other materials.)
Refer to Page 7 for Operating/Processing Temperatures
CONTACT FINISH - RoHS Compliant
MODIFICATION CODE (Consult Factory)
OMIT FOR STANDARD
MOUNTING STYLE (Opposite Page)
H = Clearance Holes
I = Threaded Inserts
S = Side Mounting
N = No Mounting
All platings are Lead Free and have .000050” Nickel underplate
Contact Surface
B = .000010” Gold
C = .000030” Gold
TERMINATION TYPE (Opposite Page)
PD, PF, PS = .025” [0.64 mm] Square Dip Solder
PM = .025” [0.64 mm] Square Wire Wrap
PB, PG, PE, PJ, PU = .025” [0.64 mm] Square Right Angle
PN, PR = .025” [0.64 mm] Square Card Extender
Termination
.000100” Pure Tin, Matte
CONTACT CENTERS
C = .100” [2.54 mm]
NUMBER OF CONTACT POSITIONS
See Chart Below
READOUT (Opposite Page)
D = Dual
Female Card Edge
DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches.
.425 [10.80] INSERTION DEPTH
E
D
B
A
.400 [10.16]
C
.180 [4.57]
.560
[14.22]
.250
[6.35]
.050
[1.27]
.100 [2.54]
.025 [0.64] SQ.
F
REFER TO TERMINATION TYPE
Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory.
INCHES
MILLIMETERS
POSITIONS/
CONTACTS
A±.008
B±.008
C±.015
D±.010
E±.020
F±.015
A±0.20
B±0.20
C±0.38
D±0.25
E±0.51
F±0.38
06/12
07/14*
08/16
10/20
12/24*
13/26*
15/30
17/34*
18/36*
20/40
22/44*
24/48*
25/50*
28/56*
30/60
31/62*
35/70*
36/72*
40/80
43/86
44/88
49/98*
50/100
55/110*
60/120*
61/122*
65/130*
70/140*
0.500
0.600
0.700
0.900
1.100
1.200
1.400
1.600
1.700
1.900
2.100
2.300
2.400
2.700
2.900
3.000
3.400
3.500
3.900
4.200
4.300
4.800
4.900
5.400
5.900
6.000
6.400
6.900
0.700
0.800
0.900
1.100
1.300
1.400
1.600
1.800
1.900
2.100
2.300
2.500
2.600
2.900
3.100
3.200
3.600
3.700
4.100
4.400
4.500
5.000
5.100
5.600
6.100
6.200
6.600
7.100
0.860
0.960
1.060
1.260
1.460
1.560
1.760
1.960
2.060
2.260
2.460
2.660
2.760
3.060
3.260
3.360
3.760
3.860
4.260
4.560
4.660
5.160
5.260
5.760
6.260
6.360
6.760
7.260
1.175
1.275
1.375
1.575
1.775
1.875
2.075
2.275
2.375
2.575
2.775
2.975
3.075
3.375
3.575
3.675
4.075
4.175
4.575
4.875
4.975
5.475
5.575
6.075
6.575
6.675
7.075
7.575
1.435
1.535
1.635
1.835
2.035
2.135
2.335
2.535
2.635
2.835
3.035
3.235
3.335
3.635
3.835
3.935
4.335
4.435
4.835
5.135
5.235
5.735
5.835
6.335
6.835
6.935
7.335
7.835
0.740
0.840
0.940
1.140
1.340
1.440
1.640
1.840
1.940
2.140
2.340
2.540
2.640
2.940
3.140
3.240
3.640
3.740
4.140
4.440
4.540
5.040
5.140
5.640
6.140
6.240
6.640
7.140
12.70
15.24
17.78
22.86
27.94
30.48
35.56
40.64
43.18
48.26
53.34
58.42
60.96
68.58
73.66
76.20
86.36
88.90
99.06
106.68
109.22
121.92
124.46
137.16
149.86
152.40
162.56
175.26
17.78
20.32
22.86
27.94
33.02
35.56
40.64
45.72
48.26
53.34
58.42
63.50
66.04
73.66
78.74
81.28
91.44
93.98
104.14
111.76
114.30
127.00
129.54
142.24
154.94
157.48
167.64
180.34
21.84
24.38
26.92
32.00
37.08
39.62
44.70
49.78
52.32
57.40
62.48
67.56
70.10
77.72
82.80
85.34
95.50
98.04
108.20
115.82
118.36
131.06
133.60
146.30
159.00
161.54
171.70
184.40
29.85
32.39
34.93
40.01
45.09
47.63
52.71
57.79
60.33
65.41
70.49
75.57
78.11
85.73
90.81
93.35
103.51
106.05
116.21
123.83
126.37
139.07
141.61
154.31
167.01
169.55
179.71
192.41
36.45
38.99
41.53
46.61
51.69
54.23
59.31
64.39
66.93
72.01
77.09
82.17
84.71
92.33
97.41
99.95
110.11
112.65
122.81
130.43
132.97
145.67
148.21
160.91
173.61
176.15
186.31
199.01
18.80
21.34
23.88
28.96
34.04
36.58
41.66
46.74
49.28
54.36
59.44
64.52
67.06
74.68
79.76
82.30
92.46
95.00
105.16
112.78
115.32
128.02
130.56
143.26
155.96
158.50
168.66
181.36
* Consult factory for availability.
65
很抱歉,暂时无法提供与“ECC25DPDS”相匹配的价格&库存,您可以联系我们找货
