MP2060 Kool-Pak® Clip Mount Power Film Resistor
TO-220 Style Power Resistor Designed for Clip Mounting - Non-Inductive
Up to 60 Watts continuous power at +25°C case temperature, 0.020Ω and above.
Up to 60 Amps continuous current at +25°C case temperature, 0.015Ω and below.
TO-220 Style package utilizes proven power semiconductor thermal solutions.
Equivalent to UL94 V-0 flammability rating.
Excellent pulse/surge performance.
Non-inductive design for high speed switching, snubbers and rf applications.
Operation up to +150°C case temperature.
Electrically isolated case.
Model
Package
Power
Rating
Resistance
0.010Ω
TO-220
Style
0.015Ω
RATED POWER %
0.020Ω to 1.00K
Derating Curve
100
80
60
40
100
150
CASE TEMPERATURE, °C
Current
Limited
Current
Limited
Current
Limited
60 Arms
18 Watts
0.005Ω
MP2060
36 Watts *
54 Watts *
60 Watts *
Max. Current
Max.
Rating (Amps) Voltage
60 Arms
60 Arms
I=
250 Vrms
P/R
Thermal Resistance
RθJC
Film (J) to Case (C)
6.94°C/Watt
3.47°C/Watt
2.31°C/Watt
2.08°C/Watt
* Derating Using Case Temperature (TC):
All power and associated overload ratings are
derated based upon case temperature using the
derating curve. The case temperature is measured at the center of the ceramic mounting surface, with the part properly mounted and under
electrical load. Without a heat sink, when in free
air at +25°C, the MP2060 is rated for 2.5 watts.
The thermal design should satisfy the following equation:
Case Temperature (Tc) + [Thermal Resistance (RθJC) x power applied (Watts)] ≤ 150°C, considering the full
operating temperature range of the application.
Mounting Note: Mount on a smooth, clean and flat heat sink surface with a thermal interface material, such as
thermal grease. The entire exposed ceramic portion must be in contact with the heat sink. When using a
spring clip, it is recommended that a mounting force of 8 to 30 pounds (35 to 130 N) be applied to the center of
the package. The clip should be round or smooth in the contact area to avoid concentrating the load on a small
point of the plastic body of the package. Another mounting option is to use a pressure bar method which can
achieve a greater mounting force with a greater contact area.
For additional applications information regarding mounting and pulse handling see the Caddock Applications Notes at caddock.com or contact Applications Engineering.
0.175 ± 0.010
(4.45 ± 0.26)
0.410 ± 0.010
(10.41 ± 0.26)
0.150 ± 0.030
(3.81 ± 0.76)
0.640 ± 0.010
(16.26 ± 0.26)
MP2060
50.0
1%
0.100 ± 0.020
(2.54 ± 0.51)
0.500 ± 0.050
(12.70 ± 1.27)
0.050 ± 0.007
(1.27 ± 0.18)
0.200 ± 0.010
(5.08 ± 0.26)
0.035 ± 0.007
(0.89 ± 0.18)
0.105 ± 0.010
(2.67 ± 0.26)
DIMENSIONS IN INCHES AND (MILLIMETERS)
Ordering Information:
Model Number:
Standard Resistance Values:
Tolerance: 1% Standard (except as noted)
0.005 Ω 5%
0.010 Ω 2%
0.015 Ω 2%
0.020 Ω
0.025 Ω
0.030 Ω
0.033 Ω
0.040 Ω
0.050 Ω
0.075 Ω
0.10 Ω
0.15 Ω
0.20 Ω
0.25 Ω
0.30 Ω
10.0 Ω
12.0 Ω
15.0 Ω
20.0 Ω
25.0 Ω
27.0 Ω
30.0 Ω
33.0 Ω
40.0 Ω
47.0 Ω
50.0 Ω
56.0 Ω
75.0 Ω
100 Ω
120 Ω
150 Ω
200 Ω
250 Ω
300 Ω
330 Ω
400 Ω
470 Ω
500 Ω
560 Ω
750 Ω
1.00 K
For custom values and tolerances contact
MP2060 - 0.050 - 1%
Resistor Value:
0.33 Ω
0.40 Ω
0.50 Ω
0.75 Ω
1.00 Ω
1.50 Ω
2.00 Ω
2.50 Ω
3.00 Ω
3.30 Ω
4.00 Ω
5.00 Ω
7.50 Ω
8.00 Ω
Tolerance
Packaging Information: MP2060 resistors are packaged in plastic shipping tubes, 50 pieces
per tube. These resistors are available in a 50 piece minimum quantity and in full tube
quantity increments (i.e. 50, 100, 150, etc.).
ELECTRONICS, INC.
e-mail: caddock@caddock.com • web: www.caddock.com
For Caddock Distributors listed by country see caddock.com/contact/dist.html
© 2003-2017 Caddock Electronics, Inc.
New
Clip
M
Value ount
0.005s to
These products are covered by one or more
patents, also patents pending.
Specifications:
Temperature Coefficient:
TC referenced to +25°C, ∆R taken at +150°C
0.50 ohm and above, -20 to +80 ppm/°C
0.050 ohm to 0.49 ohm, 0 to +100 ppm/°C
0.015 ohm to 0.049 ohm, 0 to +200 ppm/°C
0.005 ohm to 0.014 ohm, 0 to +300 ppm/°C
Operating Temperature: -55°C to +150°C
Inductance: 10 nH typical in series when
measured at the shoulder of the lead.
Capacitance:
很抱歉,暂时无法提供与“MP2060-0.50-1%”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+113.547121+14.65669
- 10+92.8816110+11.98918
- 25+88.1421025+11.37741
- 50+85.3952150+11.02284
- 100+83.20591100+10.74024
- 250+80.98087250+10.45303
- 500+79.68953500+10.28635
- 1000+78.661071000+10.15359
