ACM06DSMH-S328
ACM06DSMH-S328
    SULLINS
    CONN EDGECARD 12POS .156"
ACM06DSMH-S328 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 1521 INITIAL RELEASE 10/3/2007 VJ B 2246 ADD S1487, 47 & 50-POSITION, UPDATE NOTES 1/25/2011 JH F E F FIRST POSITION INDICATOR D B 2X A .075 1.91 SEE NOTE 13 E C .180 4.57 .125 3.18 A E .297 7.54 INSERTION DEPTH .370 9.40 .550 13.97 .250 6.35 .620±.025 15.75±0.64 D A .156 3.96 TYP .200 5.08 ROW SPACING .025 0.64 FITS .040 [1.01] MIN. HOLE _ _ M _ _ DSMH SECTION A-A 2X .125 3.18 FOR 'H' OR 'I' MOUNTING D A C CONTACT MARKINGS (LETTERS G, I, O & Q NOT USED) .200 5.08 .156 3.96 C SIZES 06-25 & 30 1 2 ... 23 24 ... 29 30 A B ... A B ... H J .040 1.02 MIN PCB LAYOUT RECOMMENDED D SIZES 28 & 31 1 2 ... 23 24 ... 30 31 A B ... A B ... J K B A NOTES: 1. INSULATOR MATERIAL:SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE:SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. VOLTAGE RATING: 950 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 3 AMP PER CONTACT 9. CONTACT RESISTENCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB 16. MODIFICATION:SEE PART NUMBER CODING SIZES 36 - 43 A B ... A B ... X Y 1 2 ... 23 24 ... 42 43 CONTACT ID SCALE 4:1 7 6 5 SIZES 47 & 50 1 3 ... 97 99 2 4 ... 98 100 CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 B 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME XX/XX/XX MNH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, HP PART NUMBER _ _M_ _DSM_ - (S38, S81, S328, S1487) SIZE C CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11150 SHEET 1 OF 3 1 REV B FILE NAME: C11150, _ _M_ _DSM_ (OMIT, S38,S81,S328, S1487) 8 7 E 1 2 3 F 2X #4-40 THREADED INSERTS D F 4 5 6 E _ _ M _ _ DSMI 2X 2X D D .125 3.18 THRU .125 3.18 THRU D .245 6.22 _ _ M _ _ DSMS C C C B B _ _ M _ _ DSMN CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME XX/XX/XX MNH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, HP PART NUMBER _ _M_ _DSM_ - (S38, S81, S328, S1487) SIZE C CAGE CODE 54453 SCALE: 1:1 2 DWG. NO. C11150 SHEET 2 OF 3 1 REV B FILE NAME: C11150, _ _M_ _DSM_ (OMIT, S38,S81,S328, S1487) 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME XX/XX/XX MNH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, HP PART NUMBER _ _M_ _DSM_ - (S38, S81, S328, S1487) SIZE C CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. C11150 SHEET 3 OF 3 1 REV B FILE NAME: C11150, _ _M_ _DSM_ (OMIT, S38,S81,S328, S1487)
ACM06DSMH-S328 价格&库存
很抱歉,暂时无法提供与“ACM06DSMH-S328”相匹配的价格&库存,您可以联系我们找货
