8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
1521
INITIAL RELEASE
10/3/2007
VJ
B
2246
ADD S1487, 47 & 50-POSITION, UPDATE NOTES
1/25/2011
JH
F
E
F
FIRST
POSITION
INDICATOR
D
B
2X
A
.075 1.91
SEE NOTE 13
E
C
.180 4.57
.125 3.18
A
E
.297 7.54
INSERTION
DEPTH
.370 9.40
.550 13.97
.250 6.35
.620±.025 15.75±0.64
D
A
.156 3.96 TYP
.200 5.08
ROW SPACING
.025 0.64
FITS .040 [1.01] MIN. HOLE
_ _ M _ _ DSMH
SECTION A-A
2X .125 3.18
FOR 'H' OR 'I'
MOUNTING
D
A
C
CONTACT MARKINGS
(LETTERS G, I, O & Q NOT USED)
.200 5.08
.156 3.96
C
SIZES 06-25 & 30
1 2 ... 23 24 ... 29 30
A B ... A B ... H J
.040 1.02 MIN
PCB LAYOUT RECOMMENDED
D
SIZES 28 & 31
1 2 ... 23 24 ... 30 31
A B ... A B ... J K
B
A
NOTES:
1. INSULATOR MATERIAL:SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE:SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. VOLTAGE RATING: 950 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 3 AMP PER CONTACT
9. CONTACT RESISTENCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 16 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
INTERNAL INSPECTION TO BE PER SULLIN'S WORK INSTRUCTION WI7.3-01
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB
16. MODIFICATION:SEE PART NUMBER CODING
SIZES 36 - 43
A B ... A B ... X Y
1 2 ... 23 24 ... 42 43
CONTACT ID
SCALE 4:1
7
6
5
SIZES 47 & 50
1 3 ... 97 99
2 4 ... 98 100
CUSTOMER COPY
DRAWN
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
Pb
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
B
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
INTERPRET DIMENSIONS AND
TOLERANCING
PER: ASME Y14.5M-2009
3
DATE
NAME
XX/XX/XX MNH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
A
EDGECARD, .156 CC, HP
PART NUMBER
_ _M_ _DSM_ - (S38, S81, S328, S1487)
SIZE
C
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11150
SHEET 1 OF 3
1
REV
B
FILE NAME: C11150, _ _M_ _DSM_ (OMIT, S38,S81,S328, S1487)
8
7
E
1
2
3
F
2X #4-40
THREADED
INSERTS
D
F
4
5
6
E
_ _ M _ _ DSMI
2X
2X
D
D
.125 3.18 THRU
.125 3.18
THRU
D
.245 6.22
_ _ M _ _ DSMS
C
C
C
B
B
_ _ M _ _ DSMN
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
XX/XX/XX MNH
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 1:1
2
DWG. NO.
C11150
SHEET 2 OF 3
1
REV
B
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
XX/XX/XX MNH
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11150
SHEET 3 OF 3
1
REV
B
很抱歉,暂时无法提供与“ACM06DSMN”相匹配的价格&库存,您可以联系我们找货
