JW60ZA0R00
JW60ZA0R00
    SEI
    插件电阻 - 0Ω - - -
JW60ZA0R00 数据手册
JW Series Stackpole Electronics, Inc. Tin Plated Jumper Wire Resistor Resistive Product Solutions Features: • • • • • • • Ideal for crossovers or jumpers on circuit boards High current ratings Standard JW is copper plated steel, with 100% tin overplate 100% tin plate on copper wire is available as type JWQ 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical and Mechanical Specifications Type / Code Gauge Reference Maximum Current (A) JW50 24 3 JW55 23 3 JW60 22 3 JW80 20 4 Diameter 0.020 0.50 0.022 0.55 0.024 0.60 0.031 0.80 ± ± ± ± ± ± ± ± 0.0008 0.02 0.0012 0.03 0.0012 0.03 0.002 0.05 Unit inches mm inches mm inches mm inches mm Performance Characteristics Item Coating Thickness Specification 5u ± 2u 7.1 0.4mm - below 0.6mm - 250g 7.2 0.6mm - below 1 - 500g 8.1 Sn 100%: Heat 195ºC ± 5ºC / 1 hour Bending Heat Reliability Humidity 40ºC / 90 - 95RH / 72 hours Solderability 235ºC ± 5ºC / 3 seconds Rev Date: 09/01/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com JW Series Stackpole Electronics, Inc. Tin Plated Jumper Wire Resistor Resistive Product Solutions RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series JW Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Tin Plated Jumper Wire Resistor Axial YES 100% Matte Sn Jan-04 04/01 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order J W Product Series Size Code Description Code Diameter JW Jumper Wire 50 0.5 mm 55 0.55 mm 60 0.6 mm 80 0.8 mm 5 0 Z T 0 R Tolerance Packaging Code Tol Code Description Size Z Zero Ohm 50, 55, 60 T Tape and Reel 80 50, 55, 60 A Ammo 80 Rev Date: 09/01/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 0 0 Resistance Value Quantity 10000 8000 10000 8000 Four characters with the multiplier used as the decimal holder. Zero Ohm = 0R00 www.seielect.com marketing@seielect.com
JW60ZA0R00 价格&库存
很抱歉,暂时无法提供与“JW60ZA0R00”相匹配的价格&库存,您可以联系我们找货
