GBA30DRSZ-S664
GBA30DRSZ-S664
    SULLINS
    CONN EDGECARD 60POS DIP .125 SLD
GBA30DRSZ-S664 数据手册
Female Card Edge .125” [3.18 mm] Contact Centers, .610” [15.49 mm] Insulator Height, Dip Solder/Wire Wrap/Right Angle for .093” [2.36 mm] or .125” [3.18 mm] Mating PCB Sullins Female Card Edge SPECIFICATIONS • Accommodates .093” ± .008” [2.36 mm 0.20 mm] PC board or .125” ± .008” [3.18 mm ± 0.20 mm] mating PCB • PBT, PPS or PA9T insulator • Molded-in key available • 3 Amps current rating for one contact energized • 30 milli Ohms maximum at rated current • UL Flammability Rating: 94V-0 READOUT HALF LOADED (H) DUAL (D) TERMINATION TYPE L POST CROSS SECTION (K) POST LENGTH L ± .025”ʺ [0.64] FITS MIN. HOLE SIZE RS DIP SOLDER .025ʺ [0.64] SQ. .190ʺ [4.83] .040ʺ [1.02] RM WIRE WRAP .025ʺ [0.64] SQ. .560ʺ [14.20] .040ʺ [1.02] TA RIGHT ANGLE .025ʺ [0.64] SQ. .100ʺ [2.54] .043ʺ [1.09] TB RIGHT ANGLE .025ʺ [0.64] SQ. .180ʺ [4.57] .043ʺ [1.09] TM RIGHT ANGLE .025ʺ [0.64] SQ. .250ʺ [6.35] .043ʺ [1.09] TERMINATION TYPE .030” [0.76] .150” [3.81] L .250” [6.35] K LOOP BELLOWS (RS, RM) RIGHT ANGLE DIP SOLDER (TA, TB, TM) PCB LAYOUT COMPONENT SIDE .125” [3.18] TYP. .250” [6.35] .150” [3.81] Ø .040” [1.02] 2X Ø .125” [3.18] FOR (D) OR (T) MOUNTING A D .125” [3.18] TYP. Ø .043” [1.09] .095” [2.41] A D 2X Ø .125” [3.18] FOR (Z) MOUNTING RIGHT ANGLE TERMINATIONS (TA, TB, TM) STRAIGHT PIN TERMINATIONS (RS, RM) MOUNTING STYLE Ø.125” [3.18] #4-40 .250” [6.35] NO MOUNTING EARS (N) 66 FLUSH MOUNTING (D) .250” [6.35] FLUSH MOUNTING WITH THREADED INSERT (T) Ø.125” [3.18] .250” [6.35] FLUSH MOUNTING WITH SIDE HOLES (Z) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .125” [3.18 mm] Contact Centers, .610” [15.49 mm] Insulator Height, Dip Solder/Wire Wrap/Right Angle for .093” [2.36 mm] or .125” [3.18 mm] Mating PCB PART NUMBER OPTIONS E B A 50 D RM D - S273 MODIFICATION CODE (Consult Factory) -S273 = FOR .093” ± .008” [2.36 mm ± 0.20 mm] THICK MATING PCB -S664 = FOR .125” ± .008” [3.18 mm ± 0.20 mm] THICK MATING PCB MOUNTING STYLE (Opposite Page) N = No Mounting D = Flush Mounting T = Flush Mounting With Threaded Inserts Z = Flush Mounting With Side Holes CONTACT FINISH - RoHS Compliant All platings are Lead Free and have .000050” Nickel underplate Contact Surface .000010” Gold .000030” Gold .000010” Gold .000030” Gold Contact Surface S = .000010” Gold M = .000030” Gold E = .000100” Pure Tin, Matte B C G Y Termination .000100” Pure Tin, Matte .000100” Pure Tin, Matte .000005” Gold .000005” Gold Overall Plating .000010” Gold .000010” Gold .000100” Pure Tin, Matte = = = = Sullins Female Card Edge MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze(Standard) R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT & Beryllium Copper A = PPS & Beryllium Copper J = PA9T & Beryllium Copper (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures TERMINATION TYPE (Opposite Page) RS = .025” [0.64 mm] Square Dip Solder RM = .025” [0.64 mm] Square Wire Wrap TA, TB, TM = .025” [0.64 mm] Square Right Angle READOUT (Opposite Page) D = Dual H = Half Loaded NUMBER OF CONTACT POSITIONS See Chart Below CONTACT CENTERS A = .125” [3.18 mm] DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. .297 [7.54] INSERTION DEPTH C REFER TO MOUNTING STYLE .360 [9.14] .470 [11.94] .610 [15.49] A B D C .060 [1.52] REFER TO TERMINATION TYPE, SEE OPPOSITE PAGE .125 [3.18] TYP. F Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. INCHES MILLIMETERS POSITIONS/ CONTACTS A±.008 B±.008 C±.015 D±.010 E±.020 F±.015 A±0.20 B±0.20 C±0.38 D±0.25 E±0.51 F±0.38 06/12* 08/16* 10/20* 14/28* 15/30* 18/36* 22/44* 24/48* 25/50 28/56* 30/60 31/62* 32/64 35/70* 36/72 40/80* 43/86* 44/88* 49/98* 50/100 0.625 0.875 1.125 1.625 1.750 2.125 2.625 2.875 3.000 3.375 3.625 3.750 3.875 4.250 4.375 4.875 5.250 5.375 6.000 6.125 0.875 1.125 1.375 1.875 2.000 2.375 2.875 3.125 3.250 3.625 3.875 4.000 4.125 4.500 4.625 5.125 5.500 5.625 6.250 6.375 1.035 1.285 1.535 2.035 2.160 2.535 3.035 3.285 3.410 3.785 4.035 4.160 4.285 4.660 4.785 5.285 5.660 5.785 6.410 6.535 1.295 1.545 1.795 2.295 2.420 2.795 3.295 3.545 3.670 4.045 4.295 4.420 4.545 4.920 5.045 5.545 5.920 6.045 6.670 6.795 1.555 1.805 2.055 2.555 2.680 3.055 3.555 3.805 3.930 4.305 4.555 4.680 4.805 5.180 5.305 5.805 6.180 6.305 6.930 7.055 0.915 1.165 1.415 1.915 2.040 2.415 2.915 3.165 3.290 3.665 3.915 4.040 4.165 4.540 4.665 5.165 5.540 5.665 6.290 6.415 15.88 22.23 28.58 41.28 44.45 53.98 66.68 73.03 76.20 85.73 92.08 95.25 98.43 107.95 111.13 123.83 133.35 136.53 152.40 155.58 22.23 28.58 34.93 47.63 50.80 60.33 73.03 79.38 82.55 92.08 98.43 101.60 104.78 114.30 117.48 130.18 139.70 142.88 158.75 161.93 26.29 32.64 38.99 51.69 54.86 64.39 77.09 83.44 86.61 96.14 102.49 105.66 108.84 118.36 121.54 134.24 143.76 146.94 162.81 165.99 32.89 39.24 45.59 58.29 61.47 70.99 83.69 90.04 93.22 102.74 109.09 112.27 115.44 124.97 128.14 140.84 150.37 153.54 169.42 172.59 39.50 45.85 52.20 64.90 68.07 77.60 90.30 96.65 99.82 109.35 115.70 118.87 122.05 131.57 134.75 147.45 156.97 160.15 176.02 179.20 23.24 29.59 35.94 48.64 51.82 61.34 74.04 80.39 83.57 93.09 99.44 102.62 105.79 115.32 118.49 131.19 140.72 143.89 159.77 162.94 * Consult factory for availability. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 67
GBA30DRSZ-S664 价格&库存
很抱歉,暂时无法提供与“GBA30DRSZ-S664”相匹配的价格&库存,您可以联系我们找货
