EBA35DSSH-S288
EBA35DSSH-S288
    SULLINS
    CONNEDGEDUALFMALE70POS0.125
EBA35DSSH-S288 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2898 INITIAL RELEASE 1/17/2014 JHSU E F F D FIRST POSITION INDICATOR B A 2X .125 3.18 THRU .075 1.91 SEE NOTE 13 E E +.005 +0.13 .370 9.40 - .015 - 0.38 C A .030 0.77 .180 4.57 D D .550 13.97 .250 6.35 ACCEPTS .062" PCB A F C SECTION A-A C _ _A_ _DSSH-S288 B .300 7.62 INSERTION DEPTH .235±.025 5.97±0.64 .025 0.63 .125 3.18 TYP .020 0.51 CONTACT MARKINGS 1 3 5 ... 45 47... 99 2 4 6 ... 46 48... 100 CONTACT ID NOTES: SCALE 4:1 1. INSULATOR MATERIAL: SEE PART NUMBER CODING CONTACTS NOT 2. CONTACT MATERIAL: SEE PART NUMBER CODING SHOWN FOR CLARITY 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 750 VAC MINIMUM AT SEA LEVEL. 8. CONTACT RATING: 3 AMP DRAWN DATE NAME 9. CONTACT RESISTANCE: 30 MILLI OHM MAX UNLESS OTHERWISE SPECIFIED: 6/24/2011 JH 10. INSULATION RESISTANCE: 5000 MEGA OHM MIN DIMENSIONS ARE IN INCHES [MM] 11. DURABILITY: 500 CYCLES MIN TITLE TOLERANCES: ANGULAR: 30' 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE EDGECARD .125" PITCH, HP .XX= .02 [.5] .XXX= .005 [.13] 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] PART NUMBER .XXXX= .0005 [.013] _ _A_ _DSS_-S288 14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062" TEST BLADE. CAGE CODE DWG. NO. SIZE INTERPRET DIMENSIONS AND 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062" PCB TOLERANCING C 54453 C12338 16. MODIFICATION: CARD EXTENDER BEND FOR .062" PCB PER: ASME Y14.5M-2009 RoHS COMPLIANT B CUSTOMER COPY A Pb THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. SCALE: 2:1 8 7 6 5 4 3 2 SHEET 1 OF 3 1 A REV A FILE NAME: C12338, _ _A_ _DSS_-S288 8 7 4 5 6 1 2 3 F F E E D C 2X .125 3.18 THRU 2X .245 6.22 _ _A_ _DSSS-S288 _ _A_ _DSSN-S288 D D A 2X .095 2.41 D 2X #4-40 THREADED INSERTS C C L±.015 (L= DIM 'A' + .190[4.83]) B B _ _A_ _DSSB-S288 _ _A_ _DSSI-S288 CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 6/24/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _A_ _DSS_-S288 CAGE CODE 54453 SCALE: 1.5:1 2 A EDGECARD .125" PITCH, HP DWG. NO. C12338 SHEET 2 OF 3 1 REV A FILE NAME: C12338, _ _A_ _DSS_-S288 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 6/24/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _A_ _DSS_-S288 CAGE CODE 54453 SCALE: 2:1 2 A EDGECARD .125" PITCH, HP DWG. NO. C12338 SHEET 3 OF 3 1 REV A FILE NAME: C12338, _ _A_ _DSS_-S288
EBA35DSSH-S288 价格&库存
很抱歉,暂时无法提供与“EBA35DSSH-S288”相匹配的价格&库存,您可以联系我们找货
