FSH-105-04-L-DH-SL
FSH-105-04-L-DH-SL
    SAMTEC(申泰)
    SMD,P=1.27mm,卧贴
    2X5P 间距:1.27MM 方针 卧贴
FSH-105-04-L-DH-SL 数据手册
REVISION AJ FSH-1XX-XX-XXX-XX-XX-X-XX DO NOT SCALE FROM THIS PRINT No OF POSITIONS -DH ROW SPEC: -05 THRU -25 -RA ROW SPEC: -05 THRU -46 (PER ROW) [INCREMENTS OF 5 STD] ((No OF POS + 4) x .0500[1.270]) .008[.20] LEAD STYLE -01 -02 -03 -04 .099 2.51 REF .259 6.58 REF ROW/TAIL SPECIFICATION -DH: DOUBLE HORIZONTAL (USE FSH-XX-D-ES-XX-XX) -RA: RIGHT ANGLE (USE FSH-XX-D-ES-XX-XX) PLATING SPECIFICATION -L: LIGHT SELECTIVE (USE T-1S15-XX-L) -F: FLASH SELECTIVE (USE T-1S15-XX-F) -S: SELECTIVE GOLD/MATTE TIN TAIL (USE T-1S15-XX-S) -LM: LIGHT SELECTIVE GOLD/MATTE TIN TAIL(USE T-1S15-XX-L) -FM: FLASH SELECTIVE GOLD/MATTE TIN TAIL(USE T-1S15-XX-F) -STL: SELECTIVE GOLD CONTACT, TIN/LEAD TAIL(USE T-1S15-XX-STL) -FTL: FLASH SELECTIVE GOLD CONTACT, TIN/LEAD TAIL(USE T-1S15-XX-FTL) SEE NOTE 10 .150 3.81 REF PACKAGING BLANK: TUBES (SEE NOTE 13) -TR: TAPE & REEL(SEE NOTES 14 & 15) (NOT AVAILABE WITH -RA) -FR: FULL REEL QTY TAPE & REEL (SEE NOTES 15 & 14) (NOT AVAILABE WITH -RA) PICK AND PLACE OPTION -C: POLYIMIDE FILM (USE K-DOT-.177-.281-.005) (10 POSITION MIN) (SEE FIG 3, SHT 2) (NOT AVAILABLE WITH -RA) OPTION -SL: SOLDER LOCKS .016 0.41 SQ REF .125 3.18 (No OF POS x .0500 [1.270]) -.0500[1.270] .040 1.02 REF "A" (SEE NOTE 3) C .160 4.06 REF .040 1.00 REF .205±.010 5.21±0.25 2 .135 3.43 REF .155 3.94 REF T-1S15-03-XXX [PIN 2] 1 .050 1.27 REF NOTES: SEE NOTE 2 T-1S15-03-XXX [PIN 1] .025 0.64 (No OF POS + 2) x .0500 [1.270] SEE NOTE 5 .050 1.27 REF .035 0.89 .028 0.70 FIG 1 1. C REPRESENTS A CRITICAL DIMENSION. 2. COPLANARITY TO INCLUDE INSULATOR: .0060[.152]. 3. MAXIMUM HEIGHT VARTIATION BETWEEN ROWS: .005[.13]. 4. MINIMUM PUSHOUT FORCE: .5 LB. 5. MAXIMUM BURR ALLOWED [SHEARED TAILS]: .002[.05]. 6. MAXIMUM ALLOWABLE BOW: .002[.05] INCH/INCH AFTER ASSEMBLY. 7. ALL FIRST ROW PINS TO BE .001 BELOW TO .003 ABOVE BODY (SEE SHT 3). 8. MAX FLASH TO BE .015[.38]. C 9. END SHROUDS NOT TO BE CUT. 10. POSITIONS 13-28 (ONCE CUT) TO HAVE 1 TAB EVENLY SPACED BETWEEN THE FIRST AND LAST CORE. POSITIONS 29-46 TO HAVE TWO TABS EVENLY SPACED BETWEEN THE FIRST AND LAST CORES. 11. FOR POSITIONS 13-27, MIDDLE SHROUD WILL NOT BE CENTERED FOR ODD POSITION PARTS. 12. ALL SECOND ROW PINS TO BE .003 BELOW TO .003 ABOVE BODY (SEE SHT 4). 13. TUBES ARE STANDARD PACKAGING. 14. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. 15. ATTACH LABEL ON EACH REEL. .085 2.15 -DH: DOUBLE HORIZONTAL [AVAILABLE IN POSITIONS -05 THRU -25] UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[.3] .XXX: .005[.13] .XXXX: .0020[.051] PATENT NUMBERS 6159045 MATERIAL: C 2 * .0495[1.26] REF PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING VECTRA E130i, COLOR: BLACK TERMINAL: PHOS BRONZE, THICKNESS: .0160 SQ F:\DWG\MISC\MKTG\FSH-1XX-XX-XXX-XX-XX-X-XX-MKT.SLDDRW SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 SHROUDED TERMINAL ASSEMBLY DWG. NO. FSH-1XX-XX-XXX-XX-XX-X-XX BY: DEANP 9/8/1999 SHEET 1 OF 4 REVISION AJ FIG 3 FIG 2 -C: POLYIMIDE FILM NOTE: "R" = USE MEASURED DIMENSION (REF) "S" = {("R" - .1772[4.501]) / 2} .020[.51] -RA: RIGHT ANGLE (SAME AS FIG 1, UNLESS OTHERWISE STATED) [AVAILABLE IN POSITIONS -05 THRU -46] "R" (SEE NOTE) "S" (SEE NOTE) 2 MAX SWAY (ANY DIRECTION) .142 3.61 .039±.020 0.990±0.51 2 MAX TOE (ANY DIRECTION) .075 1.91 T-1S15-03-XXX "B" 90°±3° .050 1.27 .100 2.53 .177 4.50 REF T-1S15-04-XXX .050 1.27 .09 2.3 -DH .025 0.64 TUBE: PT-1-24-02-53 PLUG: TP-09 PACKAGING VIEW TUBE ALL POSITIONS SEE NOTE 11 -RA TUBE: PT-1-24-01-45 PLUG: TP-07 FIG 4 FSH-119-XX-XX-RA-XX SHOWN F:\DWG\MISC\MKTG\FSH-1XX-XX-XXX-XX-XX-X-XX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 SHROUDED TERMINAL ASSEMBLY DWG. NO. FSH-1XX-XX-XXX-XX-XX-X-XX BY: DEANP 9/8/1999 SHEET 2 OF 4 REVISION AJ IN-PROCESS 1 .090±.005 2.29±0.13 "A" IN-PROCESS 2 (AFTER FIRST ROW FORMED) 'F' "A" .245 6.22 * .001±.002 0.03±0.05 (SEE NOTE 7) DETAIL 'F' SCALE 16 : 1 F:\DWG\MISC\MKTG\FSH-1XX-XX-XXX-XX-XX-X-XX-MKT.SLDDRW PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 SHROUDED TERMINAL ASSEMBLY DWG. NO. FSH-1XX-XX-XXX-XX-XX-X-XX BY: DEANP 9/8/1999 SHEET 3 OF 4 REVISION AJ 'H' .000±.003 0.00±0.08 (SEE NOTE 12) DETAIL 'H' SCALE 16 : 1 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 2.5:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 SHROUDED TERMINAL ASSEMBLY DWG. NO. F:\DWG\MISC\MKTG\FSH-1XX-XX-XXX-XX-XX-X-XX-MKT.SLDDRW FSH-1XX-XX-XXX-XX-XX-X-XX BY: DEANP 9/8/1999 SHEET 4 OF 4
FSH-105-04-L-DH-SL 价格&库存
很抱歉,暂时无法提供与“FSH-105-04-L-DH-SL”相匹配的价格&库存,您可以联系我们找货
FSH-105-04-L-DH-SL
    • 1+21.66480
    • 10+21.14640
    • 50+20.79000
    库存:17
