TSS-113-01-L-D
TSS-113-01-L-D
    SAMTEC(申泰)
    插件
TSS-113-01-L-D 数据手册
SHROUDED .025" SQ POST HEADERS (2.54 mm) .100" PITCH • TSS/HTSS/ZSS SERIES TSS/HTSS/ZSS SERIES Mates: SSW, SSQ, ESW, ESQ, SSM, BCS TSS/HTSS Cable Mates: IDSD SPECIFICATIONS Insulator Material: TSS, ZSS=Black Glass Filled Polyester HTSS=Natural PCT Insulation Resistance: 5000 MΩ min Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Withstanding Voltage: 1000 VRMS TSS - NO. PINS PER ROW 03 (TSS only) HTSS 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 = High Temp Connector Strip LEAD STYLE Specify LEAD STYLE from chart PLATING OPTION T/H (A) –01 (2.92) .115 –02 (4.19) .165 –03 (14.35) .565 ROW OPTION –F –D = Double Row Through-hole (lead style –01, –02 & –03 only) –L –DV = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Double Row Surface Mount (lead style –01 only) (HTSS only) –T = Matte Tin (2.54) .100 x No. of Positions + (1.27) .050 LEAD STYLE - = Gold flash on post, Matte Tin on tail (Not available on -DV) (2.54) .100 x No. of Positions + (3.81) .150 –D–RA LEAD STYLE RIGHT ANGLE (B) –04 (3.30) .130 –05 (5.84) .230 (9.27) .365 = Double Row Right-angle (lead style –04 & –05 only) B (8.89) .350 A —DV (HTSS ONLY) —D -1 ZSS - NO. PINS PER ROW 03, 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 (Standard sizes) MOQ Required LEAD STYLE Specify LEAD STYLE from chart (2.54) .100 x No. of Positions + (3.81) .150 (2.54) .100 x No. of Positions + (1.27) .050 - PLATING OPTION (2.54) .100 - D - –F –L BODY HEIGHT –“XXXX” = Body Height = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail LEAD STYLE –T –01 (16.00) .630 (13.72) .540 –02 (18.54) .730 (16.26) .640 –03 (21.08) .830 (18.80) .740 –04 (23.62) .930 (21.34) .840 –05 (26.16) 1.030 (23.88) .940 –06 (28.70) 1.130 (26.42) 1.040 –07 (31.24) 1.230 (28.96) 1.140 –08 (33.78) 1.330 (31.50) 1.240 –09 (36.32) 1.430 (34.04) 1.340 (9.27) .365 (2.29) .090 MIN —D—RA = Gold flash on post, Matte Tin on tail = Matte Tin (8.89) .350 Note: Some lengths, styles and options are non-standard, non-returnable. ZSS is non-standard, non-returnable. - (Standard sizes) ALSO AVAILABLE Other sizes Other platings Alignment Pins Single Row Locking Leads Polarized 1 = Connector Strip PROCESSING Lead–Free Solderable: HTSS=Yes TSS, ZSS=No, Lead Wave only SMT Lead Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact ipg@samtec.com) - BODY HEIGHT C (OAL) Note: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. samtec.com?TSS, samtec.com?HTSS or samtec.com?ZSS MAX C BODY (OAL) HEIGHT F-221 (Rev 22DEC22) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
TSS-113-01-L-D 价格&库存
很抱歉,暂时无法提供与“TSS-113-01-L-D”相匹配的价格&库存,您可以联系我们找货
TSS-113-01-L-D
  • 1+34.961221+4.53619
  • 50+28.4828350+3.69563
  • 100+24.18865100+3.13846
  • 500+21.50012500+2.78963
  • 1000+21.245791000+2.75663
库存:27
