REVISION J
DO NOT
SCALE FROM
THIS PRINT
NOTES:
1.
2.
3.
4.
5.
6.
7.
8.
TFM-1XX-XX-X-DH-XX
REPRESENTS A CRITICAL DIMENSION.
MINIMUM PUSHOUT FORCE TO BE 12 OZ RETENTION FOR CONTACTS AND WELD TABS.
MAXIMUM TERMINAL BURR: .003[0.08]
MAXIMUM HEIGHT VARIATION BETWEEN ANY TWO PINS: .005[0.13]
PARTS SHALL BE PACKAGED IN TUBES UNLESS OTHERWISE SPECIFIED. SEE SHEET 2.
NOTE DELETED.
NOTE DELETED.
ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY
STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM
9. ATTACH LABEL TO EACH REEL.
C
LEAD STYLE
-02
ROW SPECIFICATION
-DH: DOUBLE HORIZONTAL
PLATING SPECIFICATION
-S: 30µ" SELECTIVE GOLD IN CONTACT
AREA, MATTE TIN ON TAIL
-L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT
-F: 3µ" FLASHED SELECTIVE GOLD IN CONTACT
((No OF POSITIONS x .050[1.27]) + .271[6.88]) REF
((No OF POSITIONS x .050[1.27])) + .025[0.64] REF
C
((No OF POSITIONS - 1) x .050[1.27])
PACKAGING
BLANK: TUBES (SEE NOTE 5)
-TR: TAPE & REEL PACKAGING
(SEE NOTES 8 & 9)
-FR: FULL REEL QTY. TAPE & REEL
(SEE NOTES 8 & 9)
No OF POSITIONS
-02 THRU -50
(PER ROW)
"A"
WT-81-01-T
.225 5.72 REF
.110 2.79 REF
02
.100 2.54 REF
01
.135 3.43 REF
.050 1.27 REF
.0100 0.254
"A"
REF (TYP)
C
.094±.004 2.39±0.10
.155 3.94 REF
.025 0.64
REF (TYP)
(No OF POSITIONS x .050[1.27]) + .154[3.91]
.057 1.44 REF
2 MAX SWAY
(EITHER DIRECTION)
2 MAX SWAY
(EITHER DIRECTION)
"B"
TFM-XX-DH
.089 2.26 REF
SECTION "A"-"A"
SCALE 4 : 1
.018 0.46 REF (TYP)
.096 2.44 REF
.329 8.36
REF
2 MAX SWAY
(EITHER DIRECTION)
.150 3.810
REF
.244 6.20
REF
.1635 4.153 REF
T-1R46-01-XXX
T-1R45-01-XXX
C .050 1.27
C
"A" (SEE TABLE 2)
.018 0.46
REF (TYP)
.0500 1.270
(TOL. NON-ACCUMULATIVE)
.135 3.43 REF
"B"
.030 0.762
REF (TYP)
C .304±.003 7.72±0.08
FIG 1
TFM-125-02-X-DH SHOWN
SECTION "B"-"B"
SCALE 3 : 1
C .244±.003 6.20±0.07
(VIEW ROTATED 90°)
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [0.3]
2
.XXX: .005 [0.13]
.XXXX: .0020 [0.051]
MATERIAL:
FIG 2
BACK VIEW
C
2 MAX SWAY
(EITHER DIRECTION)
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, UL 94-VO
COLOR: BLACK
TERMINAL: COPPER ALLOY
F:\DWG\MISC\MKTG\TFM-1XX-XX-X-DH-XX-MKT.SLDDRW
SHEET SCALE: 3:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.050 X .050 DOUBLE HORIZONTAL TERMINAL STRIP
DWG. NO.
TFM-1XX-XX-X-DH-XX
BY: J. BROWNING 04/12/2010
SHEET 1 OF 2
REVISION J
.010 0.25
REF
C
.050 1.27
.010 0.25
REF
C .244±.003 6.20±0.08
+0.025
.0105+-.0010
.0020 0.267 - 0.051
C
+0.051
.0110+-.0020
.0010 0.279 - 0.025
C
.004[0.10]
C
"A" (SEE TABLE 2, SHT 1)
IN-PROCESS 2
IN-PROCESS 1
FILL T-1R46-01-XXX
FILL T-1R45-01-XXX
PROPRIETARY NOTE
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
TUBE VIEW
PT-1-24-01-124
TP-07
SHEET SCALE: 3:1
DESCRIPTION:
DWG. NO.
TFM-1XX-XX-X-DH-XX
SHEET 2 OF 2
很抱歉,暂时无法提供与“TFM-104-02-L-DH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+30.65040
- 10+29.98080
- 48+29.52720
