SHF-105-01-L-D-TH-LC 数据手册
REVISION V
DO NOT
SCALE FROM
THIS PRINT
NOTES:
SHF-1XX-01-X-D-XX-XX
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM PUSHOUT FORCE: 1 LB[4.45N].
3. MAXIMUM ALLOWABLE BOW: .002[0.05] INCH/INCH AFTER ASSEMBLY.
4. POST HEIGHT VARIATION BETWEEN ANY TWO PINS: .005[0.13].
5. FOR ALL PINS: NO BAND MARKS ALLOWED IN POST AREA.
6. MINIMUM RETENTION FOR LOCKING CLIPS: .75LB[3.336N]
7. MEASURE AT BEND.
8. MAXIMUM PIN ROTATION IN BODY TO BE 2 .
9. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE
PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY
STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM.
10. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL,
BASED ON OPTIONS SELECTED.
C
(No OF POS x .050[1.27]) + .250[6.35] REF
.0500 1.270
(TYP)
CL
.020 0.51 REF
02
No OF POSITIONS
-02 THRU -25
LEAD STYLE
-01:
PLATING SPECIFICATION
-L: 10µ" LIGHT SELECTIVE IN CONTACT AREA,
MATTE TIN ON TAIL
-F: 3µ" FLASH SELECTIVE GOLD IN CONTACT
AREA, MATTE TIN ON TAIL
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
C
.037 0.94
REF
.140 3.56
REF
CL
C .0500 1.270
01
03
.220 5.59 C
REF
(No OF POS x .050[1.27]) + .180[4.57] REF
.056 1.42 REF
(No OF POS - 1) x .0500[1.270] C
.100 2.54 REF
(ONLY FOR POSITION -05 THRU -25)
OPTION
-LC: LOCKING CLIP
(NOT AVAILBLE WITH -RA)
-K: POLYIMIDE FILM
(-SM ONLY)
(AVAILABLE IN TAPE & REEL ONLY)
(USE K-DOT-.256-.375-.005)
-TR: TAPE & REEL(SEE NOTE 10)
-FR: FULL REEL QTY. TAPE & REEL
(SEE NOTE 11)
BODY HEIGHT
-TH: THROUGH HOLE (SEE FIG 1, SHT. 1)
-RA: RIGHT ANGLE (SEE FIG 2, SHT. 2)
-SM: SURFACE MOUNT (SEE FIG 3, SHT. 3)
ROW SPECIFICATION
-D: DOUBLE
DETAIL 'B'
SCALE 8 : 1
2 MAX SWAY
(EITHER DIRECTION)
FIRST POSITION
INDICATOR
SHF-XX-D-LC
.120 3.05 C
C .210 5.33 REF
LC-06-TM
C .055 1.40
.020 0.51 REF
.010 0.25 REF
(TYP)
2 MAX SWAY
(EITHER DIRECTION)
CL
2 MAX SWAY
(EITHER DIRECTION)
SHF-XX-D-LC
T-1S71-01-X
.030 0.76 REF
.016 0.41 SQ
REF (TYP)
C .165 4.19
FIG 1
(SHF-110-01-X-D-TH-LC SHOWN)
F:\DWG\MISC\MKTG\SHF-1XX-01-X-D-XX-XX-MKT.SLDDRW
DECIMALS
ANGLES
.XX: .01 [0.3]
2
.XXX: .005 [0.13]
.XXXX: .0020 [0.051]
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 4:1
INSULATOR: SUMIKA E6810LHF, UL 94 VO, COLOR: BLACK
TERMINAL: PHOS BRONZE
(FOR -TH ONLY)
2 MAX SWAY
(EITHER DIRECTION)
MATERIAL:
IN-PROCESS 1
'B'
(No OF POS x .0500[1.270]) + .2120[5.385] C
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
.260 6.60 C
REF
.075 1.91
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.050 x .050 SHROUDED TERMINAL STRIP
DWG. NO.
BY: T NEWTON 1/10/2008
SHEET 1 OF 4
REVISION V
.040 1.02 REF
C .390 9.91
REF
.285 7.24
.040 1.02 REF
C
.120 3.05
90° C
.120 3.05
.040 1.02
C .122 3.09
SHF-XX-D-LC
C .490 12.45
REF
C
C .385 9.78
T-1S71-02-X
T-1S71-03-X
IN-PROCESS 2
IN-PROCESS 1
(FOR -RA ONLY)
(FOR -RA ONLY)
IN-PROCESS 3
IN-PROCESS 4
(FOR -RA ONLY)
(FOR -RA ONLY)
C
2 MAX SWAY
(EITHER DIRECTION)
"C"
.120 3.05
.0500 1.27 C
(TYP)
.085 2.15 REF
90° C
(TYP)
.040 1.02 REF
02
90° C
.050 1.26 C
(SEE NOTE 7)
C .120 3.05
.172 4.36
.050 1.27 C
(SEE NOTE 7)
01 03
C
SECTION "C"-"C"
"C"
IN-PROCESS 5
(VIEW ROTATED 90°)
FIG 2
(SHF-110-01-X-D-RA SHOWN)
(SAME AS FIG 1, DIFFERENT AS SHOWN)
(FOR -RA ONLY)
2 MAX SWAY
(EITHER DIRECTION)
PROPRIETARY NOTE
SHEET SCALE: 4:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 2 OF 4
REVISION V
SHF-XX-D-LC
"D"
T-1S71-01-X
02
.020 0.51 REF
01
.260 6.60 C
REF
"D"
C .175 4.45
T-1S71-01-X-2
CL
IN-PROCESS 1
+0°
90° - 5° (TYP) C
C .120 3.05
(FOR -SM ONLY)
.215 5.46 REF
(SEE NOTE 7)
C
.004[0.10]
.055 1.40
.240 6.10 REF
(VIEW ROTATED 90°)
2 MAX SWAY
(EITHER DIRECTION)
C .0500 1.27
(TYP)
.020 0.51
REF
.190 4.83
REF
.105 2.67
REF
C
.240±.010 6.10±0.254
IN-PROCESS 2
(FOR -SM ONLY)
FIG 3
(SHF-110-01-X-D-SM-LC SHOWN)
PROPRIETARY NOTE
SHEET SCALE: 4:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 3 OF 4
REVISION V
C
.256 6.50 REF
.220 5.59
C
(VIEW ROTATED 90°)
"S"
(SEE NOTE)
.028±.020 0.71±0.51
"R"
(SEE NOTE)
FIG 4
NOTE: "R" = USED MEASURED DIMENSION (REF)
"S" = {("R" -.256[6.50])/2} 0.020[0.51]
(SHF-110-01-X-D-SM-K SHOWN)
PT-FTSH002-DV-A-P-M
PT-1-24-18-09
PT-1-24-01-45
NOTE: ALL POSITIONS ARE TO BE TUBED
PACKAGING
ALL PARTS ARE LOADED WITH POSITION 1
TOWARD THE ARROW "EXCEPT -RA"
PROPRIETARY NOTE
SHEET SCALE: 4:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
SHEET 4 OF 4
