TFM-107-02-S-D
TFM-107-02-S-D
    SAMTEC(申泰)
    TFM-107-02-S-D
TFM-107-02-S-D 数据手册
RUGGED TIGER EYE™ SYSTEMS (1.27 mm) .050" PITCH MAX 3.2 A m p s 8 G b p s FEATURES & BENEFITS • S crew down, locking clip, friction latching and weld tab ruggedizing options • Shrouded, polarized and keyed • Surface mount or through-hole tails • High-density, four row design (FOLC/MOLC Series) • Discrete wire assemblies available in single or double row, 28 and 30 AWG PVC or Teflon® wire; contact asp@samtec.com for custom solutions • Cable components (ISDF/CC03) and tooling available IDC cable assemblies with rugged strain relief (FFSD/FFMD, FFTP/FMTP) Dupont™ Teflon® is a registered trademark of the E.I. du Pont de Nemours and Company or its affiliates. KEY SPECIFICATIONS (TFM/SFM) PITCH STACK HEIGHTS INSULATOR MATERIAL CONTACT MATERIAL BeCu (SFM) 1.27 mm F-221 6 to 12 mm Black LCP Phosphor Bronze (TFM) PLATING Au or Sn over 50 µ" (1.27 µm) Ni OPERATING TEMP RANGE -55 °C to +125 °C CURRENT RATING 3.2 A per pin (2 pins powered) Locking for increased unmating force (SFML/TFML) VOLTAGE RATING 250 VAC MAX CYCLES 10,000 with 30 µ" (0.76 µm) Au (Call Samtec for E.L.P.™ plating option) samtec.com/127mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. MAX 3.2 A (1.27 mm) .050" • SMT/THROUGH-HOLE HEADER SERIES -1 TFM NO. PINS PER ROW - 03, 04, 06, 08 = Standard (TFM –01 & –02 only) TFML = Locking (–01 & –02 lead style only) 05, 07, 10, 15, 20, 25, 30, 35, 40, 45, 50 LEAD STYLE Specify LEAD STYLE from chart - PLATING OPTION –L = 15 µ" (0.38 µm) Gold on post, Matte Tin on tail (Call Samtec for E.L.P.™ plating option) (Standard sizes) - p s 8 25 G b p s - ROW OPTION OPTIONS –S Specify only –RA, –RE1 or –RE2 –D = Right-angle (Lead style –01 only) = Single Row (TFM only) = Double Row –DH* = Double Horizontal (TFM lead style –02 only) (05 thru 50 positions only) (–TR or –FR option only available) –RA –RE1 = Right-angle Elevated for (1.60 mm) .062" PCB (Requires TFM lead style –01, –D row and –WT) SMT lead styles only Specify only –A, Specify only –K or –P –LC, –DS or –WT Not available with –RA, –RE1 and –RE2 unless –K otherwise noted. = Polyimide Film Pick & Place Pad –A = Alignment Pin –LC = Locking Clip (Manual Placement required) –P = Plastic Pick & Place Pad (5 positions min.) (Not available with 5 position with –WT) Specify –TR or -FR last –DS (Not available with –DS) = Dual –RE2 Screw Down = Right-angle –TR for (1.60 mm) Elevated for = Tape & Reel .062" PCB (2.36 mm) .093" PCB (05, 07, 10, 15, 20, (Requires TFM lead 25, 30, 35, 40 –FR style –01, –D row positions only) = Full Reel and –WT) (TFM lead styles Tape & Reel –01 and –02 only) (must order max. (Requires –D quantity per reel; row option) contact Samtec for MATED HEIGHTS* (Mates with quantity breaks) SFM–DS option and LEAD STYLE (SMT) SFSD/SFSDT –SS and MATED HEIGHT* –DS option only) TFM SFM (Not available with –A, –LC, –WT, –K, –P, –XR) -02 (6.35) .250 TFM Board Mates: SFM, SFMC Cable Mates: SFSD TFML Board Mates: SFML –12 (1.27) .050 x No. of Positions + (3.18) .125 (8.13) .320 -02 -22 (9.91) .390 -32 (11.81) .465 LEAD STYLE (T/H) MATED HEIGHT* TFM SFM -01 (5.97) .235 –03 (5.97) .235 -11 (7.75) .305 -13 (7.75) .305 -01 -21 (9.53) .375 -23 (9.53) .375 -31 (11.43) .450 *Processing conditions will affect mated height. (4.45) .175 SINGLE ROW (1.27) .050 x No. of Positions + (3.18) .125 (See website for –REX, –DH, –DS, –WT OAL) (5.72) .225 LEAD STYLE (SMT) B A C THROUGH-HOLE –A Note: Some lengths, styles and options are non-standard, non-returnable. A –02 (5.72) .225 –12* (7.49) .295 –22* (9.27) .365 –32* (11.18) .440 * N/A with 07, -DH or -S row option DOUBLE ROW –LC m LEAD STYLE (T/H) –WT = Weld Tab (TFM lead styles –01 and –02 only) (Required callout for –RE1 & –RE2) (Mates to SFSS/SFSD –SR and –DR option only) (05, 07, 10, 15, 20, 25, 30, 35, 40, 45, 50 positions only) B C –01 (5.59) .220 (1.97) .078 –03* (5.59) .220 (2.77) .109 –11* (7.37) .290 (1.97) .078 –13* (7.37) .290 (2.77) .109 –21* (9.14) .360 (1.97) .078 –23* (9.14) .360 (2.77) .109 –31* (11.05) .435 (1.97) .078 * Not Available with 07 or -S row option SURFACE MOUNT –WT –DS –DH* –RA –RE1 & –RE2 View complete specifications at: samtec.com?TFM & samtec.com?TFML samtec.com/127mm-TigerEye Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
TFM-107-02-S-D
物料型号:文档中没有明确列出具体的物料型号,但提到了多种系列和型号,如TFM、TFML、SFML等。
器件简介:"TIGER EYE SYSTEM"是一个高密度、四排设计的连接器系统,具有多种加固选项,如螺丝固定、锁定夹、摩擦锁扣和焊接标签。
引脚分配:文档中提到了不同引脚数量的配置,如每排3、4、6、8个引脚,以及双排配置。
参数特性:文档列出了关键规格,包括间距、堆叠高度、绝缘材料、接触材料、镀层、工作温度范围、电流额定值、电压额定值和最大循环次数。
功能详解:文档中提到了多种功能特性,如带加固的电缆组件、锁定以增加未配对力、以及多种表面贴装和通孔尾部选项。
应用信息:文档中没有明确提供应用信息,但提到了可用于定制解决方案的电缆组件和工具。
封装信息:文档提供了不同引脚配置的匹配高度和外形尺寸信息。
TFM-107-02-S-D 价格&库存
很抱歉,暂时无法提供与“TFM-107-02-S-D”相匹配的价格&库存,您可以联系我们找货
