FTE-105-01-G-DV-ES
FTE-105-01-G-DV-ES
    SAMTEC(申泰)
    SMD,P=0.8mm
    排针 2x5P SMT
FTE-105-01-G-DV-ES 数据手册
REVISION BH DO NOT SCALE FROM THIS PRINT FTE-1XX-XX-X-DV-XX-XX NOTES: C 1. REPRESENTS A CRITICAL DIMENSION. 2. MAXIMUM CUT FLASH: .010 [0.25] 3. MINIMUM PUSHOUT FORCE: 1 LB 4. SHEAR TAILS TO DIMENSION SHOWN. 5. MAXIMUM BURR: .003 [0.08] 6. MAXIMUM COPLANARITY: -05 THRU -49 = .004 [0.10] -50 THRU -64 = .006 [0.15] -65 THRU -90 = .009 [0.22] 7. FOR -XX POSITION ASSEMBLY USE -XX POSITION BODY EXCEPT AS LISTED IN TABLE 2. 8. IF -A CALLED OUT ON ASSEMBLY, USE -A ON END OF BODY CALLOUT. USE FTE-190-0X-G-DV-SA FOR STOCK THAT WILL BE CUT FOR STAKED -A ORDERS. USE FTE-190-0X-G-DV FOR ORDERS NOT REQUIRING STAKED -A OPTION. 9. MAXIMUM ATTACHED FLASH ALLOWED ON POST SIDE ONLY: .02 [0.5] 10. -ES MOLDED OPTION ONLY, DURING CUT PROCESS, WALL MUST BE A MINIMUM OF .004" OR COMPLETELY REMOVED. 11. IF RETENTION IS BELOW SPECIFICATION, A SUBSTITUTION OF FTE-90-D FOR FTE-90-D-A IS ACCEPTABLE. C (No OF POS x .0315) +.004[+0.10] -.010[-0.25] .0157 0.399 "A" LEAD STYLE -01: .075 POST (USE T-1S29-04-X-2 FOR HAND FILL, T-1S29-02-X-2 FOR MACHINE FILL). -02: .175 POST (USE T-1S29-04-X-2 FOR HAND FILL, T-1S29-02-X-2 FOR MACHINE FILL). -03: .120 POST (USE T-1S29-04-X-2 FOR HAND FILL, T-1S29-02-X-2 FOR MACHINE FILL). PLATING SPEC -G: 10µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL FLEX SHROUD OPTIONS (STYLE -01 ONLY) -ES: END SHROUD [SAMTEC DISCRETION ON WHICH -ES USED] (SEE FIG 3, SHT 2 FOR SNAPPED-ON, 11 POSITIONS MIN) (SEE FIG 8, SHT 2 FOR MOLDED, 5 POSITIONS PER ROW MIN, SEE TABLE 2) -EC: END SHROUD WITH LOCKING CLIPS (SEE FIG 7, SHT 2) (11 POSITIONS MIN) -EP: END SHROUD WITH GUIDE POSTS (SEE FIG 4, SHT 2) (11 POSITIONS MIN) ROW SPECIFICATION .0315 0.800 -DV: DOUBLE ROW VERTICAL (USE FTE-90-D-A) 180 02 OPTIONS -P: PICK AND PLACE PAD (SEE FIG 2, SHT 2) (ONLY AVAILABLE FOR 08-90 POSITIONS) (USE PPP-37) ( USE PPP-37-NT FOR TAPE & REEL) -TR: TAPE & REEL PACKAGING (USE PPP-37-NT ONLY) -A: ALIGNMENT PIN (MOLDED OR STAKED) [ SAMTEC DISCRETION ON WHICH -A PIN USED] (MOLDED 4 POS MIN, SEE FIG 6, SHT 2) (USE FTE-90-D-XX) (STAKED 7 POS MIN, SEE FIG 5, SHT 2) (USE FTE-90-D-A) -M: METAL PICK & PLACE PAD USE MPP-17-5 (SEE FIG 9 - SHT 3) (10 POS MIN, AVAILABLE IN -01 STYLE ONLY) No OF POSITIONS -05 THRU -90 (PER ROW) CL .1200 3.048 REF SEE NOTE 11 01 179 "A" 2.5 MAX SWAY (EITHER DIRECTION) 2 MAX SWAY (EITHER DIRECTION) 2 MAX SWAY (EITHER DIRECTION) .0120 0.305 SQ REF .075 1.91 (CONTACT AREA) +0.41 .0472+-.016 .006 1.200 - 0.15 T-1S29-XX-X-2 SEE NOTE 9 C "A" (SEE TABLE 1) .055 1.40 REF C 90°±3° .070 1.78 SEE NOTE 6 FTE-90-D SEE NOTE 2 C SEE NOTE 2 BURR SIDE (SEE NOTE 4 & 5) .18 4.6 SECTION "A"-"A" FIG 1 FTE-1XX-03-X-DV SHOWN UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .X: .1 [2.5] .XX: .01 [0.3] 2 .XXX: .005 [0.13] .XXXX: .0020 [0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: BLACK, LCP, UL 94 VO TERMINAL: PHOS BRONZE F:\DWG\MISC\MKTG\FTE-1XX-XX-X-DV-XX-XX-MKT.SLDDRW SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .8MM x 1.2MM C.L. TERMINAL STRIP ASSM. DWG. NO. FTE-1XX-XX-X-DV-XX-XX BY: DEAN P 9/01/2009 SHEET 1 OF 3 REVISION BH .200 5.08 REF CL "P" .075 1.91 REF .0080 [0.203] (NO OF POS x .0315 [.800] + .217 [5.53]) "R" REF .275 6.99 REF FTE-EP .125 3.18 REF .150 3.81 REF .290 7.37 REF "M" "M"= No OF POS X .0315 [0.800] "P"= ("M" - .200 [5.08]) / 2 .020 [0.51] FIG 2 -P OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) FIG 4 -EP OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (NO OF POS x .0315 [0.800]) + .025 [0.64] REF .120 3.05 REF +.004 [+0.10] ((NO OF POS + 2) x .0315) - .010 [-0.25] (NO OF POS X .0315) +.004[+0.10] -.010[-0.25] NO OF POS X .0315 [0.800] + .062 [1.57] .197 5.00 REF .314 7.98 .0057 0.145 REF (SEE NOTE 10) .130 3.30 REF .008 [0.20] .164 4.17 REF FTE-ES .140 3.56 REF DETAIL 'B' SCALE 6 : 1 'B' FTE-XX-D-ES-XX-X (4 PLCS) .165 4.19 REF .135 3.43 REF .164 4.17 .150 3.81 FIG 8 -ES OPTION (MOLDED) (5 POS MIN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) FIG 3 -ES OPTION (SNAPPED ON) (11 POS MIN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) C (NO OF POS - 2) x .0315 [0.800] {(NO OF POS x .0315 [0.800]) + .160 [4.06]} .008 [0.20] FTE-EC C .025 0.64 .003 [0.08] SM-A11H .013 0.32 REF .164 4.17 CL .037 0.94 REF FIG 5 -A OPTION (STAKED) (7 POS MIN) (DIFFERENT AS SHOWN OTHERWISE SAME AS FIG 1) (NO OF POS - 2) x .0315 [0.800] FIG 6 .003 [0.08] -A OPTION (MOLDED) (4 POS MIN) (DIFFERENT AS SHOWN OTHERWISE SAME AS FIG 1) {(NO OF POS x .0315 [0.800]) + .111 [2.82]} .070 1.78 .008 [0.20] FIG 7 LC-05-TM -EC OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) * FTE-90-D-XX CL .024 0.61 REF .025 0.64 REF .037 0.94 REF PROPRIETARY NOTE DO NOT SCALE DRAWING .025 0.64 REF SHEET SCALE: 4:1 F:\DWG\MISC\MKTG\FTE-1XX-XX-X-DV-XX-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .8MM x 1.2MM C.L. TERMINAL STRIP ASSM. DWG. NO. FTE-1XX-XX-X-DV-XX-XX BY: DEAN P 9/01/2009 SHEET 2 OF 3 REVISION BH "M" .250 6.35 REF MPP-17-5 .100 2.54 "P" .065 1.65 REF .080 2.03 "M" = No OF POSITIONS x .0315 [0.800] "P" = {( "M" - .250 [6.35]) / 2 } .020 [0.51] FIG 9 -M OPTION (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) PT-1-24-01-37 PT-1-24-01-37 PT-FTE001-DV-P PT-FTE001-DV-P -01-EC & -EC-M OPTIONS -01-ES-P OPTION -01-EC-P OPTION PT-1-24-13-09 -01 & -03 OPTION -01-A & -03-A OPTION PT-1-24-01-09 -02 OPTION PT-1-24-01-37 -02-A OPTION PT-FTE001-DV-P PT-FTE001-DV-P -01-ES-M OPTION -01-ES & -01-ES-A OPTIONS * 01-EP 01-EP-M -01-EP-P OPTION -01-P, -02-P & -03-P OPTION -01-ES-A-P OPTION -01-A-P, -02-A-P & -03-A-P OPTION -01-M & -01-A-M OPTION F:\DWG\MISC\MKTG\FTE-1XX-XX-X-DV-XX-XX-MKT.SLDDRW PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .8MM x 1.2MM C.L. TERMINAL STRIP ASSM. DWG. NO. FTE-1XX-XX-X-DV-XX-XX BY: DEAN P 9/01/2009 SHEET 3 OF 3
FTE-105-01-G-DV-ES 价格&库存
很抱歉,暂时无法提供与“FTE-105-01-G-DV-ES”相匹配的价格&库存,您可以联系我们找货
FTE-105-01-G-DV-ES
    • 1+27.93960
    • 10+27.25920
    • 30+26.81640
    库存:28
    FTE-105-01-G-DV-ES
    • 1+40.401251+5.24792
    • 50+32.9230350+4.27654
    • 100+27.94887100+3.63042
    • 500+26.91974500+3.49674
    库存:554
    FTE-105-01-G-DV-ES
    • 104+37.96696
    • 520+33.78831
    • 1040+26.62257
    库存:1124
