1S25000028-Q
1S25000028-Q
    YL(惠伦晶体)
    SMD1612_4P
    无源晶振 25MHz 6pF 72Ω -40℃~+105℃ -10~+50ppm SMD1612_4P
1S25000028-Q 数据手册
SMD X'TAL 1.6×1.2×0.35mm 1S Series ■ Features - 1.6 x 1.2 x 0.35 MAX. mm of surface mounted quartz crystal units. - Excellent reliability characteristics such as heat and mechanical shock. - Pb-free and satisfy RoHs requirements. - Reflow soldering is available. ■ Applications Digital Electronics, Consumer Products, Mobile Communications, ■ Specifications Frequency range Overtone Order Frequency tolerance at 25℃ Operating temperature range and frequency stability Equivalent series resistance Shunt capacitance Load capacitance Drive level (Max.) Insulation resistance Aging at 25℃ Storage temperature range Measure instrument 20~96 MHz Fundamental ±10, ±15, ±20, ±30, ±50 ppm See Table 1 See Table 2 3 pF Max or specify 8, 16, 20 pF or specify 10, 100, 200 μW or specify 500 MΩ Min. at DC 100V ±3 ppm / year Max. -40 ~ +85 ℃ or -40 ~ +125 ℃ S&A 250B system with PI circuit ■ Table 1: Operating temperature range and frequency stability ppm Temp 0~+ 50 ℃ - 10~+ 60 ℃ - 20~+ 70 ℃ - 30~+ 85 ℃ - 40~+ 85 ℃ - 40~+ 125 ℃ ±5 ±10 ±15 ±20 ±50 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ■ Table 2: Equivalent series resistance Frequency (MHz) 20~26 26~32 32~60 60~100 Overtone Order Fundamental Fundamental Fundamental Fundamental ESR (Ω MAX) 150 80 60 30 The mark “●” denotes our achieved level ■ Dimensions (unit: mm) 0 ■ Land pattern (unit: mm) #4 #3 #3 #4 #1 #2 #2 #1 Pin #1 #2 #3 #4 Function Xtal Terminal (Input) GND Xtal Terminal (Output) N/C
1S25000028-Q
PDF文档中提到的物料型号为1S Series,由广东惠伦晶体科技股份有限公司生产。
以下是文档中的关键信息摘要:
- 器件简介:1.6 x 1.2 x 0.35mm的表面贴装石英晶体单元,具有优异的热冲击和机械冲击可靠性特性,无铅并符合RoHS要求,可进行回流焊接。
- 引脚分配:#1为晶体终端(输入),#2为地线(GND),#3为晶体终端(输出),#4为无连接(N/C)。
- 参数特性:频率范围20~96 MHz,基频模式,频率容差±10,±15,±20,±30,±50ppm,等效串联电阻和并联电容等参数详见表格。
- 功能详解:文档提供了频率稳定性、老化率、存储温度范围等详细参数。
- 应用信息:适用于数字电子、消费产品、移动通信等领域。
- 封装信息:提供了尺寸图和焊盘图案,尺寸单位为毫米。
更多详细信息和数据表,建议直接查阅原始PDF文档。
1S25000028-Q 价格&库存
很抱歉,暂时无法提供与“1S25000028-Q”相匹配的价格&库存,您可以联系我们找货
