深圳市长江微电科技有限公司
SZ CJIANG TECHNOLOGY CO.,LTD
FXL1050 Series
Introduction
• ROHS,Halogen Free and REACH compliance
• High rated current
• 125℃ maximum total temperature operation
• 11.5×10.3×5.0mm maximum surface mount package
• Low core loss
• Ultra low buzz noise due to molding construction
Applications
• Laptops and PCs
• Switch and servers
• Base stations
• DC/DC converters
• Battery powered devices
• SSD modules
Product Identification
FXL
①
1050
②
-1R5
③
-M
④
① FXL ---------- Series name
② 1050 ---------- Dimension
③ 1R5 ----------- Inductance Value (1R5 = 1.5μH)
④ M -----------Inductance Tolerance ( M= ± 20% )
Dimensions-mm
A
C
b
E
B
c
D
a
Recommend Land Pattern
A
B
C
D
E
a typ
b typ
c typ
11.5MAX
10.0±0.3
4.8±0.2
2.0±0.5
3.0±0.5
5.4
13.6
4.1
深圳市长江微电科技有限公司
Marking
The inductor is marked with a 3-digit code
Nominal
Inductance
Example
Nominal Value
1R0
1.0 μH
100
10 μH
101
100 μH
Note:Using Ink for marking
1R0
Structure and Components
Symbol
Components
Material
a
MARKING
Ink(black)
b
CORE
Alloy Sponge Powder
c
WIRE
Polyurethane copper wire
d
Terminal
Copper plated with Sn
深圳市长江微电科技有限公司
Heating Rating
Inductance
DC Resistance
Saturation Current
L0 (μH)
DCR (mΩ)
Isat (A)
Irms (A)
±20 %, 100 kHz, 1V
MAX.
TYP.
TYP.
FXL1050-R22-M
0.22
0.8
65
37
FXL1050-1R0-M
1.0
3
30
23
FXL1050-1R5-M
1.5
3.8
25
21
FXL1050-2R2-M
2.2
6
19
15
FXL1050-3R3-M
3.3
10
16
13
FXL1050-4R7-M
4.7
14
15
11
FXL1050-5R6-M
5.6
17
14
9.5
FXL1050-6R8-M
6.8
18.5
14
9
FXL1050-100-M
10
28
10
8
FXL1050-150-M
15
42
7.5
6.5
FXL1050-220-M
22
50
6
5.5
FXL1050-330-M
33
86
5.2
4.8
FXL1050-470-M
47
127
4.5
3.7
FXL1050-101-M
100
290
2.8
2.1
Part No.
Current
Notes
1.
All test data is referenced to 25 °C ambient
2.
Operating temperature range - 55 °C to + 125 °C
3.
Irms (A):DC current (A) that will cause an approximate ΔT of 40 °C(reference ambient temperature is 25 °C)
4.
Isat(A):DC current (A) that will cause L0 to drop approximately 30 %
5.
The part temperature (ambient + temp rise) should not exceed 125 °C under worst case operating conditions.
Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions
all affect the part temperature. Part temperature should be verified in the end application.
深圳市长江微电科技有限公司
Mechanical Reliability
Item
Specification and Requirement
1. No case deformation
or change in apperarance
Solderability
2. New solder coverage
Test Method
1.Preheat:155℃±5℃ ,60S±2S
2.Tin: lead-free.
3.Temperature:240℃±5℃,flux 3.0S±0.5S.
More than 95%
Mechanical
1. Acceleration: 100G
2. Pulse time::6ms
shock
3. 3 times in each positive and negative direction of 3
2. △L/Lo≦±10%
Mechanical
vibration
2. △L/Lo≦±10%
mutual perpendicular directions
1. Reflow: 2times
2. Frequency: 10HZ~55HZ~10HZ,20 Min/Cycles
3. Amplitude: 1.52 mm
4. Directions: X,Y,Z
5. Time: 12 cycle / direction
Endurance Reliability
Item
Inductance change:
Thermal Shock
Within ± 10% Without distinct damage
in appearance
Test Method
1. First -55℃ for 30 minutes,last 125℃ for 30 minutes
as 1 cycle. Go through
1000 cycles.
2. Max transfer time is 3 minutes.
3. Measured at room temperature after placing for 24±2
hours
Humidity
Resistance
Inductance change:
1.Reflow 2 times,
2.85℃,85%RH,1000 hours
in appearance
3.Measured at room temperature after placing for 24±2
hours
Low
temperature
storage
High
temperature
storage
Inductance change:
1. Temperature:-55 ± 2℃
2. Time:1000 hours
in appearance
hours
Inductance change:
in appearance
1. Temperature:+125 ± 2℃
2. Time:1000 hours
hours
深圳市长江微电科技有限公司
Recommended Soldering Technologies
(1)Re-flowing Profile
Preheat condition: 150 ~200℃/60~180sec.
Allowed time above 217℃: 80~120sec.
Max temp: 260℃
Max time at max temp: 10 sec.
Solder paste: Sn/3.0Ag/0.5Cu
Allowed Reflow time: 2x max
(2)Iron Soldering Profile
Iron soldering power: Max. 30W
Pre-heating: 150℃/60sec.
3sec. Max.
350℃
Soldering Tip temperature: 350℃ Max.
Power: max. 30W
Soldering time: 3sec. Max.
Diameter of Soldering
Max.1 times for iron soldering
Soldering Iron
Iron 1.0mm max.
Tc ℃
深圳市长江微电科技有限公司
Packaging Information
(1) Tape Packaging Dimensions(Unit:mm)
Type
FXL1050
Tape dimensions (mm)
W
P
24
±0.3
16
±0.1
Taping Drawings (UNIT:mm)
P0
P2
D0
4
2
1.5
±0.1 ±0.05 ±0.1
D1
T
A0
1.5
0.4
10.4
±0.1 ±0.05 ±0.1
B0
K0
E
F
11.6
±0.1
5.4
±0.1
1.75
±0.1
11.5
±0.1
深圳市长江微电科技有限公司
(2) Reel Dimensions(Unit:mm)
B
D
N
C
W
A
W
N
B
C
D
330+2.0
24±0.5
97±0.5
2.2+0.5
13.0±0.2
10.75±0.25
(3) Packaging Quantity(PCS)
Standard Quantity
Type
FXL1050
Reel
Inner box
500 pcs / reel
2Reel / box (1000 pcs)
(4) Peel force of top cover tape
The peel speed shall be about 300mm/minute
The peel force of top cover tape shall be between 0.1 to 1.3 N
Carton box
4 Middle boxes,
(4000 pcs)
A
深圳市长江微电科技有限公司
(5) Reel Label
Label on the reel
• Customer's part Number
• Lot Number
• Quantity
• date code
Shipping Label
• Manufacturer's part Number
• Quantity
• date code
(6) Inner Box
(7) Carton
A
B
C
很抱歉,暂时无法提供与“FXL1050-100-M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.16720
- 10+1.12960
- 100+1.09190
- 500+1.03920
- 1000+0.95640
- 国内价格
- 5+2.35732
- 50+1.81268
- 150+1.57929
- 500+1.28812
- 2500+1.15841
- 5000+1.08054
- 国内价格
- 5+1.39380
- 20+1.29030
- 100+1.18680
- 500+1.08330
- 1000+1.03500
- 2000+1.00050
- 国内价格
- 1+1.47400
- 50+1.13300
- 500+1.04500
