1N4007 SOD-123FL
1N4007 SOD-123FL
    YONGYUTAI(永裕泰)
    SMF(SOD-123FL)
    整流二极管 Vr=1kV Io=1A Vf=1.1V@1A Ir=5uA@1kV
1N4007 SOD-123FL 数据手册
1N4001 THRU 1N4007 FEATURES SOD-123FL Glass passivated device Ideal for surface mouted applications Low reverse leakage Metallurgically bonded construction High temperature soldering guaranteed: 250 C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension 1.8± 0.1 1.0±0.2 Cathode Band Top View 1.3± 0.15 0.10-0.30 2.8±0.1 0.6±0.25 MECHANICAL DATA 3.7±0.2 Dimensions in millimeters Case: JEDEC SOD-123FL molded plastic body over passivated chip Terminals: Solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.0007 ounce, 0.02 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. SYMBOLS Catalog Number Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TA=65 C (NOTE 1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) TL=25 C Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=125 C Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) Operating junction and storage temperature range VRRM VRMS VDC 4001 4002 4003 4004 4005 4006 4007 A1 A2 A3 A4 A5 A6 A7 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 UNITS VOLTS VOLTS VOLTS I(AV) 0.9 Amp IFSM 25.0 Amps VF 1.1 Volts IR 10.0 50.0 µA CJ RθJA TJ,TSTG 4 180 -55 to +150 pF K/W C Note: 1.Averaged over any 20ms period. 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.Thermal resistance from junction to ambient at 0.375” (9.5mm)lead length,P.C.B. mounted www.yongyutai.com PAGE 1 1N4001 THRU 1N4007 RATINGS AND CHARACTERISTIC CURVES 1N4001 THRU 1N4007 FIG.2 -- TYPICAL JUNCTION CAPACITANCE 10 TJ = 150°C CAPACITANCE, pF 1000 m AMPERES TJ = 25°C TJ = 100°C 9 8 7 6 5 4 3 2 1 100 600 700 800 900 1000 0 1100 INSTANTANEOUS FORWARD VOLTAGE,mV TJ = 150°C 10 TJ = 125°C TJ = 100°C 1 TJ = 75°C TJ = 50°C 0.1 TJ = 25°C 0.01 0 100 200 300 400 500 600 700 800 900 INSTANTANEOUS REVERSE VOLTAGE,V www.yongyutai.com 5 10 15 20 25 30 35 40 FIG.4 -- FORWARD DERATING CURVE AVERAGE FORWARD CURRENT, AMPERES 100 0 REVERSE VOLTAGE,VOLTS FIG.3 -- TYPICAL INSTANTANEOUS REVERSE CHARACTERISTICS µ AMPERES INSTANTANEOUS REVERSE CURRENT INSTANTANEOUS FORWARD CURRENT FIG.1 --TYPICAL FORWARD CHARACTERISTIC 1.2 Resistive or Inductive Load 1.0 0.8 0.6 0.4 0.2 3.0 x 3.0mm 40 µm Thick Copper Pad Areas 0 0 20 40 60 80 100 120 140 160 AMBIENT TEMPERATURE, PAGE 2
1N4007 SOD-123FL 价格&库存
很抱歉,暂时无法提供与“1N4007 SOD-123FL”相匹配的价格&库存,您可以联系我们找货
