09195106829
09195106829
    HARTING(浩亭)
    插件,P=2.54mm
    排母 2x5P 间距:2.54mm 直插
09195106829 数据手册
Product data sheet 09 19 510 6829 SEK mezz Fe 10P Press-in 4.5mm PL2 SEK mezz Fe 10P Press-in 4.5mm PL2 Part number 09 19 510 6829 Specification SEK mezz Fe 10P Press-in 4.5mm PL2 HARTING eCatalogue https://b2b.harting.com/09195106829 Image is for illustration purposes only. Please refer to product description. Identification Category Connectors Series SEK Mezzanine Element Female connector Description of the contact Straight Version Termination method Press-in termination Connection type PCB to PCB Motherboard to daughtercard Number of contacts 10 Termination length 4.5 mm Technical characteristics Contact rows 2 Contact spacing (termination side) 2.54 mm Rated current 1 A Insulation resistance >109 Ω Contact resistance ≤20 mΩ Limiting temperature -55 ... +125 °C Insertion and withdrawal force ≤20 N Performance level 2 Mating cycles ≥250 Test voltage Ur.m.s. 1 kV Page 1 / 2 | Creation date 2022-04-29 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Product data sheet 09 19 510 6829 SEK mezz Fe 10P Press-in 4.5mm PL2 Technical characteristics Isolation group IIIa (175 ≤ CTI < 400) PCB thickness 1.6 mm +1.6 Material properties Material (insert) Liquid crystal polymer (LCP) Colour (insert) Black Material (contacts) Copper alloy Surface (contacts) Nickel plated Termination side Au over Pd/Ni Mating side Material flammability class acc. to UL 94 V-0 RoHS compliant ELV status compliant China RoHS e REACH Annex XVII substances Not contained REACH ANNEX XIV substances Not contained REACH SVHC substances Not contained California Proposition 65 substances Not contained Specifications and approvals Specifications IEC 60603-13 Commercial data Packaging size 100 Net weight 3.07 g Country of origin China European customs tariff number 85366990 eCl@ss 27460201 PCB connector (board connector) Page 2 / 2 | Creation date 2022-04-29 | Please note that the data specified here were taken as extracts from the online catalogue. Please refer to the user documentation for the complete and up-to-date information and data. Please also note that the user is responsible for validating functionality, conformity with applicable laws and directives, as well as for the electrical safety in the particular application. HARTING Electronics GmbH | Marienwerderstraße 3 | 32339 Espelkamp | Germany Phone +49 5772 47-97200 | electronics@HARTING.com | www.HARTING.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: HARTING: 09195106829
09195106829 价格&库存
很抱歉,暂时无法提供与“09195106829”相匹配的价格&库存,您可以联系我们找货
  • 1+11.20000
  • 10+10.70000
库存:43
09195106829
  • 1+49.23663
  • 10+45.28978
  • 25+40.88473
库存:62
09195106829
  • 1+30.098881+3.86051
  • 10+25.5455210+3.27649
  • 25+23.9489525+3.07171
  • 50+22.8034450+2.92479
  • 100+21.71380100+2.78503
  • 300+20.09368300+2.57723
  • 500+19.38231500+2.48599
  • 1000+18.457751000+2.36741
  • 2500+17.303072500+2.21931
库存:33
