3S12000309-Q
3S12000309-Q
    YL(惠伦晶体)
    SMD3225_4P
    无源晶振 12MHz 80Ω 12.5pF ±10ppm -20℃~+70℃ SMD3225_4P
3S12000309-Q 数据手册
SMD X'TAL 3.2×2. 5×0.7mm 3S Series ■ Features - 3.2 x 2.5 x 0.7 MAX. mm of surface mounted quartz crystal units. - Excellent reliability characteristics such as heat and mechanical shock. - Pb-free and satisfy RoHs requirements. - Reflow soldering is available. ■ Applications Digital Electronics, Consumer Products, Mobile Communications, Bluetooth, Wireless LAN and Automotive ■ Specifications Frequency range Overtone Order Frequency tolerance at 25℃ Operating temperature range and frequency stability Equivalent series resistance Shunt capacitance Load capacitance Drive level (Max.) Insulation resistance Aging at 25℃ Storage temperature range Measure instrument 8~96 MHz Fundamental ±10, ±15, ±20, ±30, ±50 ppm See Table 1 See Table 2 3 pF Max or specify 8, 16, 20 pF or specify 10, 100, 200 μW or specify 500MΩ Min. at DC 100V ±3 ppm / year Max -40 ~ +85 ℃ or -40 ~ +125 ℃ S&A 250B system with PI circuit ■ Table 1: Operating temperature range and frequency stability ppm Temp 0~+ 50 ℃ - 10~+ 60 ℃ - 20~+ 70 ℃ - 30~+ 85 ℃ - 40~+ 85 ℃ - 40~+ 125 ℃ ■ Table 2: Equivalent series resistance ±5 ±10 ±15 ±20 ±50 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Frequency (MHz) 8~10 10~12 12~16 16~24 24~32 32~54 60~100 The mark “●” denotes our achieved level. ■ Dimensions (unit: mm) Overtone Order Fundamental Fundamental Fundamental Fundamental Fundamental Fundamental Fundamental ■ Land pattern (unit: mm) #4 #3 #3 #1 #2 #2 #4 #1 Pin #1 #2 #3 #4 Function Xtal Terminal (Input) GND Xtal Terminal (Output) GND ESR (Ω MAX) 500 300 80 60 40 30 30
3S12000309-Q
物料型号:3S系列
器件简介:该系列是表面安装的石英晶体单元,具有优秀的热冲击和机械冲击可靠性,无铅且符合RoHS要求,可进行回流焊接。
引脚分配:引脚1(#1)为晶体终端(输出),引脚2(#2)和引脚4(#4)为地(GND),引脚3(#3)为晶体终端(输入)。
参数特性: - 频率范围:8~96 MHz - 基频 - 25°C时频率容差:±10, ±15, ±20, ±30, ±50ppm - 工作温度范围和频率稳定性:见表1 - 等效串联电阻:见表2 - 并联电容:最大3pF或指定 - 负载电容:8, 16, 20 pF或指定 - 最大驱动电平:10, 100, 200 mW或指定 - 绝缘电阻:最小500MΩ(直流100V) - 25°C时老化率:最大±3 ppm/年 - 存储温度范围:-40 ~+85°C或-40~+125°C
功能详解:文档提供了详细的频率稳定性和等效串联电阻的数据表,以及尺寸图和引脚功能说明。
应用信息:适用于数字电子、消费产品、移动通信、蓝牙、无线局域网和汽车。
封装信息:尺寸为3.2 x 2.5 x 0.7 mm,提供了焊盘图案的尺寸信息。
3S12000309-Q 价格&库存
很抱歉,暂时无法提供与“3S12000309-Q”相匹配的价格&库存,您可以联系我们找货
