SMD X'TAL 2.5×2.0×0.6mm
2S Series
■ Features
- 2.5 x 2.0 x 0.6 MAX. mm of surface mounted quartz crystal units.
- Excellent reliability characteristics such as heat and mechanical shock.
- Pb-free and satisfy RoHs requirements.
- Reflow soldering is available.
■ Applications
Digital Electronics, Consumer Products, Mobile Communications,
Bluetooth, Wireless LAN and Automotive
■ Specifications
Frequency range
Overtone Order
Frequency tolerance at 25℃
Operating temperature range and frequency stability
Equivalent series resistance
Shunt capacitance
Load capacitance
Drive level (Max.)
Insulation resistance
Aging at 25℃
Storage temperature range
Measure instrument
12~ 96 MHz
Fundamental
±10, ±15, ±20, ±30, ±50 ppm
See Table 1
See Table 2
3 pF Max or specify
8, 16, 20 pF or specify
10, 100, 200 μW or specify
500MΩ Min. at DC 100V
±3 ppm / year Max
-40 ~ +85 ℃ or -40 ~ +125 ℃
S&A 250B system with PI circuit
■ Table 1: Operating temperature range and frequency stability
ppm
Temp
0~+ 50 ℃
- 10~+ 60 ℃
- 20~+ 70 ℃
- 30~+ 85 ℃
- 40~+ 85 ℃
- 40~+ 125 ℃
±5
±10
±15
±20
±50
■ Table 2: Equivalent series resistance
Frequency
Overtone
ESR
(MHz)
Order
(Ω MAX)
Fundamental
100
12~16
Fundamental
80
16~20
Fundamental
60
20~30
Fundamental
50
30~54
Fundamental
30
60~100
The mark “●” denotes our achieved level
■ Dimensions (unit: mm)
■ Land pattern (unit: mm)
1
0.9
2.5 0.1
#3
#3
#1
#2
#2
1
#4
0.6 Max.
#1
Pin
#1
#2
#3
#4
Function
Xtal Terminal (Input)
GND
Xtal Terminal (Output)
GND
0.65
0.9
0.7
2.0 0.1
0.9
#4
0.85
很抱歉,暂时无法提供与“2S16000016-Q”相匹配的价格&库存,您可以联系我们找货
