深圳市长江微电科技有限公司
SZ CJIANG TECHNOLOGY CO.,LTD
Introduction
•Soft saturation.
•High current,low DCR,high efficiency.
•Very low acoustic noise and very low leakage flux noise.
•High reliability.
•100% Lead(Pb)-Free and RoHS compliant.
•Operating temperature -55~+125℃(Including self - temperature rise)
Applications
• Note PC power system,incl. IMVP-6
• DC/DC converter
Dimensions (Unit: mm)
A
C
D
E
B
F
Code
Dimensions(mm)
A
5.5±0.2
B
5.3±0.2
C
4.8±0.2
D
4.3±0.3
E
1.1±0.3
F
2.3±0.3
H
L
G
Recommend Land Pattern
L
4.5ref
H
4.7ref
G
2.0ref
Unit : mm
深圳市长江微电科技有限公司
Marking
Note:Using Ink for marking
Marking:
Example
Nominal Value
0.18μH
R18
1.2 μH
1R2
4.5 μH
4R5
Structure and Components
NO
Components
Material
1
CORE
Alloy Powder
2
WIRE
Polyester Wire or equivalent.
3
Clip
100% Pb free solder
4
Ink
Halogen-free ketone
5
paint
Epoxy resin
深圳市长江微电科技有限公司
Specification
Part No.
L0 (μH)±20 %
DCR (mΩ)
MAX
Isat (A)
Irms (A)Typ
Max
Typ
20℃
rise
40℃
rise
FEXL0550A-5R6M
5.6
24.2
7.2
8.6
5.3
7.2
FEXL0550A-6R8M
6.8
28.6
6.6
7.8
4.8
6.4
FEXL0550A-8R2M
8.2
32.5
6.1
7.2
4.6
6.1
FEXL0550A-100M
10
43
5.4
6.5
3.8
5
FEXL0550A-150M
15
76.7
3.2
3.7
3
3.9
FEXL0550A-220M
22
99.65
3
3.6
2.5
3.4
Notes:
1. Test frequency : L : 100KHz /0.1V;
2. All test in 25 °C temperature.
3.Testing Instrument:L:HP4285A,CH11025,CH3302,CH1320,CH1320S LCR METER / Rdc:CH16502, MICRO OHMMETER.
4.Heating Rating Current (Irms) will cause the coil temperature rise of 40℃ approximately (Δt);
5.Saturation Current (Isat ) will cause L0 to drop 30% approximately.
6.The part temperature (ambient + temp rise) should not exceed 125℃ under the worst case operating condition. Circuit design, component,
PCB trace size and thickness airflow and other cooling provisions all could affect the part temperature. Part temperature should be verified in the end application.
7.Special inquiries besides the above common used types can be met on your requirement.
DCR Test
深圳市长江微电科技有限公司
Mechanical Reliability
Item
Specification and Requirement
1. No case deformation
or change in visual
Solderability
2. New solder coverage
Test Method
1.Preheat:155℃±5℃ ,60S±2S
2.Tin: lead-free.
3.Temperature:240℃±5℃,flux 3.0S±0.5S.
More than 95%
Mechanical
1. Acceleration: 100G
or change in visual
2. Pulse time::6ms
shock
3. 3 times in each positive and negative direction of 3
2. △L/Lo≦±10%
Mechanical
or change in visual
vibration
2. △L/Lo≦±10%
mutual perpendicular directions
1. Reflow: 2times
2. Frequency: 10HZ~50HZ~10HZ,20 Min/Cycles
3. Amplitude: 1.52 mm±10%
4. Directions: X,Y,Z
5. Time: 12 cycle / direction
Endurance Reliability
Item
Inductance change:
Thermal Shock
Within ± 10% Without distinct damage
in visual
Test Method
1. First -55℃ for 30 minutes,last 125℃ for 30 minutes
as 1 cycle. Go through
1000 cycles.
2. Max transfer time is 3 minutes.
3. Measured at room temperature after placing for 24±2
hours
Biased
Humidity
Inductance change:
1.Reflow 2 times,
2.85℃±3℃,85%±3%RH,1000 hours
in visual
3.Measured at room temperature after placing for 24±2
hours
Low
temperature
storage
High
temperature
storage
Inductance change:
1. Temperature:-55 ± 2℃
2. Time:1000 hours
in visual
hours
Inductance change:
in visual
1. Temperature:+125 ± 2℃
2. Time:1000 hours
hours
深圳市长江微电科技有限公司
Recommended Soldering Technologies
(1)Re-flowing Profile
Preheat condition: 150 ~200℃/60~120sec.
Allowed time above 217℃: 60~90sec.
Peak temp: 260℃
Max time at Peak temp: 10 sec.
Solder paste: Sn/3.0Ag/0.5Cu
Allowed Reflow time: 2x max
(2)Iron Soldering Profile
Iron soldering power: Max. 30W
Pre-heating: 150℃/60sec.
3sec. Max.
350℃
Soldering Tip temperature: 350℃ Max.
Power: max. 30W
Soldering time: 3sec. Max.
Diameter of Soldering
Max.1 times for iron soldering
Soldering Iron
Iron 1.0mm max.
Tc ℃
深圳市长江微电科技有限公司
Packaging Information
(1) Tape Packaging Dimensions(Unit:mm)
Tape dimensions (mm)
W
P
P0
P2
D0
D1
T
A0
B0
K0
E
F
16
±0.3
8
±0.1
4
±0.1
2
±0.1
1.5
±0.1
1.5
±0.1
0.35
±0.05
6.0
±0.1
5.7
±0.1
5.3
±0.1
1.75
±0.1
7.5
±0.1
Taping Drawings (UNIT:mm)
深圳市长江微电科技有限公司
(2) Reel Dimensions(Unit:mm)
B
N
C
W
A
W
N
B
C
330+2.0
16.8+0.2
97+0.5
2.2+0.5
13.2±0.2
(3) Packaging Quantity
Standard Quantity
Reel
Inner box
1500 pcs / reel
3Reel / box (4500 pcs)
(4) Peel force of top cover tape
The peel speed shall be about 300mm/minute
The peel force of top cover tape shall be between 0.1 to 1.3 N
Carton box
4 Middle boxes,
(18,000 pcs)
A
深圳市长江微电科技有限公司
(5) Reel Label
Label on the reel
• Customer's part Number
• Lot Number
• Quantity
• date code
Shipping Label
• Manufacturer's part Number
• Quantity
• date code
(6) Inner Box
(7) Carton
A
B
C
深圳市长江微电科技有限公司
Appearance criterion
1、PAD residual powder、inner wire exposed、imprinting
The residual powder on both side of pad is norm and within following criteria are acceptable.
2、Defects
Chip off is generated during molding and manufacturing process.
Chip off acceptance limits subjected to the product size.
Our current Defect limit is based on the IPC-A-610.
Some chip off does not impact the product function, see the IPC standard 1 & 2.
w
T
L
Marking
T
≤10% of the thickness
Each surface can only accept
W
≤10 % of the width
one minor chip off,and more than 3
L
≤10 % of the length
chip off problems are not allowed on
the same product.
Defects usually occur at the corners and edges of the product,There will be
a slight defect black and rough, but not exposed copper, and does not
affect the product performance and reliability.
3、Crack
Production process of cracks appearing in the body is inevitable, some slight crack is caused because the molding,
is not oxidized, crack on the product will not affect product performance.
We have done a reliability test of crack products, even if cracks is more than 0.13mm also will not
affect the electrical properties of the product, crack limits as follows:
Products from a slight crack in the baking process due to thermal expansion, and it is not obvious by visual inspection
(Must not exceed the blue square area).
Cracks on the same side surface are not allowed to exceed 1/2 of the length of the side and the crack width cannot exceed 0.13mm,
and only 1 crack is allowed on the same side.
Bottom cracks are not allowed to exceed 1/2 of the length (or width) of the corresponding body nor the Non-manufacturability swelling,
and the crack width cannot be exceed 0.13mm, and less than 2 cracks are allowed and judged as good products.
Visible cracks and non-manufacturability bulging are not allowed on the front side.
4、oxidation(rust)
the contains iron composite, although the resin has a protective effect of oxidation,but there will be
small amount of product that may occur oxidation, The oxidation area of each surface is allowed to
be about 25% (in the case of non-reliability test),it is recommend that customer use this product in
humidity controlled environment.The basic steps should be to protect the surface oxidation, including
the sealed packages to PCB mount inductors. To avoid the adverse effects caused by oxidation,
Oxidation occurs at the surface only allows the internal oxidation is not allowed, oxidized surface will
not affect the reliability of the product.
Marking
4sides slightly oxidized side:
Acceptable
Marking
Top and bottom slightly oxidized side:
Spray printing effect :
can be accepted if recognizable
Acceptable
Visual inspection: Examination with the naked eye, to distinguish from more technical modes of analysis employing tools or apparatus.
很抱歉,暂时无法提供与“FEXL0550A-5R6M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.79500
- 100+3.15700
- 750+2.87100
- 1500+2.75000
- 国内价格
- 1+4.42650
- 10+3.95930
- 30+3.51180
- 100+2.90190
- 1500+2.65600
- 国内价格
- 1+3.94200
- 10+3.44520
- 30+3.20760
- 100+2.95920
- 500+2.80800
- 1500+2.73240
