5S16900019-Q
5S16900019-Q
    YL(惠伦晶体)
    SMD5032_4P
    无源晶振 50Ω 16pF 16.9344MHz ±20ppm -10℃~+60℃ SMD5032_4P
5S16900019-Q 数据手册
SMD X'TAL 5.0×3.2×0.9mm 5S Series ■ Features - 5.0 x 3.2 x 0.9±0.15 mm of surface mounted quartz crystal units. - Excellent reliability characteristics such as heat and mechanical shock. - Pb-free and satisfy RoHs requirements. - Reflow soldering is available. ■ Applications Digital Electronics, Consumer Products, Mobile Communications, Bluetooth, Wireless LAN and Automotive ■ Specifications Frequency range Overtone Order Frequency tolerance at 25℃ Operating temperature range and frequency stability Equivalent series resistance Shunt capacitance Load capacitance Drive level (Max.) Insulation resistance Aging at 25℃ Storage temperature range Measure instrument 8~100 MHz Fundamental, 3rd overtone ±10, ±15, ±20, ±30, ±50 ppm See Table 1 See Table 2 5 pF Max or specify Series, 8, 16, 20 pF or specify 10, 100, 200 μW or specify 500MΩ Min. at DC 100V ±3 ppm / year Max -40 ~ +85 ℃ or -40 ~ +125 ℃ S&A 250B system with PI circuit ■ Table 1: Operating temperature range and frequency stability ppm Temp 0~+ 50 ℃ - 10~+ 60 ℃ - 20~+ 70 ℃ - 30~+ 85 ℃ - 40~+ 85 ℃ - 40~+ 125 ℃ ±5 ±10 ±15 ±20 ±50 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ■ Table 2: Equivalent series resistance Frequency Overtone ESR (MHz) Order (Ω MAX) Fundamental 100 8~10 Fundamental 80 10~12 Fundamental 60 12~15 Fundamental 50 15~54 3rd overtone 100 40~80 3rd overtone 90 80~100 The mark “●” denotes our achieved level ■ Dimensions (unit: mm) ■ Land pattern (unit: mm) 5.00 0.15 2.6 2 #3 #3 #4 #1 #2 #2 #1 1.7 2 0.90 0.15 1 1.2 1.4 3.20 0.15 1.2 #4 Pin #1 #2 #3 #4 Function Xtal Terminal (Input) GND Xtal Terminal (Output) GND
5S16900019-Q
物料型号:5S Series YL200、YNO3
器件简介:5.0 x 3.2 x 0.9±0.15 mm的表面贴装石英晶体单元,具有出色的热冲击和机械冲击可靠性,无铅且符合RoHs要求,可进行回流焊接。
应用信息:适用于数字电子、消费产品、移动通信、蓝牙、无线局域网和汽车。
参数特性: - 频率范围:8~100 MHz - 基频和3次泛音 - 25°C时频率容差:±10, ±15, ±20, ±30, ±50 ppm - 工作温度范围和频率稳定性:详见表1 - 等效串联电阻:详见表2 - 并联电容:最大5 pF或指定 - 负载电容:串联,8, 16, 20 pF或指定 - 最大驱动电平:10, 100, 200 W或指定 - 绝缘电阻:最小500MΩ,直流100V - 25°C时老化率:最大±3 ppm/年 - 存储温度范围:-40~+85°C或-40~+125°C - 测量仪器:S&A 250B系统与PI电路
引脚分配: - #2 GND:晶体终端(输入) - #3 Xtal:晶体终端(输出) - #4 GND:接地
封装信息:尺寸为5.00 x 3.20 x 0.90 mm,引脚间距为1.7 mm。
5S16900019-Q 价格&库存
很抱歉,暂时无法提供与“5S16900019-Q”相匹配的价格&库存,您可以联系我们找货
